HiroProX #126 Posted January 26, 2010 I'm now convinced I need to get one of these. Quote Share this post Link to post Share on other sites
atarian63 #127 Posted January 26, 2010 I still need to find time to install mine..Dammit! Quote Share this post Link to post Share on other sites
DamageX #128 Posted January 26, 2010 pic: http://www.hyakushiki.net/vbxeinst.jpg I cheated and used a rev D board which already had ICs in sockets. Wizztronics 256KB board is on the left, patched OS EEPROM with a socket that's too long on the right, and a hole in the back of the case (don't ask). I have it hooked up to RGB inputs on an OLD 19" NEC 15KHz monitor. 80-column text is pretty sharp. Quote Share this post Link to post Share on other sites
Rybags #129 Posted January 26, 2010 Nice... I'm not sure which Core version you should use though... IIRC there's the normal "A" core, and the "R" core if it's a RAMBO compatible expansion. Quote Share this post Link to post Share on other sites
electron #130 Posted January 26, 2010 Nice... I'm not sure which Core version you should use though... IIRC there's the normal "A" core, and the "R" core if it's a RAMBO compatible expansion. R version of the core has Rambo-compatible upgrade built in. (the upgrade uses vbxe VRAM, sharing it with normal vbxe functions) So, if there is any memory upgrade already installed in the computer then user should use "A" version of the core, "R" is intended for stock 65/800XE/XL computers only. Quote Share this post Link to post Share on other sites
candle #131 Posted January 26, 2010 (edited) DamageX: there is no free ride - machine sockets as on rev d are no good to hold vbxe2 board in place - it might pop up! you don't want that kind of suprise [edit] all VBXE2 boards (except "special orders" as for 1200xl or "low profile") are configured to use FX 1.20A core, these excluded from above are running so called TEST core (AVR led lit, FPGA led blinking at 13.5Hz frequency, sawtooth present on each of video DAC channles) Edited January 26, 2010 by candle Quote Share this post Link to post Share on other sites
+Stephen #132 Posted January 31, 2010 Finally beginning work. Details at my AA blog here. Still an early WIP. Stephen Anderson Quote Share this post Link to post Share on other sites
jvas #133 Posted February 1, 2010 they are also included in this package and its always at http://spiflash.org/files/vbxe/release.zip I wanted to install my VBXE but I have a couple of OOPS: - IIRC it does matter whether the machine is PAL or NTSC. I thought my 130XE is PAL, but how can I make sure it really is. - I assume it has 4bit RAM (LH2464-10) but I had 4 of these chips instead of 2 that is in "release.zip" - what is u34 for? It is populated in my motherboard. Thanks in advance, Jozsi Quote Share this post Link to post Share on other sites
candle #134 Posted February 1, 2010 130xe has 4 chips where 65xe has only 2 pal machine has 14.18 crystal/oscillator where ntsc has 14.31 one u34 is EMMU - extended memory management unit, so again - unpopulated for 65xe Quote Share this post Link to post Share on other sites
jvas #135 Posted February 1, 2010 130xe has 4 chips where 65xe has only 2 pal machine has 14.18 crystal/oscillator where ntsc has 14.31 one u34 is EMMU - extended memory management unit, so again - unpopulated for 65xe Thanks for the quick answer. I was confused, because the printing on the mobo says "130XE" but there are only two memory chips (on "atari130xe4bit.jpg") I checked the crystal and it is a 14.18 one. Thanks again! Quote Share this post Link to post Share on other sites
jvas #136 Posted February 6, 2010 Here is the first VBXE from Hungary: And the new monitor connector: And here is my first computer, where everything has started: Quote Share this post Link to post Share on other sites
spookt #137 Posted February 8, 2010 OK, slightly daft, slighty O/T question... I've noticed a lot of the VBXE installs in this thread using nice small black connectors to connect wires to the headers on the VBXE board. The only place I've ever found these is on the case fittings of old PCs (power switch, LED, USB ports, etc). Does anyone know where they can be bought or have a part number or even just he correct name for them? I've searched around a couple of on line component stores but I'm shooting in the dark and having no luck. I'd love to get hold of a supply for a couple of upgrades sitting on my shelf and I'm running out of old PCs to cut up! Quote Share this post Link to post Share on other sites
+bob1200xl #138 Posted February 8, 2010 They are often just called connector housings. Don't know about the other side of the Pond, but Jameco has them over here. (lots of places probably do) Bob OK, slightly daft, slighty O/T question... I've noticed a lot of the VBXE installs in this thread using nice small black connectors to connect wires to the headers on the VBXE board. The only place I've ever found these is on the case fittings of old PCs (power switch, LED, USB ports, etc). Does anyone know where they can be bought or have a part number or even just he correct name for them? I've searched around a couple of on line component stores but I'm shooting in the dark and having no luck. I'd love to get hold of a supply for a couple of upgrades sitting on my shelf and I'm running out of old PCs to cut up! Quote Share this post Link to post Share on other sites
spookt #139 Posted February 8, 2010 (edited) They are often just called connector housings. Don't know about the other side of the Pond, but Jameco has them over here. (lots of places probably do) Bob Thanks Bob, 'connector housings' turned out to be the key! I found them here on RS. I assume I should be able to find them elsewhere now I know what I'm looking for I need to order some IC sockets and a few other basics soon so I'll add a selection of these (and the crimp terminals) in. Edited February 8, 2010 by spookt Quote Share this post Link to post Share on other sites
StaxX28 #140 Posted February 13, 2010 Here is my VBXE install : I have to do the RGB output to see if everything works... Quote Share this post Link to post Share on other sites
candle #141 Posted February 13, 2010 Dom, You've formed a coil on that keyboard support, and that lead conducts 14mhz clock line - not the brightest idea under the sun Quote Share this post Link to post Share on other sites
StaxX28 #142 Posted February 13, 2010 ok, I'll remove it ! thanks Quote Share this post Link to post Share on other sites
flashjazzcat #143 Posted February 23, 2010 (edited) Finally got around to reinstating the lagacy output on my VBXE machine today, and adding a second hole in the back of the case for VBXE's DIN 13 plug: I'm happy with the way the icon and label (previously signifying RF output) are preserved. This is how it looks from the inside (not wired up yet): I used a dremel and sanding drum, then finished it by hand with a file. Still room for a couple of Stereo RCA jacks in the middle, and the other end of the case is left clear for I/O stuff. Edited February 23, 2010 by flashjazzcat Quote Share this post Link to post Share on other sites
candle #144 Posted February 23, 2010 tell me Jon did you have to drill it at offset or it was coaxial with previous hole? Quote Share this post Link to post Share on other sites
flashjazzcat #145 Posted February 23, 2010 It was at a vertical offset (because the RF mod hole is low on the case), but the horizontal position is the same (to keep the icon lined up). I used a fine tip marker pen and traced around a coin about 2mm smaller than the desired aperture. Quote Share this post Link to post Share on other sites
candle #146 Posted February 23, 2010 ah according to Atari those holes have 19mm diameter (quoting after SF314 manual) Quote Share this post Link to post Share on other sites
flashjazzcat #147 Posted February 23, 2010 (edited) I used a 5 pence piece, which apparently has an 18mm diameter, so I must have traced closer than I thought. Can't believe my nerves held long enough to take a drill to a mint 130XE! Edited February 23, 2010 by flashjazzcat Quote Share this post Link to post Share on other sites
+bf2k+ #148 Posted February 24, 2010 Finally got around to reinstating the lagacy output on my VBXE machine today, and adding a second hole in the back of the case for VBXE's DIN 13 plug: I'm happy with the way the icon and label (previously signifying RF output) are preserved. This is how it looks from the inside (not wired up yet): I used a dremel and sanding drum, then finished it by hand with a file. Still room for a couple of Stereo RCA jacks in the middle, and the other end of the case is left clear for I/O stuff. Looking at the socket mounting to the board, is it just glued or attached in some other fashion? Quote Share this post Link to post Share on other sites
flashjazzcat #149 Posted February 25, 2010 Looking at the socket mounting to the board, is it just glued or attached in some other fashion? Just glued unfortunately: I'd wanted to solder it in right way up in holes drilled in the board, but I don't have the equipment to tin the holes, etc. It's fairly sturdy as is. If it ever comes off, I'll just glue it back in. Quote Share this post Link to post Share on other sites
candle #150 Posted February 25, 2010 fjc - nobody has, thing is you just leave them unplated Quote Share this post Link to post Share on other sites
