mimo Posted November 3, 2009 Share Posted November 3, 2009 In a 600xl, waiting in Poland for a load of other cool stuff to be fitted:P Quote Link to comment Share on other sites More sharing options...
Roydea6 Posted November 3, 2009 Share Posted November 3, 2009 i'm affride Beetle won't tell you this Hmm - a mystery then. You guys never stop tinkering with cool toys!! Stephen Anderson Stephen , Go back and re-read post #15. You are referring to the wrong guy. Quote Link to comment Share on other sites More sharing options...
Beetle Posted November 3, 2009 Author Share Posted November 3, 2009 (edited) Hi folks, Mimo: cool to see it in smallest a8, too. Here is my 1200XL: The installed VBXE upgrade, OS eprom modification in the works. I used XE Adaptor board. People asked how to mount the ST monitor jack - i used hotglue. Thats what the back looks like now. Headphone jack for stereo pokey output. The channel switch does now switch between 2 OS :-) Does your 1200XL run Ice-T terminal emulator that sharp? I love VBXE! Greetings, Beetle Edited November 3, 2009 by Beetle Quote Link to comment Share on other sites More sharing options...
+Stephen Posted November 3, 2009 Share Posted November 3, 2009 Stephen , Go back and re-read post #15. You are referring to the wrong guy. D'oh - that'll teach me. OK - now two questions for candle. What is that mystery PCB, and why is your 1200XL startup screen blue and not black? Stephen Anderson Quote Link to comment Share on other sites More sharing options...
candle Posted November 3, 2009 Share Posted November 3, 2009 i'll start from the last one because it run long enought that atract mode started the board provides clearance for another boards - as AOSD module and io-board possibly PBI bus in near future Quote Link to comment Share on other sites More sharing options...
Beetle Posted November 4, 2009 Author Share Posted November 4, 2009 (edited) Cool, 1200XL is now a capable photo display. Watch your favorite usermeeting pics on a suitable system! Pictures are 320x240 pixels, 256 colors out of a 24 bit pallete. Looks really neat on a 1084S. Edited November 4, 2009 by Beetle Quote Link to comment Share on other sites More sharing options...
Thorsten Günther Posted November 4, 2009 Share Posted November 4, 2009 yep can you buy these new? Digi-key has > 3000 in stock - $2.85 US In Germany, at least Reichelt has them in stock, too (didn't bother looking up Conrad). They were not only used by Atari, but also by Aiwa, Kenwood, Clarion and Blaupunkt (among others, presumably) to connect car CD changers to the car radio. They're a PITA to solder, though, that's why I started harassing Beetle with this issue (although my VBXE didn't arrive yet). Thorsten Quote Link to comment Share on other sites More sharing options...
candle Posted November 4, 2009 Share Posted November 4, 2009 Could You point me in direction of some datasheet? i need to add footprint to my library in order to use them Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted November 4, 2009 Share Posted November 4, 2009 Could You point me in direction of some datasheet? i need to add footprint to my library in order to use them This? SDD-130J.zip Quote Link to comment Share on other sites More sharing options...
candle Posted November 4, 2009 Share Posted November 4, 2009 nice! really apreciate it Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 4, 2009 Share Posted November 4, 2009 Hot melt glue crept up into insides of 13 pin DIN socket... had to order another one. More delays... Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 5, 2009 Share Posted November 5, 2009 You could probably get some out with a hairdryer... that stuff is supposed to melt at only 70 Degrees C or so. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 5, 2009 Share Posted November 5, 2009 You could probably get some out with a hairdryer... that stuff is supposed to melt at only 70 Degrees C or so. I managed to salvage it, but it looks a little scruffy now. I'll fit the next one with the plug in... Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 5, 2009 Share Posted November 5, 2009 How many are you building? I'm not decided yet on my socket type ... kinda thinking of using a standard VGA D15 socket - I've got this old 15-9 adaptor cord lying around which would let me plug straight into the 1084. Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted November 5, 2009 Share Posted November 5, 2009 How many are you building? I'm not decided yet on my socket type ... kinda thinking of using a standard VGA D15 socket - I've got this old 15-9 adaptor cord lying around which would let me plug straight into the 1084. Just the one. I meant the next socket when it arrives in the post. I was going to go for a wide DB15 socket until I noticed the 13-Pin DIN idea. The thing I like about that is that there's no hacking of the case required. Quote Link to comment Share on other sites More sharing options...
candle Posted November 7, 2009 Share Posted November 7, 2009 the one i (almost - i don't have din8 socket yet) did for Heaven additional 3 pins of din8 will be used for RGB, and the remaining 5 provides backward compatibility with standard monitor cables (you can plug din5 jack into din8 socket) Quote Link to comment Share on other sites More sharing options...
+Stephen Posted November 7, 2009 Share Posted November 7, 2009 the one i (almost - i don't have din8 socket yet) did for Heaven additional 3 pins of din8 will be used for RGB, and the remaining 5 provides backward compatibility with standard monitor cables (you can plug din5 jack into din8 socket) Excellent idea on the DIN8 - I think this is the route I will go. Stephen Anderson Quote Link to comment Share on other sites More sharing options...
Mathy Posted November 7, 2009 Share Posted November 7, 2009 Hello Candle Wouldn't the din7 of the power supply also fit into the din8 socket? greetings Mathy Quote Link to comment Share on other sites More sharing options...
candle Posted November 7, 2009 Share Posted November 7, 2009 nope i've used din8-262, you can't fit din7 into this standard din8 is 280, din8-262 is as the one used in commodore Quote Link to comment Share on other sites More sharing options...
Mathy Posted November 7, 2009 Share Posted November 7, 2009 Hello Candle So the din7 will not fit, but the din5 will? Will you have to solder 8 wires to the din8 connector or will five of the pins drop into the five wholes in the motherboard? I've seen a din10 connector on the internet. I guess both din5 and din7 will not fit? greetings Mathy Quote Link to comment Share on other sites More sharing options...
candle Posted November 7, 2009 Share Posted November 7, 2009 close up: and bottom side: Quote Link to comment Share on other sites More sharing options...
Tezz Posted November 8, 2009 Share Posted November 8, 2009 After spending the day down in London today with Zaxon, I finally now have the VBXE2 installed Many thanks for all your help today Zaxon! Quote Link to comment Share on other sites More sharing options...
Beetle Posted November 8, 2009 Author Share Posted November 8, 2009 cool Tezz! Will you please us with a picture? Quote Link to comment Share on other sites More sharing options...
Tezz Posted November 8, 2009 Share Posted November 8, 2009 (edited) Sure ting Beetle, Will get it posted in the morning I had a chance to see the osd proto too. will be good for many things when this is ready also. Edited November 8, 2009 by Tezz Quote Link to comment Share on other sites More sharing options...
candle Posted November 9, 2009 Share Posted November 9, 2009 (edited) well Tezz, so where are Your pictures? to cut the wait, here is a bit improved logo for 1200XL binary included, hopefully i'll put this into eprom so it would start as normal 1200xl logo screen - to cut "it won't fit" talk - i'm going to put it as "basic" rom, and use stock 800xl rom for system - this is also make this machine pbi capable i'll add sources for this when i'll finnish the work 1200xl.zip Edited November 9, 2009 by candle Quote Link to comment Share on other sites More sharing options...
