Skaarg Posted January 23, 2010 Share Posted January 23, 2010 When I first got my ADAM around a year ago the first thing I got was an Expansion Module #1 considering it was cheaper than a 2600 (of course that's different now). Well shortly after this I found a very nice supercharger set with the first 5 games. Well it just so happens because of the Supercharger cart getting wider as it extends out it does not fit in the Expansion Module #1. I'm just curious if there are any other 2600 carts or items that will not work with the Expansion Module #1 due to physical complications or compatibility issues. Quote Link to comment Share on other sites More sharing options...
oldjd Posted January 23, 2010 Share Posted January 23, 2010 When I first got my ADAM around a year ago the first thing I got was an Expansion Module #1 considering it was cheaper than a 2600 (of course that's different now). Well shortly after this I found a very nice supercharger set with the first 5 games. Well it just so happens because of the Supercharger cart getting wider as it extends out it does not fit in the Expansion Module #1. I'm just curious if there are any other 2600 carts or items that will not work with the Expansion Module #1 due to physical complications or compatibility issues. I havent run into any,but sometimes the case can be a bit warped and will be difficult to get it in. I have had that happen on the 2600 console If I recall correctly the supercharger is a lot longer the a conventional 2600 game case,andas you noted it tapers,which is why it wont fit right. Also make sure there isnt any garbage in the slot.or on the supercharger that would bind it up Quote Link to comment Share on other sites More sharing options...
ed1475 Posted January 23, 2010 Share Posted January 23, 2010 (edited) I've read somewhere that Supercharger games work but you have to open up the Exp Mod #1 and remove the cover so the Supercharger will fit. I only own about 20 Atari games and the only one that I have that doesn't work right with the Exp Mod #1 is Real Sports Boxing. The game plays but the scores for the boxers are mixed up. Edited January 23, 2010 by ed1475 Quote Link to comment Share on other sites More sharing options...
lhfreak Posted February 4, 2010 Share Posted February 4, 2010 When I first got my ADAM around a year ago the first thing I got was an Expansion Module #1 considering it was cheaper than a 2600 (of course that's different now). Well shortly after this I found a very nice supercharger set with the first 5 games. Well it just so happens because of the Supercharger cart getting wider as it extends out it does not fit in the Expansion Module #1. I'm just curious if there are any other 2600 carts or items that will not work with the Expansion Module #1 due to physical complications or compatibility issues. I found this out when I got the module back in the day....So I sanded down the supercharger to get it to fit. I think I read about that in some magazine. So I tried it and it worked Quote Link to comment Share on other sites More sharing options...
RangerG Posted February 4, 2010 Share Posted February 4, 2010 1) How well does the expansion module play through the Adam? 2) Would the Harmony work in the expansion module? Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted February 4, 2010 Share Posted February 4, 2010 1) How well does the expansion module play through the Adam? 2) Would the Harmony work in the expansion module? I remember using my Expansion Module #1 with my ADAM when I was a kid, and I never had any problem with it. I can't answer your second question, sorry. Quote Link to comment Share on other sites More sharing options...
colecomaniac Posted February 17, 2010 Share Posted February 17, 2010 When I first got my ADAM around a year ago the first thing I got was an Expansion Module #1 considering it was cheaper than a 2600 (of course that's different now). Well shortly after this I found a very nice supercharger set with the first 5 games. Well it just so happens because of the Supercharger cart getting wider as it extends out it does not fit in the Expansion Module #1. I'm just curious if there are any other 2600 carts or items that will not work with the Expansion Module #1 due to physical complications or compatibility issues. Coleco must have been aware of the problem. They produced a cartridge slot extender that plugs right into the Expansion Module #1. http://www.atariage.com/forums/topic/140126-the-official-coleco-adam-topic/page__p__1697043#entry1697043 One issue that I have experienced with Exp #1 is that if you use it on a stand alone Adam that is connected to a monitor via A/V connection: The picture is crisp, but for some strange reason, the audio is muffled so badly that it ruins the gaming experience. Quote Link to comment Share on other sites More sharing options...
