tz101 #1 Posted December 20, 2009 Anyone know how this might be done? I have priced the jag component cables on Ebay and don't particularly care for the high prices plus exorbitant shipping costs. A donor RCA cable would work for one end, but I would need the correct plug to connect to the console. Also, pinouts from the AV out port on the Jag would probably be a necessity. Any ideas? Quote Share this post Link to post Share on other sites
minux #2 Posted December 20, 2009 Anyone know how this might be done? I have priced the jag component cables on Ebay and don't particularly care for the high prices plus exorbitant shipping costs. A donor RCA cable would work for one end, but I would need the correct plug to connect to the console. Also, pinouts from the AV out port on the Jag would probably be a necessity. Any ideas? Not too hard of an endeavour, here are the correct pin outs for the Jaguar: http://pinouts.ru/Video/AtariJaguarAV_pinout.shtml As for as the Video Edge Connection port, the modern replacement for the connection has a DigiKey p/n of S3304-ND and can still be orderd from the following link: http://www.digikey.com/scripts/dksearch/dksus.dll?Detail&name=S3304-ND The other option, which I think is easier to do is to open up the Jaguar, solder the actual pins, run the wires to the back of the case, drill the case and place a/v connectors to your line, then you wont have to ever worry about loosing your a/v cable. With the way my brain works, it's easier for me to do this than make cable. I've never been good at that, really. Too many bad experiences with cheap crimpers . Quote Share this post Link to post Share on other sites
Paolo #3 Posted December 20, 2009 Also, if you look around the forum, you'll find that some of us already did it by ourselves, and explained a few things. Quote Share this post Link to post Share on other sites
tz101 #4 Posted December 23, 2009 The other option, which I think is easier to do is to open up the Jaguar, solder the actual pins, run the wires to the back of the case, drill the case and place a/v connectors to your line, then you wont have to ever worry about loosing your a/v cable. With the way my brain works, it's easier for me to do this than make cable. I've never been good at that, really. Too many bad experiences with cheap crimpers . I like this option. Would anyone have pics of their actual solder job, as far as where on the main board to connect my wires to the RCA output jacks? Quote Share this post Link to post Share on other sites
