Tupin #1 Posted December 17, 2009 I just got a 1040STf and an SC1224 off of Craigslist. It however, did not come with the cable to connect it to the ST, my version of the SC1224 doesn't have the cable built in. I cannot seem to find a direct 13 pin-13 pin cable, anyone have any advice? Quote Share this post Link to post Share on other sites
+Mitch #2 Posted December 18, 2009 That's too bad. I think only one of the three SC1224 models actually has a detachable cable too. Best Electronics should have one in stock. Probably B&C has it as well. Mitch Quote Share this post Link to post Share on other sites
+Stephen #3 Posted December 18, 2009 I just got a 1040STf and an SC1224 off of Craigslist. It however, did not come with the cable to connect it to the ST, my version of the SC1224 doesn't have the cable built in. I cannot seem to find a direct 13 pin-13 pin cable, anyone have any advice? Ends are available if you feel like building your own. I typically buy a cheap VGA extension cable, cut the ends, and wire up the DIN-13s. It's somewhat tedious, as the pics are very closely spaced. If you don't want to to this, the ends are the same as used by Kenwood car stereo equipment for hooking up CD changers and Sirius/XM receivers. Those cables tend to be insanely long and rather expensive though. Stephen Anderson 1 Quote Share this post Link to post Share on other sites
Tupin #4 Posted December 18, 2009 (edited) I just got a 1040STf and an SC1224 off of Craigslist. It however, did not come with the cable to connect it to the ST, my version of the SC1224 doesn't have the cable built in. I cannot seem to find a direct 13 pin-13 pin cable, anyone have any advice? Ends are available if you feel like building your own. I typically buy a cheap VGA extension cable, cut the ends, and wire up the DIN-13s. It's somewhat tedious, as the pics are very closely spaced. If you don't want to to this, the ends are the same as used by Kenwood car stereo equipment for hooking up CD changers and Sirius/XM receivers. Those cables tend to be insanely long and rather expensive though. Stephen Anderson Just my luck that I get a model that doesn't have the cable built in. At least it came with 95 disks and an ICD FA-ST. Edited December 18, 2009 by Tupin Quote Share this post Link to post Share on other sites
tjlazer #5 Posted December 19, 2009 (edited) I just got a 1040STf and an SC1224 off of Craigslist. It however, did not come with the cable to connect it to the ST, my version of the SC1224 doesn't have the cable built in. I cannot seem to find a direct 13 pin-13 pin cable, anyone have any advice? Ends are available if you feel like building your own. I typically buy a cheap VGA extension cable, cut the ends, and wire up the DIN-13s. It's somewhat tedious, as the pics are very closely spaced. If you don't want to to this, the ends are the same as used by Kenwood car stereo equipment for hooking up CD changers and Sirius/XM receivers. Those cables tend to be insanely long and rather expensive though. Stephen Anderson Just my luck that I get a model that doesn't have the cable built in. At least it came with 95 disks and an ICD FA-ST. Just buy a cable from Best or B&C? Yes they are going to cost you around $30 but it is what it is my retro friend! You have no idea how many times I have had to do that over the years between my C= and Atari collections! Edited December 19, 2009 by tjlazer Quote Share this post Link to post Share on other sites
Tupin #6 Posted December 20, 2009 Got the cable. It works, but the mouse is iffy because it had no mouse ball and I had to replace it with one from a Mac. The place where you put it is so deep, I could only imagine it's a special kind of ball. Quote Share this post Link to post Share on other sites
