+5-11under #1 Posted September 11, 2009 Hi there, I need to create a 2 layer PCB that is about 4" x 6" or so. In the past, I've used FreePCB, which is okay for smaller boards, but I'm afraid it won't work well with relatively complex boards. I also see that the free version of Eagle is size-limited. I'm wondering if anyone with some experience with other PCB layout software can recommend a solution for somewhat larger and more complex boards? Ideally, I'd like it to be free, or pretty close. Any help would be appreciated. Thanks, 5-11under Quote Share this post Link to post Share on other sites
+GroovyBee #2 Posted September 11, 2009 Have you considered using surface mount parts to try and get the board size down? Quote Share this post Link to post Share on other sites
thebiggw #3 Posted September 11, 2009 Would KiCad work? Quote Share this post Link to post Share on other sites
+5-11under #4 Posted September 11, 2009 Have you considered using surface mount parts to try and get the board size down? Yes, I'll be using surface mount parts for as much as possible. Mostly SOIC, as a compromise between solderability and size. Based on having several connectors, switches, and such, I'll definitely be above Eagle Light's limit of 4" x 3.2" 5-11under Quote Share this post Link to post Share on other sites
+5-11under #5 Posted September 11, 2009 Would KiCad work? I saw their website. Have you used it? Is it good? Thanks, 5-11under Other information I should have mentioned in my first post: This is for a Windows XP environment. KiCad would pass this requirement. Quote Share this post Link to post Share on other sites
thebiggw #6 Posted September 11, 2009 I haven't had much time to mess with it. I had to much other stuff going on. I got an idea for a controller replacement for the 5200 that I am hoping will be cheap enough to produce. My goal is to keep in the 25$ range I have been studying the schematics and pin outs. But for now its on the back burner as I got to many other projects on the go. Quote Share this post Link to post Share on other sites
+5-11under #7 Posted September 11, 2009 It looks like I'll be trying KiCad. I'll post a review, if I remember. Thanks, 5-11under Quote Share this post Link to post Share on other sites
