hobojoe44 Posted February 18, 2010 Share Posted February 18, 2010 I picked up a Gemini controller for a few $ the other day. I wanted to find a guide (if there is any) before I open it up. Quote Link to comment Share on other sites More sharing options...
coleconut Posted February 18, 2010 Share Posted February 18, 2010 I picked up a Gemini controller for a few $ the other day. I wanted to find a guide (if there is any) before I open it up. As luck would have it I just opened up about 6 of them for the first time and I found that cleaning them (if that was your goal) was relatively simple. The hardest part about some of these jobs is often the re-assembly but this was relatively simple, there is a little springy thing for the fire button but it is simple dis- and re-assembly. And just swabbing with alcohol resulted in good response and jitter-free paddles. There isnt much you can do to go wrong with this process. My worst knightmare was my Creativision joysticks and I understand Arcadia 2001 joysticks are no treat either. Coleco super action controllers are a little finicky to re-assemble I found. Quote Link to comment Share on other sites More sharing options...
hobojoe44 Posted February 18, 2010 Author Share Posted February 18, 2010 Thanks for the Info I opened it up lastnight to clean it, the damn springy thing flew out from the tension as I opened it. It took me a few mins the figure out where to put the springy thing for when I reassemble it. It's great that you don't need to use pliers to clean the paddle like you do with 2600 paddles. Quote Link to comment Share on other sites More sharing options...
