Videogamecollector123 #1 Posted December 9, 2009 Hi, I bought a power glove earlier this year, and there is a problem with it. When I got it and I plugged the sensors in the first time it worked fine(fine as you can get with it) after I wiggled the wires on the sensors around primarily the elbow one in the top right corner going to the top left corner wire. Anyway after that I tried it again and when I plugged the sensors in, the led on the NES dimmed and the screen went to static. I'm guessing that wire is the problem and needs replacement, if anyone thinks they can help me and needs pictures, I'll provide them. Quote Share this post Link to post Share on other sites
iswitt #2 Posted December 9, 2009 Honestly I would just leave well enough alone. That abomination does not deserve to be see usage. Unless of course you really want to beat Top Gun, which in that case I would understand. Quote Share this post Link to post Share on other sites
Videogamecollector123 #3 Posted December 9, 2009 really I feel that everything should be fixed, also I've used my friends functinal one and it works really well for Rad Racer. Quote Share this post Link to post Share on other sites
Cebus Capucinis #4 Posted December 9, 2009 (edited) Hi, I bought a power glove earlier this year Found your problem right there. Sounds like a short in the wire, though. Good luck, it's got to be really tough to work on wiring in one of those without actually destroying it. You can't work on the 'power' part without hurting the 'glove' part! Edited December 9, 2009 by CebusCapucinis Quote Share this post Link to post Share on other sites
