Sign in to follow this
Mot
Help: What glue 4 label reattachment?
My Centipede cart’s end label fell off :sad: and I need to know from you knowledgeable people what glue is best to put it back on? Thanks.
Mine came with a package of sticky tack. I attached a Spider-Man label back to it's Parker Bros. cartridge this way and it worked like a charm :D
I've been using rubber cement. Will I come to regret it down the road?
I'd say yes. Past experience with rubber cement has shown me that although it may appear "clean" when you attach it, the glue seeps through paper material later on. I found this out in college when I was glueing homemade labels to the jewel cases of promo CD's; when you looked at them in the light later on you could already see a form of "actiplaque" at work. That's why after the discussion we had on RGVC about this subject, plus my own personal experience since then, I only use the glue stick to reaffix labels.
Does anyone know what type of glue was used to attach those Activision labels and why they plaqued so badly? I've always wondered, but never did any research...
I've used 3M Super 77 glue to attach many labels and it works quite well. I suggest cleaning the cart surface with something like Goo Gone first, so the label will stick better. Then you flip the label over, spray the glue on the back side, let it sit for several seconds, and then apply it to the cart. Works great, but can be messy. I've also used glue sticks, but I don't think those bond quite as well as the Super 77.
..Al
Just a quick addendum to Albert's post. If you use 3M spray glue, do it in a well ventilated area. We used to use it in an art class and some people had nasty asthma like reactions to it.
I've been using something called Lineco pH Neutral Glue. Works well, and supposed to be archivally sound. It's made for book binding.
Glue sticks work great. I've been using them (various brands) for quite a while on end labels without any problems. If you're really concerned, you can go searching for specific types of glue, but if you've got a glue stick around, give it a shot.
--Zero
Just lick the back of it and put it back on :D :ponder:
Garak
My kid has glue stick but this seems like it would never hold. Is there better kinds or are they all about the same?
