Chainclaw #1 Posted September 24, 2009 I am trying to implement a level selection in my current game, and am not quite sure how to do it. I tried making an array like "data tColumn0Level0", and then I wasn't sure how to assign a variable like a pointer to it. I am on my phone, so I did minimal searching but it's really slow to find info Quote Share this post Link to post Share on other sites
jbs30000 #2 Posted September 24, 2009 I am trying to implement a level selection in my current game, and am not quite sure how to do it. I tried making an array like "data tColumn0Level0", and then I wasn't sure how to assign a variable like a pointer to it. I am on my phone, so I did minimal searching but it's really slow to find info tColumn0Level0 is the pointer. This should have the information you're looking for Click Here Quote Share this post Link to post Share on other sites
Chainclaw #3 Posted September 25, 2009 I am trying to implement a level selection in my current game, and am not quite sure how to do it. I tried making an array like "data tColumn0Level0", and then I wasn't sure how to assign a variable like a pointer to it. I am on my phone, so I did minimal searching but it's really slow to find info tColumn0Level0 is the pointer. This should have the information you're looking for Click Here I read that, and couldn't find what I was looking for. Here is what I want to do: dim currentLevel = a dim selectedLevelIndex = b data tColumn0Level0 some data for the first level end data tColumn0Level1 some data for the second level end if selectedLevelIndex = 0 then currentLevel = tColumn0Level0 if selectedLevelIndex = 1 then currentLevel = tColumn0Level1 rem fill in the playfield with the level data var25 = currentLevel[index] var29 = currentLevel[index+1] var33 = currentLevel[index+2] Is there any way to do something like that? Quote Share this post Link to post Share on other sites
jbs30000 #4 Posted September 25, 2009 I am trying to implement a level selection in my current game, and am not quite sure how to do it. I tried making an array like "data tColumn0Level0", and then I wasn't sure how to assign a variable like a pointer to it. I am on my phone, so I did minimal searching but it's really slow to find info tColumn0Level0 is the pointer. This should have the information you're looking for Click Here I read that, and couldn't find what I was looking for. Here is what I want to do: dim currentLevel = a dim selectedLevelIndex = b data tColumn0Level0 some data for the first level end data tColumn0Level1 some data for the second level end if selectedLevelIndex = 0 then currentLevel = tColumn0Level0 if selectedLevelIndex = 1 then currentLevel = tColumn0Level1 rem fill in the playfield with the level data var25 = currentLevel[index] var29 = currentLevel[index+1] var33 = currentLevel[index+2] Is there any way to do something like that? I see what you're saying and I don't think you can. I assume you tried the code and it didn't work. If so, then there's your answer I'm afraid. Quote Share this post Link to post Share on other sites
+RevEng #5 Posted September 25, 2009 I'll preface this by saying that I'm a 6502 noob. Hopefully someone more experienced can jump in with corrections. I think the reason what you're trying to do can't be done boils down to the fact that the opcodes that allow indirect/variable memory access have a base address hardcoded in the instruction and an 8-bit index, which only allows for access to 256 bytes. (Hence the limitation on array access in bB) You might see if "sread" can do what you need, or use if statements to test your level variable and use different blocks of code for different levels, or... You might be able to create a small ram-based value loader subroutine. Just change the instruction address in ram and jsr to the routine. [Patiently waits to be schooled by one of the 6502 gurus ] Quote Share this post Link to post Share on other sites
jrok #6 Posted September 25, 2009 (edited) I am trying to implement a level selection in my current game, and am not quite sure how to do it. I tried making an array like "data tColumn0Level0", and then I wasn't sure how to assign a variable like a pointer to it. I am on my phone, so I did minimal searching but it's really slow to find info tColumn0Level0 is the pointer. This should have the information you're looking for Click Here I read that, and couldn't find what I was looking for. Here is what I want to do: dim currentLevel = a dim selectedLevelIndex = b data tColumn0Level0 some data for the first level end data tColumn0Level1 some data for the second level end if selectedLevelIndex = 0 then currentLevel = tColumn0Level0 if selectedLevelIndex = 1 then currentLevel = tColumn0Level1 rem fill in the playfield with the level data var25 = currentLevel[index] var29 = currentLevel[index+1] var33 = currentLevel[index+2] Is there any way to do something like that? Yes, there is a way to do this, but not the way you are attempting it. One of the problems is that you are trying to store your arrays in the variable "currentLevel" when in fact "currentLevel" should be your pointer. One way of doing what you want here would be to store *all* of your level data in one data statement (i.e. "Levels") and then treat that as a multidimensional array. In other words, if each level contained 30 values to describe it, then to access each individual level you would use: include div_mul.asm dim currentLevel = a dim selectedLevelIndex = b Levels (30 values for level 1), (30 values for level 2), (30 values for level 3), end selectedLevelIndex = currentLevel * 30 That would bring you to the first value of of each level, then you could use addition to access values 1-through-29 (or 31-through-59, or 61-through-89, etc). If that doesn't make sense to you, I can post an example later today when I have some free time. Cheers, Jarod. Edited September 25, 2009 by jrok Quote Share this post Link to post Share on other sites
Chainclaw #7 Posted September 28, 2009 Yes, there is a way to do this, but not the way you are attempting it. One of the problems is that you are trying to store your arrays in the variable "currentLevel" when in fact "currentLevel" should be your pointer. One way of doing what you want here would be to store *all* of your level data in one data statement (i.e. "Levels") and then treat that as a multidimensional array. In other words, if each level contained 30 values to describe it, then to access each individual level you would use: include div_mul.asm dim currentLevel = a dim selectedLevelIndex = b Levels (30 values for level 1), (30 values for level 2), (30 values for level 3), end selectedLevelIndex = currentLevel * 30 That would bring you to the first value of of each level, then you could use addition to access values 1-through-29 (or 31-through-59, or 61-through-89, etc). If that doesn't make sense to you, I can post an example later today when I have some free time. Cheers, Jarod. Thanks, that seems like it might do what I want. I will have to test it when I get a chance to sit down and work on this a little more. My only concern is the 256 array size limit. Quote Share this post Link to post Share on other sites
+RevEng #8 Posted September 29, 2009 A more complicated example, without the 256-byte limitation on the total level data... levelloader.bas levelloader.bas.bin ...it loads the data into the score variable, but there's no reason why it couldn't be playfield data or any other variables. rem *********************************************************************** rem arbitrary level data loader example rem rem features rem ...level data is loaded from an indexed array rem ...total level data can be bigger than 256 bytes rem rem limitations rem ...level for any one level must be <257 bytes rem ...eats up cycles because in-ram routine is a subroutine and uses one rem sub call per byte. this could be fixed easily if you dedicate more rem ram to the ram-based asm routine. rem rem notes rem ...requires all-in-one score_graphics.asm file, found here: rem http://www.atariage.com/forums/topic/147450-custom-fonts-for-bb-all-in-one-score-graphicsasm rem rem *********************************************************************** const fontstyle=CURVES const fontcharSPACE = 1 const fontcharARIFACE = 1 const lvl1lo = #>lvl1 const lvl1hi = #<lvl1 const lvl2lo = #>lvl2 const lvl2hi = #<lvl2 const lvl3lo = #>lvl3 const lvl3hi = #<lvl3 const lvl4lo = #>lvl4 const lvl4hi = #<lvl4 rem *** the size of the level data, in bytes const levelsize = 3 def sc1=score def sc2=score+1 def sc3=score+2 def level=a def delay=b scorecolor=$0f level=0 initlevel rem *** call our level loader... gosub loadlvldata rem *** do any other level initialization delay=0 gameloop drawscreen rem *** wait for 120 frames and then increment the level. If it's >3 make it smaller if delay=120 then level=level+1 : level=level & 00011 : goto initlevel delay=delay+1 goto gameloop data lvlhipointers lvl1hi, lvl2hi, lvl3hi, lvl4hi end data lvllopointers lvl1lo, lvl2lo, lvl3lo, lvl4lo end data lvl1 $1a,$aa,$ab end data lvl2 $2a,$aa,$ba end data lvl3 $3a,$ab,$aa end data lvl4 $4a,$ba,$aa end loadlvldata rem the following code loads theses opcodes into the temp variables: rem ldx $XXXX,y ($BE,XX,XX) rem stx $XX,y ($96,XX) rem rts ($60) temp1=$be temp2=lvlhipointers[level] temp3=lvllopointers[level] temp4=$96 temp5=#score temp6=$60 asm ldy levelsize keeploadinglvl jsr temp1 dey bpl keeploadinglvl clc end return Quote Share this post Link to post Share on other sites
