Sign in to follow this
aminerva
Atari Artist?
Anybody know where I can get a copy of the atr file for Atari Artist? I've got the touch tablet but not the software for running it (I think it came with Atari Artist). I can get the cart off of EBay, but thought I'd see if anyone knew where I could get the ATR file for my sio2pc cable instead.
Holmes has a copy, but I've not been able to get it to work on my 800XL (I've tried using the translator disk, just in case). The file name reads "Atari Artist -nw.atr), not sure what the "-nw" means (not working?). I've also tried the file on atari800win, without any luck.
Any help appreciated
Tony
I'm searching Atari Artist .atr or .bin. or .xex.
Can someone help me?
Thanks very much to all!
The only problem is that I'm not able to run the .xex version with Atari800Win Plus 4.0.
Hm, it won't work with the "load xex" menu option, but if you copy the .xex to a DOS disk and boot it, it'll run fine... Apparently Atari800win's XEX loader hates something about my "loading" intro screen.
Were you getting a brief flash of a "loading atari artist" screen, then a black screen, then BOOT ERROR?
Anyway, here's an ATR image that works with Atari800win. It's DOS 2.0, with the same xex file, named AUTORUN.SYS.
atari_artist_atr.zip
Now that I think of it... you don't want to use the xex by itself anyway. If you do, you won't have DOS loaded, so you won't be able to save your drawings.
I've just dumped it using QMEG.
Hi Fandal
Could you please describe the procedure used to dump a cart using QMEG?
Thanks!
Hi Fandal
Thanks!
It's very easy. Just insert the cart, turn computer on and jump to QMEG (SELECT+RESET). Then jump to monitor and use command for writing memory to D1: device: $ADR>$START_SECTOR.$NUMBER_OF_SECTORS. I used APE and this command: 8000>3.80 (write memory $8000-$BFFF to disk from sector $03 - note that you're in hexa mode!) as I didn't know if the cart was 8kB or 16kB. This works for non-switchable carts only. If you want to dump switchable cart you must use some dumping program.
Sounds easy? There's one small problem. You must be able to jump to QMEG. But boot of QMEG doesn't have higher priority than boot of cart (like standard Atari OS). In other words: when you boot from cart you won't be able to jump to QMEG. I usually use this dirty trick: I hold SELECT+RESET when turning computer on. And sometimes the computer is not booting from cart when I leave hold of. Then I must hold those two keys again and I'm able to just to QMEG. The only problem is that one must still hold those two keys for the rest of action. I know it's pretty ugly and dirty and I'm sure a lot of users here will describe you much more safer ways how to dump carts...
F.
It's very easy. Just insert the cart, turn computer on and jump to QMEG (SELECT+RESET). ...
Excellent.
Thanks, Fandal. It seems that booting an OS with a cart inserted is always the big issue when dumping a cart's contents. I remember a hardware hack on Jindroush's site to control RD4 and RD5 lines, so booting with a cart inserted was possible.
Is there another Atari OS able to boot with a cart inserted?
Regards
