Videogamecollector123
Battlefield Vietnam problem
Hi, I have this problem with Battlefield vietnam when I'm playing it after a little bit the screen will start blacking out and stop accepting my controls. I'm a pilot in the game most of the time so when this happens by the time I get it to come back with ctrlaltdel I've crashed most of the time. Does anyone know how to fix this problem I run vista 32 bit and have tried compatiblity mode
It's not compatible with vista. But you could try this:
got my computer, C:/program Files/EA GAMES/Battlefield 1942/modsbf1942/ open in notepad the file VideoDefault.con
renderer.allowAllRefreshRates 0
change the 0 into a 1
or try this solution
Make sure you've patched the 1.21 of BFV and 1.6.19 of BF42 and then change
your login to be an administrator login and all seems to work great except
for the missing crosshairs. Played sometime with no indication of trouble.
Theoretically you could just set the program to 'Run as Administrator' and
that *should* work. I'll test this if I have time.
tweakguides
Edited by Seob
