SegaShooters Posted January 23, 2010 Share Posted January 23, 2010 Would anyone have the complete specs for both the original ColecoVision black system and the Grey Adam Game Console power supples? I've tried looking around the web and haven't found much. Thanks. Quote Link to comment Share on other sites More sharing options...
Rik Posted January 24, 2010 Share Posted January 24, 2010 Don't know about the Adam,but here's the power supply specs for the Colecovision Input: 120V AC-60 Hz .25A OUTPUT:PIN 1 +5 VDC .9A PIN 2 -5 VDC .1A PIN 3 +12 VDC .3A PIN 4 GROUND Quote Link to comment Share on other sites More sharing options...
desiv Posted January 24, 2010 Share Posted January 24, 2010 Would anyone have the complete specs for both the original ColecoVision black system and the Grey Adam Game Console power supples? I've tried looking around the web and haven't found much. Thanks. Coleco ADAM -- 1 Brown +12V 2 Red +12V 3 Orng +5V 4 Yell -5V 5 Green GND 6 Blue ADAMNet 7 Violet Reset 8 -- Drain 9 -- No Wire "Basically for a PC power supply, you have to use the top row of pins on the DB-9 connector. The others you can ignore. The ADAM is smart enough to tell if a printer is attached or not." *Geoff!* From: http://webspace.webring.com/people/vc/chrispepin/voltages.txt desiv Quote Link to comment Share on other sites More sharing options...
