Sign in to follow this
Larry
Some questions about SDX
The SDX manual says that "Whenever SpartaDos is re-initialized (i.e. RESET) the default directory is set to the MAIN (root) directory."
I'm using 4.42, and when I press RESET, I go back to the same location where I was. If I'm in D5:TOOLS and press RESET, then I am still in D5:TOOLS -- not D5: (MAIN).
I ran into this because when I CHDIR>TOOLS, then I can't get back to D5: (MAIN). I've had trouble with this before, but I don't remember the way home... It's probably quite simple, but I can't find it in the manual.
Thanks,
Larry
Thanks,
Larry
cd > will put you in the MAIN (or root) dir
cd < will back you up 1 dir
Yes, from my MS-Dos days, that's what I thought. But I kept getting "150 Path not found".
But your post made me look at the command -- evidently there's got to be a space in there CD > (not) CD> Ahhhh!
Thanks, Cabell. I'm sure I'll have more questions.
Thanks,
Larry
I cannot find this information in the 4.42 manual http://www.goodbytexl.homepage.t-online.de/Manual%20V4-42_Rev_1b.pdf
Sure, 4.40 and later versions do not reset the paths, as it was annoying in the case when a program (e.g. The Music ProTracker) called the warm reset routine after its execution.
Maybe because this information is missing from the old (4.20) manual. I remember that I was in this same problem once, when I was a SDX beginner... In the 4.42 manual it is page 14.
Hi Konrad-
Thanks for the info, and I just sent you a PM about some other stuff. But the RESET info is in the 4.42 manual (.pdf) page 44. Pretty much verbatim from the original manual.
edit/update: I see the 1B and this is different that the 4.42 manual that I was looking at:
http://sdx.atari8.info/sdx_files/4.42/Manual%20V4-42.pdf
-Larry
Edited by Larry
