+Philsan #1 Posted March 3, 2010 How may I slow a sprite's animation? player1: PLAYER DEFINITION end drawscreen player1: PLAYER DEFINITION end drawscreen player1: PLAYER DEFINITION end drawscreen player1: PLAYER DEFINITION end drawscreen Quote Share this post Link to post Share on other sites
+Philsan #2 Posted March 3, 2010 Answer found here: http://www.atariage.com/forums/topic/109288-code-snippets-samples-for-bb-beginners/ Quote Share this post Link to post Share on other sites
+Random Terrain #3 Posted March 4, 2010 (edited) You use can use a counter and use if-thens or gosubs or gotos. Here's an example using only if-thens: rem ***************************************************** rem ***************************************************** rem * rem * Animation Example Using Only if-thens rem * rem ***************************************************** rem ***************************************************** rem ***************************************************** rem * rem * Create aliases for variables. rem * rem ***************************************************** dim P0_Anim_Count = a dim P0_Flip = b dim rand16=z rem ***************************************************** rem * rem * Variable descriptions. rem * rem ***************************************************** rem * rem * P0_Anim_Count -- Player 0 animation counter. rem * rem * P0_Flip -- Tells the program which way player 0 should face. rem * rem * rand16 -- This 16-bit random number generator gives you better random numbers. rem ***************************************************** rem * rem * Player 0 sprite position variables. rem * rem ***************************************************** x=80 : y =55 rem ***************************************************** rem * rem * Background color. rem * rem ***************************************************** COLUBK = 0 rem ****************************************************** rem ****************************************************** rem * rem * Main game loop starts here. rem * rem ****************************************************** rem ****************************************************** MainLoop rem ***************************************************** rem * rem * Player 0 sprite color. rem * rem ***************************************************** COLUP0 = 202 rem ***************************************************** rem * rem * Increase Player 0 animation counter. rem * rem ***************************************************** P0_Anim_Count = P0_Anim_Count + 1 rem ***************************************************** rem * rem * Player 0 sprite animation if-thens. rem * rem ***************************************************** if P0_Anim_Count = 10 then player0: %11100111 %11100111 %11100111 %11100000 %11100000 %11100000 %11111111 %11111111 end if P0_Anim_Count = 20 then player0: %11100111 %11100111 %11100111 %11100111 %11100000 %11100000 %11111111 %11111111 end if P0_Anim_Count = 30 then player0: %11100111 %11100111 %11100111 %11100111 %11100111 %11100000 %11111111 %11111111 end rem ***************************************************** rem * Last animation frame for Player 0. Animation counter is reset. rem ***************************************************** if P0_Anim_Count = 40 then P0_Anim_Count = 0 : player0: %11100111 %11100111 %11100111 %11100111 %11100000 %11100000 %11111111 %11111111 end rem ***************************************************** rem * rem * Player 0 sprite position. rem * rem ***************************************************** player0x=x : player0y=y rem ***************************************************** rem * rem * Joystick movement of Player 0 sprite and position limitation. rem * rem ***************************************************** if joy0right && x < 152 then x=x+1 : P0_Flip = 0 if joy0left && x > 2 then x=x-1 : P0_Flip = 8 if joy0up && y > 9 then y=y-1 if joy0down && y < 88 then y=y+1 rem ***************************************************** rem * rem * Tells which way Player 0 sprite should be facing (left or right). rem * rem ***************************************************** REFP0=P0_Flip rem ***************************************************** rem * rem * Updates the screen. rem * rem ***************************************************** drawscreen goto MainLoop sprite_animation_if_then_2010y_03m_03d_2033t.bas sprite_animation_if_then_2010y_03m_03d_2033t.bin Edited March 4, 2010 by Random Terrain Quote Share this post Link to post Share on other sites
+Philsan #4 Posted March 4, 2010 Thanks, I've also found something interesting regarding position limitation. Quote Share this post Link to post Share on other sites
jrok #5 Posted March 5, 2010 (edited) I've always found it helpful to just reserve one variable for a universal "animation frame" and a one variable for a "framerate." Main_Loop framerate = framerate + 1 if framerate = 4 then animFrame = animFrame + 1 : framerate = 0 if animFrame = 8 then animFrame = 0 gosub PlayerSprite drawscreen goto Main_Loop So in the above, you have an 8-frame animation schedule that updates every fourth loop. To make game animation slower or faster, just alter "4" to the desired speed (higher numbers slow animation down, lower numbers speed it up) That way, rather than having to do something like "if P0_Anim_Count = 10 then player0:" you can simply do a "on" statement for every sprite you want to animate, i.e.: PlayerSprite (position updates, AI, player color, etc.) on animFrame goto P0_Frame1 P0_Frame2 P0_Frame3 P0_Frame4 P0_Frame5 P0_Frame6 P0_Frame7 P0_Frame8 return P0_Frame1 player0: %11100111 %11100111 %11100111 %11100000 %11100000 %11100000 %11111111 %11111111 end return (...) I normally contain each "on" statement at the end of whatever general subroutine I've come up with for each sprite/entity. So if it's, for instance, an enemy hunting you down, I begin the subroutine by updating it's position, then include the A.I. nodes, then end the subroutine with the "on" statements and their pointers to the sprite definitions. The important thing to remember about using this technique is to include a return after each sprite definition. After the routine reads the definition, it should return to the subroutine, which then returns to the main loop. You can do this for as many sprites (or other objects) as you want, including flickered sprites. Cheers, Jarod. Edited March 5, 2010 by jrok Quote Share this post Link to post Share on other sites
+Philsan #6 Posted March 5, 2010 Thank you very much Jarod! Quote Share this post Link to post Share on other sites
jrok #7 Posted March 5, 2010 Thank you very much Jarod! No problem. You can also include the "on" statements outside of subroutines. Such as: PlayerSprite (position updates, AI, player color, etc.) goto PlayerSpriteAnimation return PlayerSpriteAnimation on animFrame goto P0_Frame1 P0_Frame2 P0_Frame3 P0_Frame4 P0_Frame5 P0_Frame6 P0_Frame7 P0_Frame8 return P0_Frame1 player0: %11100111 %11100111 %11100111 %11100000 %11100000 %11100000 %11111111 %11111111 end return (...) I use this technique a lot in bank-switched games with lots of different animations, keeping my animations all in one place. For instance, if your animated sprite has multiple states (running, jumping, shooting, dying, etc), you can just jump to the appropriate "on" statement Label when the criteria is met in your subroutine. In any case, the useful of "on" is that you can maintain a constant animation schedule for all the elements in your game without having to keep track of a lot of different stuff. Cheers, Jarod. Quote Share this post Link to post Share on other sites
