Sign in to follow this
bongomeno
Dial up BBS
Are there any left that I can access on my Atari? I plan on using my ST to do this, but I also have a 16k 400 and a beat up 800xl...
Edited by bongomeno
yeah, I found that. Its too bad that none of them are for Atari computers. :(
I did go to Empire of the Dragon, it was pretty cool.
What I do is dial into the prison board bbs and fron the main menu select (x)internet menu,then select (a)for all of the atari bbs,it works for me,I,m using 800xl with pr:connection and 2400 supramodem.
whats the prison board BBS?
btw, Im actually working nowon progrmaming my own dial up BBS in QBASIC. Ill let you all know if I can get it working./..
Prison Board bbs 1-972-329-0781 Mesquite, TX
hit me with pm when you get board up and running and i will cal in.
Many BBS's that were dial-up switched over to telnet at some point as well. My only problem is the software that I remember could handle telnet on my 8-bit XL, DOES NOT work in any 8-bit Atari computer emulator... (yet.)
If I could host a telnet-able BBS through an Atari 8-bit computer emulator, I would.
Try 'BBS on a Stick' - bf.amfband.com - contains everything you need to run 8-bit BBS on emulator.
