andym00 #1 Posted January 1, 2010 The first numbnuts question of the year If I was to pick up an XEGS, just because I think they look so cute with the coloured buttons and the diddy keyboard, can I use it like a regular XE hooked up via SIO2PC ? And also, would a FlashMax cart work on it without any problems ? I'm guessing the FlashMax won't be an issue, but the SIO stuff I'm not sure about at all because I can't get the internet to tell me the answer for sure It's got an SIO port yes, and I'm guessing that means the answer is a yes, but still not 100% sure, so I thought I'd ask before I buy a white elephant.. And are there any other compatibility issues that would make it not worth bothering ? I mean it's just a 65XE underneath the cute colours and keyboard cable ? Or not ? Quote Share this post Link to post Share on other sites
Rybags #2 Posted January 1, 2010 XEGS is essentially an early 65XE, ie normal SIO, no ECI. Apart from the obvious differences though, it has 2 4 bit RAM chips (early XEs use 8 or 16 x 1 bit chips), and the keyboard contains the 2 multiplexor ICs that are normally on the motherboard. Unsure about the pesky caps/resistors that some XEs had to reduce RF noise, although they're supposedly only on NTSC machines anyway. Also, I'm fairly sure that most/all XEGS machines use the earlier Antic which won't necessarily provide the proper Refresh rows for most RAM expansions. Quote Share this post Link to post Share on other sites
andym00 #3 Posted January 1, 2010 XEGS is essentially an early 65XE, ie normal SIO, no ECI. Apart from the obvious differences though, it has 2 4 bit RAM chips (early XEs use 8 or 16 x 1 bit chips), and the keyboard contains the 2 multiplexor ICs that are normally on the motherboard. Unsure about the pesky caps/resistors that some XEs had to reduce RF noise, although they're supposedly only on NTSC machines anyway. Also, I'm fairly sure that most/all XEGS machines use the earlier Antic which won't necessarily provide the proper Refresh rows for most RAM expansions. Ta very much I shall go grab this puppy as soon as possible then.. I wouldn't be intending to expand the RAM on it and would want to keep it stock, but I just fancy it for developing on and like the idea of the external keyboard for making desktop real-estate more manageable.. Plus.. The cuteness is a slightly overwhelming factor as well, though that might just be the hangover Quote Share this post Link to post Share on other sites
doctor_x #4 Posted January 1, 2010 I've always loved the XEGS as well and seriously hope one I am watching ends up in my hands - but I cannot deny that the thing just SCREAMS that it needs a "hello kitty" sticker slapped on the main box.. XEGS is essentially an early 65XE, ie normal SIO, no ECI. Apart from the obvious differences though, it has 2 4 bit RAM chips (early XEs use 8 or 16 x 1 bit chips), and the keyboard contains the 2 multiplexor ICs that are normally on the motherboard. Unsure about the pesky caps/resistors that some XEs had to reduce RF noise, although they're supposedly only on NTSC machines anyway. Also, I'm fairly sure that most/all XEGS machines use the earlier Antic which won't necessarily provide the proper Refresh rows for most RAM expansions. Ta very much I shall go grab this puppy as soon as possible then.. I wouldn't be intending to expand the RAM on it and would want to keep it stock, but I just fancy it for developing on and like the idea of the external keyboard for making desktop real-estate more manageable.. Plus.. The cuteness is a slightly overwhelming factor as well, though that might just be the hangover Quote Share this post Link to post Share on other sites
Shawn Jefferson #5 Posted January 1, 2010 Those pastels from the 80s.... ugh. That's one of the models I don't have yet though (that and a 600XL), so I wouldn't turn one down if I stumbled upon it. Quote Share this post Link to post Share on other sites
