+bf2k+ #1 Posted October 10, 2009 I am looking for a FAST easy way to copy a bunch of files from a PC dir to an A8 SpartaDOS folder. Obviously I can do them 1 at a time, but I need something faster. The H: device in A800winplus 3.1 doesn't support a wildcard copy from H: to D: so that is out. Any ideas out there? Quote Share this post Link to post Share on other sites
+Roydea6 #2 Posted October 10, 2009 (edited) I am looking for a FAST easy way to copy a bunch of files from a PC dir to an A8 SpartaDOS folder. Obviously I can do them 1 at a time, but I need something faster. The H: device in A800winplus 3.1 doesn't support a wildcard copy from H: to D: so that is out. Any ideas out there? Since you are using an emulator. Try reading this thread: http://www.atariage....1entry1793830 Post #4 Make your ATR on the pc mount as Drive 2, copy D2:*.* folder>*.* other ATR managing programs for the PC are: MakeATR v0.06 supports Spartados directories. http://makeatr.prv.pl/ look for file at bottom of webpage. AtrUtil 1.3 Ken Siders 'sp' Some others that I don't use often and can't remember names. Just make your ATR on the PC and mount as a drive on the emulator. Edited October 10, 2009 by rdea6 Quote Share this post Link to post Share on other sites
+Larry #3 Posted October 10, 2009 Sounds perfect for APE's PC Mirror (registered Version only, though). Set the PC Mirror for your PC directory and D: as the target drive directory. I've done this many times with MyDos, but not Sparta. But I still think it would work fine. In my case, ©opy D4:*.*,*.* It hauls away... -Larry I am looking for a FAST easy way to copy a bunch of files from a PC dir to an A8 SpartaDOS folder. Obviously I can do them 1 at a time, but I need something faster. The H: device in A800winplus 3.1 doesn't support a wildcard copy from H: to D: so that is out. Any ideas out there? Quote Share this post Link to post Share on other sites
+bf2k+ #4 Posted October 10, 2009 Sounds perfect for APE's PC Mirror (registered Version only, though). Set the PC Mirror for your PC directory and D: as the target drive directory. I've done this many times with MyDos, but not Sparta. But I still think it would work fine. In my case, ©opy D4:*.*,*.* It hauls away... -Larry Yep, I figured that out after I left the message - Ape PCMirror worked perfectly! I need to take a look at ATR Util though... Thanks to all. Quote Share this post Link to post Share on other sites
Synthpopalooza #5 Posted October 12, 2009 Here's what I use to copy between hard drive and atr's: http://raster.infos.cz/atari/forpc/atadim.htm ATADIM ... it is a very handy little program too. Quote Share this post Link to post Share on other sites
+bf2k+ #6 Posted October 12, 2009 Here's what I use to copy between hard drive and atr's: http://raster.infos....orpc/atadim.htm ATADIM ... it is a very handy little program too. I remember that program - I had it on an old machine but I lost track of it. Quote Share this post Link to post Share on other sites
flashjazzcat #7 Posted October 12, 2009 I know I've said this before, but The Last Word running under SpartaDOS X lets you catalogue any H: drive you want, tag and batch copy files, traverse the folder structure, you name it. When developing on the PC, I just boot the emulator, load up LW, go to the disk menu, and copy everything I want from H: to D:. I know it's not a stand-alone file manager, but it's very powerful nonetheless. Quote Share this post Link to post Share on other sites
1050 #8 Posted October 14, 2009 AtrUtil 1.3 Ken Siders 'sp' Don't you mean version 1.13 and it still doesn't do Sparta disks. 'sp'? http://atari.kensclassics.org/a8emulators.html Here's what I use to copy between hard drive and atr's: http://raster.infos.cz/atari/forpc/atadim.htm ATADIM ... it is a very handy little program too. For me, Winzip says the executable is corrupt and won't give it to me. What is anybody else using to get Atadim.exe downloaded? TIA. Quote Share this post Link to post Share on other sites
flashjazzcat #9 Posted October 14, 2009 Works fine for me. Here's a re-zipped version: atadi305.zip Quote Share this post Link to post Share on other sites
