Sign in to follow this
Heaven/TQA
NTSC check
what is the most effective way to check if system is a NTSC or PAL one? really only the GITA/ANTIC flag?
I don't know what you call "GTIA/ANTIC flag" but I use this:
53268 D014 COLPM2
(W) Color and luminance of player and missile 2 (706).
PAL
® Used to determine if the Atari is PAL (European and Israeli
TV compatible when BITs 1 - 3 equal zero) or NTSC (North
American compatible when BITs 1 - 3 equal one; 14 decimal, $E).
European Ataris run 12% slower if tied to the VBLANK cycle (the
PAL VBLANK cycle is every 50th second rather than every 60th
second). They use only one CPU clock at three MHZ, so the 6502
runs at 2.217 MHZ -- 25% faster than North American Ataris.
Also, their $E000 and $F000 ROMs are different, so there are
possible incompatibilities with North American Ataris in the
cassette handling routines. There is a third TV standard called
SECAM, used in France, the USSR, and parts of Africa. I am
unaware if there is any Atari support for SECAM standards.
PAL TV has more scan lines per frame, 312 compared to 262.
NTSC Ataris compensate by adding extra lines at the beginning
of the VBLANK routine. Display lists do not have to be altered,
and colors are the same because of a hardware modification.
F.
53268 D014 COLPM2
PAL
Is this from Mapping the Atari? I like that reference overall, but there are several serious errors in that description.
it's for Gridrunner... need to switch off MSX on NTSC in the intro... ;) the title screen flickers when I am using Miker's RMT title track...
Probably something like:
sei
lda #0
sta nmien
lda #130
wait cmp vcount
bne wait
sta wsync
sta wsync
sta wsync
bit vcount
bmi pal
You could probably get away without disabling interrupts but this way ensures you don't have a longer running VBlank or something like a keypress getting in the way.
VCount wraps around for NTSC after 130, PAL keeps on going until 155.
Use a stop watch.
Turn on the Atari. See if it takes 9.1 minutes or about 11 minutes for screen saver (ATRACT) mode to kick in.
aarg... Jesus... ;)
again...
a simple check in software reading $d014 should be ok as my Atari book tells me?
Yep.
The exception is that for modded machines where people have put the other system's Antic in, that method can be invalid if they retain the original GTIA.
Probably in the dozens :P
But the kind of person who'd do such a mod would be your hardcore owner/collector/modder anyway, who in all likelihood has at least one other machine that is at default configuration insofar as factory spec Antic/GTIA/master clock.
aarg... Jesus... ;)
again...
You can use my method in all cases and you can do it manually with a stop watch or through a programmed stop watch in a high level language or a low level language. Many high level languages have the time$ variable to return time and you can use that as a stop watch. They usually return "hh:mm:ss" so if you did Right$(time$,2) and peek(77) or peek(19) and count # of seconds that elapse while those locations change say from initial count C to final count C+5, you would be able to tell the frame rate of the machine without a single ASM instruction.
Note: watch out for wrap around of the seconds and location 19 or 77.
I really don't think you want a user to wait around after running something before it'll continue with or without music, especially not 9-11 mins. If it can be done in a few frames/1 second fair enough but you also don't want any user interaction.
Heaven, just bring up a screen advising people to go make a coffee and some toast and when they come back press a key if they want PAL or NTSC ;)
Pete
or compile 2 different versions... ;) PAL and NTSC version of Gridrunner... ;) why making simple things complicated... ;) at least RMT does now have consistent playback speed across the systems...
Be careful with that consistent playback speed, afaik one of them will run at a % of a full frame time so you won't know when it's going to hit (unlike running it from VBL). Make sure your interrupts have priority else bad things will happen. ;)
Pete
Indeed...Jesus. It doesn't have to be complicated guys. In case of a standard machine, the PAL-flag in the GTIA-registers is enough. Otherwise, in case of a HW-mod, you could leave the option in the main game menu to manually switch to PAL or NTSC. But, possibly making separate PAL- and NTSC-versions is the easiest. Anyway, if that's the only difference, turning music on or off depending on PAL or NTSC, then it's easiest to do the PAL-flag test. If I'm correct, RMT-player already does that, to correct its execution timescheme.
OK, but I suppose Heaven's question was aimed at the context of which testing method to use, which is possible to do by the hardware itself. Then testing vcount is a nice and easy one, as it really tests whether we are dealing with a PAL or NTSC Antic.
I was taking into account any programming language or platform. Code is actually quite simple if you make it specific to Atari. Here's some code for Atari BASIC to determine PAL/NTSC/other stuff:
10 T=0: REM SIMULATE TIME FUNCTION RELATIVELY FOR ATARI
20 P=PEEK(19)
30 IF P=PEEK(19) THEN 30
40 P=PEEK(19)
50 IF P=PEEK(19) THEN T=T+1:GOTO 50
60 IF T>512 THEN GOTO 100: REM PAL
70 ? "NTSC":END
100 IF T>800 THEN ?"YOU CHEATER, YOU USED AN ACCELERATOR!":END
110 ?"PAL"
I assumed you are running in Gr.0 or Gr. 8/9/10/11. You can compute a different cut-off T value for other modes.
It's slower than using VCOUNT because I'm making it work with high level languages, but it's definitely simpler.
QED.
Here is how you detect the difference from a pal from NTSC in assembler.
Enjoy Steve
;checking for pal/ntsc machines
pal_ntsc
lda $d014
ora #$f0 ; masking high order bytes
cmp #$ff ;
beq ntsc
bne pal
rts
ntsc
jsr printsi
dc.b "NTSC Detected! Setting To 60hz",$9B,-1
RTS
pal
jsr printsi
dc.b "PAL Detected! Setting To 50hz",$9B,-1
RTS
; Print text
; out:
; all registers preserved
; notes:
; This print routine will print all characters
; following the JSR PRINT until a delimiter of
; -1 ($FF) is reached. PRINT will return to the
; point one byte beyond the delimiter.
printsi: JSR SAVER
TSX
LDA $0105,X
STA ZOCH+1
LDA $0106,X
STA ZOCH+2
ldy #1
ZOCH: LDA $FFFF,Y
CMP #$FF
BEQ Zecho
JSR echo
INY
BNE ZOCH
Zecho: TYA
CLC
ADC $0105,X
STA $0105,X
LDA $0106,X
ADC #0
STA $0106,X
JMP RESALL
; SAVE & RESTORE registers
SAVER: PHP
PHA
PHA
PHA
PHP
PHA
TXA
PHA
TSX
LDA $0109,X
STA $0105,X
LDA $0107,X
STA $0109,X
LDA $0101,X
STA $0107,X
LDA $0108,X
STA $0104,X
LDA $0106,X
STA $0108,X
TYA
STA $0106,X
PLA
TAX
PLA
PLP
RTS
RESALL: PLA
TAY
PLA
TAX
PLA
PLP
RTS
Enjoy Steve
pal_ntsc
lda $d014
cmp #$ff ;
beq ntsc
bne pal
rts
ntsc
jsr printsi
RTS
pal
jsr printsi
RTS
; Print text
; out:
; notes:
printsi: JSR SAVER
TSX
LDA $0105,X
STA ZOCH+1
LDA $0106,X
STA ZOCH+2
ldy #1
ZOCH: LDA $FFFF,Y
CMP #$FF
BEQ Zecho
JSR echo
INY
BNE ZOCH
Zecho: TYA
CLC
ADC $0105,X
STA $0105,X
LDA $0106,X
ADC #0
STA $0106,X
JMP RESALL
SAVER: PHP
PHA
PHA
PHA
PHP
PHA
TXA
PHA
TSX
LDA $0109,X
STA $0105,X
LDA $0107,X
STA $0109,X
LDA $0101,X
STA $0107,X
LDA $0108,X
STA $0104,X
LDA $0106,X
STA $0108,X
TYA
STA $0106,X
PLA
TAX
PLA
PLP
RTS
RESALL: PLA
TAY
PLA
TAX
PLA
PLP
RTS
It doesn't work if you have repaired machines and GTIAs have been swapped between pal/ntsc machines. The $d014 doesn't reflect the true state of PAL/NTSC frame rate but is a hardcoded value in the chip.
The question is really, how to detect it, and then, yeah, Hardware flag NTSCPAL ($D014) (AND #$0E eq 0 for PAL, $E for NTSC) is the way to go I guess. Although bootstrap also does some things.
NTSCPAL$ ($0062) is $00 for NTSC, and $01 for PAL, also KEYREPDELY ($02D9) is $30 for NTSC or $28 for PAL, and KEYREP ($02DA) is $06 for NTSC, $05 for PAL. This all assuming of course, normal hardware and standard OS.
53268 D014 COLPM2
PAL
Very true, it took me a lot of figuring aswell though. European (PAL) Atari's actually run slower than the NTSC counterparts. 1.77MHz against 1.79MHz respectively. They just can do more cycles in a VBI because the VBI calls are less frequent.
I'm one of the lucky dutch multilinguists. Combining "Mapping"(en) with "Intern"(de) and the OS reference manual turns up quite a number of discrepancies in Mapping's text.
The "PAL is slower overall" is very debatable (disregarding of course that probably 98% of games use VBlank timings)
DMA overhead Gr. 0 for an NTSC machine =
60 frames * (
262 scanlines * 9 refresh
+ 24 scanlines * 73 (deduct skipped refresh cycles)
+ 168 scanlines * 40
+ 8 (DList stuff, 3 blank, 2 LMS, 3 JVB)
Total = 650,280
DMA overhead Gr. 0 for a PAL machine =
50 frames * (
312 scanlines * 9 refresh
Total = 564,400
Difference = 85,880 less DMA cycles for PAL
Of course, the actual frame rate of both machines isn't 50/60 per second, IIRC it's actually a bit less for both.
But, in many typical screen situations a PAL machine will have more free cycles over a given time period.
Additional to that, having a VBlank NMI 10 less times per second means less cycles lost to OS overhead.
Going back to my original suggestion, surely all that's needed (even for high level languages) is a tiny assembly routine which simply monitors VCOUNT for a couple of frames and returns the highest value the register reached? For example, from BASIC:
    	pla ; remove # args
loop1: lda vcount
   	bne loop1
loop3: lda vcount
   	beq loop3
loop2: lda vcount
   	beq done
   	sta $d4
   	bne loop2
done: lda #0
   	sta $d5
   	rts
This will return either 130 (NTSC) or 155 (PAL), and could be put in a string or a few short data statements.
Edited by flashjazzcat
Just print on screen "Press P for Pal or N for NTSC", let the user decide, they know what they've got and it saves you getting stuck in a situation where your code doesn't quite get it right and there's nothing they can do about it because it's automated.
Pete
