Larry
Backing up "Big Sectors?"
I have always used APE to make backup images of my HD partitions. But now using 512-byte sectors, that poses a problem, since APE currently only supports 256-byte sectors. It seems like the easiest work-around is to split the 512-byte sectors and then just write a new "double-sized" image. Then of course, using the reverse when restoring a partition to the HD.
But before I do this, does anyone already have a utility that does it, or perhaps can think of a different/better way?
I can think of one -- since (IIRC) the KMK-JZ interface supports a master and slave IDE device, one could backup the HD partitions to a separate Compact Flash card. However, I have been using my MIO, so that would not be a good solution for me.
-Larry
-Larry
Did I miss something?
Which (Native) Atari Filesystem does support 512 byes/sector?
You might want to use a recursive file copier? In SpartaDos there is a tool called HardBack, but that is slower ofourse than a sector copy.
I know my BlackBox supports 512 bytes/sector, but that is only on HARDWARE level. In SpartaDOS/MyDOS the maximum amount of bytes/sector is 256, so sector copy to ape simply works.
Good luck,
Marius
SDX 4.42 and above.
You can use SDX COPY /R command to backup the 512 b/s partitions to 256 b/s images - that's what I do.
Good luck,
Marius
The new Sparta Dos X has 512-byte sector support.
Stephen Anderson
Hi Marius and Bf2k+
I've never used COPY/R, so wasn't aware that Copy/R would back up 512-byte sectors to 256-byte sectors. I'll have to try that and see how it works for me.
As to Native File Systems that support 512-byte sectors, SDX is the first...
-Larry
You might want to use a recursive file copier? In SpartaDos there is a tool called HardBack, but that is slower of course than a sector copy.
Good luck,
Marius
Yes... Copy/r is a recursive file copier - > COPY /R D1: D2: will copy everything on the D1: to D2: - It doesn't care about the sector density.
There is also TAR archiver, I use it regularly for backups (TAR all the files to form a long file, then copy that file onto a PC via SIO2PC - and TAR is a standard Unix format so that it is easy to unpack that everywhere).
http://drac030.krap.pl/en-sparta-pliki.php
4 years. SDX 4.39RC, the first version to support file systems with 512 bytes per sector, was released in 2005.
Edited by drac030
Oops....
I did not know that indeed. I'm only using SpartaDOS disk versions.
And for backup I'm using the HARDBACK tool. It's a very nice tool.
Do I need to upload it here?
Or does anyone know what tool it is?
Greetz
Marius
Oops....
Greetz
Marius
I was a Hardback beta tester... way back in 1985? (or thereabouts). I use it for all my sd 3.x 256 b/s backups. I also wrote an Antic Review of it (December 1985 I think - I have the issue around here somewhere.)
More generally, programs accessing files and directories cleanly (i.e. via the CIO interface) should see no difference between old and new SpartaDOS regardless of the sector size. Example: old ICD's SORTDIR (from the Toolkit) which works perfectly under new SpartaDOS 4.42 and on a 32 MB disk. Of course, CAR:SORTDIR.COM is better (shorter, faster, has bigger buffer for a directory).
All my old HDTOOLS worked perfectly with SDX 4.4x with no mods. I have since made a few mods to them (such as adding 512byte support to the ScanDISK program).
However HARDBACK (an Orion program) locks up when I try to run it under SDX.
Hi Larry,
You can also try AspeQt if you have a standard Sio2Pc cable and you're adventurous :) Version 0.3 supports 512 bytes/sector ATR images but it's poorly tested.
Edited by cyco130
Hi Cyco130-
I normally use my USB, but I'll hook up one of my serial interfaces and give it a try! Fortunately, my DIY PC still has serial and parallel ports.
Thanks,
Larry
Hi Larry,
Hi Larry,
Or Atari810 from Dan Vernon, if you like it a bit more old-fashioned ;-)
