+SpiceWare #26 Posted April 24, 2010 We're wrapping up the documentation and initial demo, it should be released tomorrow (as I'm joining some friends to go to the Texas Crawfish and Music Festival later today). The initial demo will cover all of the Harmony functions with the exception of calling a User written ARM subroutine (it was added just a few days ago and I've not had time to write something for it). The initial demo consists of 6 examples (one per bank) that highlight specific features of DPC+. The 2nd example shows off the DPC+ music support, which is quite a bit better than DPC. DPC was limited to square waves, DPC+ lets you create your own sound waves. The wave example includes: Square Waves Sine Waves Sawtooth and more! The 6th example uses a 2 line kernel and does 29 TIA updates over those 2 lines. This allows both sprites to be multicolored, display both missiles & the ball, an asymmetrical play field and both the play field color and the background color changed on every scan line. 2 Quote Share this post Link to post Share on other sites
grafixbmp #27 Posted April 24, 2010 That is so cool, I about wet myself. Quote Share this post Link to post Share on other sites
flammingcowz #28 Posted April 26, 2010 is the initial demo done yet? Quote Share this post Link to post Share on other sites
+SpiceWare #29 Posted April 26, 2010 The demo is, the documentation on how to get it onto the Harmony Cart isn't. I suspect, but don't know for sure, that batari wants to get the next BIOS in place to make that easier than it is now - "changes needed for a new release are to add multicart support for DPC+". If you'd like to see it in action via Stella 3.1, here it is: DPCplus.bin Please note, this file will not work on the Harmony Cartridge. Use GAME SELECT to cycle thru the 6 demos Demo 0: Data Fetcher Demo - draws and colors a sprite in 14 cycles. Use joystick to move, fire button to change shape. Demo 1: Music Demo - Left joystick can silence voices (using FIre, Right and Down). Right joystick changes waveforms (all directions + fire) Demo 2: Fractional Data Fetcher Demo - joystick up/down controls fractional increment. Demo 3: Random Number Demo - displays the 32 bit random number. Right to advance values, Left to go back to prior values, Fire to reset to initial value. Demo 4: Data Write Demo - shows how to write into the 4K Display Data Bank. It masks the sprite to make it go smoothly on/off the screen (ie: it doesn't wrap like in Demo 0). Hit FIRE to flip image, this shows difference between Write and Push. Demo 5: Fast Fetch Demo - enables special mode where it takes only 2 cycles to read DPC+ registers, which allows for 29 TIA updates over 2 scan lines. Left and Right joysticks move helicopters. Quote Share this post Link to post Share on other sites
+batari #30 Posted April 26, 2010 The demo is, the documentation on how to get it onto the Harmony Cart isn't. I suspect, but don't know for sure, that batari wants to get the next BIOS in place to make that easier than it is now - "changes needed for a new release are to add multicart support for DPC+". If you'd like to see it in action via Stella 3.1, here it is: DPCplus.bin Please note, this file will not work on the Harmony Cartridge. Well, it's worth mentioning that we can post a demo that does work on Harmony, but it must be loaded directly to the Harmony's memory to try it, which will overwrite the multicart BIOS. The multicart BIOS can be reloaded after trying the demo but some (or all) may not wish to do this. If anyone wants to see the demo on real hardware and doesn't mind reflashing their Harmony BIOS afterward, we can post a version that will work and instructions on how to upload it. Quote Share this post Link to post Share on other sites
flammingcowz #31 Posted April 26, 2010 i'd like to see it on the harmony cart Quote Share this post Link to post Share on other sites
+SpiceWare #32 Posted April 27, 2010 (edited) Harmony ready binary Harmony.bin To send it to the Harmony, plug you Harmony into your computer and run the Harmony Cart program. On the BIOS Update tab you're going to do only Step 1. Click the ... button to select the Harmony.bin file, then click the Download EEPROM button. Once the download's complete unplug your Harmony Cart and put it into your Atari. To restore the menu, use the same process as above, but select the appropriate eeloader file for your system (NTSC, PAL50 or PAL60) Edited April 27, 2010 by SpiceWare Quote Share this post Link to post Share on other sites
flammingcowz #33 Posted April 27, 2010 wow that was cool to see run on my atari, thanks for posting Quote Share this post Link to post Share on other sites
Pioneer4x4 #34 Posted April 27, 2010 I'm looking forward to trying this on mine also! Quote Share this post Link to post Share on other sites
+SpiceWare #35 Posted April 30, 2010 (edited) Progress so far on the ARM demo. 96x200 bitmap display being updated at 60 fps. The display is cleared during Over Scan and all the lines are calculated on the fly and plotted during Vertical Blank. http://www.youtube.com/watch?v=QNkvn3_rnXU The values at the bottom are the time remaining at the end of Vertical Blank and Over Scan. Hit the FireButton for more lines, but the screen will jitter as the code takes a tad too long to run in Vertical Blank. Harmony ready binary, follow instructions in Post 32 Harmony.bin Edited April 30, 2010 by SpiceWare Quote Share this post Link to post Share on other sites
+SpiceWare #36 Posted April 30, 2010 Improved verison. In the prior video you can see B-F time remaining (11-15 in decimal) in Vertical Blank. I was able to speed up the routines so 11-14 (17-20 in decimal) time is remaining. It's now fast enough that it doesn't jitter if you hit Fire to double the number of lines. I also changed it so you control the rotation using left/right. Harmony.bin Quote Share this post Link to post Share on other sites
+SpiceWare #37 Posted May 2, 2010 We're testing preliminary support for custom bank switching in Multi Cart Mode. http://www.youtube.com/watch?v=kxyU4cDEerk There's still a couple issues we need to track down before it can be released. We've also made changes to Stella so it will support both 29K and 32K DPC+ bin files, so you will only have to create 1 bin for distribution instead of separate "Stella" and "Harmony" bins. This will be available when Stella 3.1.2 is released. Quote Share this post Link to post Share on other sites
Orion_ #38 Posted May 8, 2010 awesome news & demo ! I can't wait to try some arm code on harmony Quote Share this post Link to post Share on other sites
+SpiceWare #39 Posted May 10, 2010 3D rotating cube at 60 fps. There's an odd perspective I need to track down, but the rotations appear to be working correctly. http://www.youtube.com/watch?v=wIrbCsqQEi8 Quote Share this post Link to post Share on other sites
Pioneer4x4 #40 Posted May 10, 2010 3D rotating cube at 60 fps. There's an odd perspective I need to track down, but the rotations appear to be working correctly. http://www.youtube.com/watch?v=wIrbCsqQEi8 WOW, that is only a few lines of code away from Castle Wolfenstein! Seriously though, that is very cool! Quote Share this post Link to post Share on other sites
rpgfaker #41 Posted May 13, 2010 *jaw hits the floor* Damn! Looks great. Quote Share this post Link to post Share on other sites
+SpiceWare #42 Posted May 13, 2010 Thanks! My folks are currently visiting from Trinidad, so there won't be anything new to show for at least a week. Batari's still working out stuff with the new BIOS. Sorry this is taking longer than expected to this stuff released to y'all, but "real life" does take priority Quote Share this post Link to post Share on other sites
