Sign in to follow this
Heaven/TQA
Gridrunner - final round Pt. 2
just a question... I am just going through the source code and played "my" port with a Competition Pro USB stick instead of keyboard but can not move diagonal?
I have no proper VIC emulator here but can someone check if it is possible in the VIC20 version?
here is the joystick "overlay" code I am using and this worked since for 20 years for me... ;)
check_joystick: lda 632
		tay
		and #1 ;up
		bne not_up
		ldx #1
		bne get_stick_end
not_up		tya
		and #2 ;down
		bne not_down
		ldx #2
		bne get_stick_end
not_down 	tya
		and #4 ;left
		bne not_left
		ldx #4
		bne get_stick_end
not_left 	tya
		and #8 ;right
		bne not_right
		ldx #8
		bne get_stick_end
not_right 	ldx #0
get_stick_end stx $02
;now check fire button
		lda $d010 ;644 ;trigger 0
		beq fire_pressed
		lda 2
		and #$7f
		sta 2
		rts
fire_pressed lda $02
		ora #$80
		sta $02
		rts
Seems I can't get it to work in Winvice... just done a Win reinstall so all my settings are defaulted.
From what I can remember, you could do diagonal in all the versions (Atari, 64, Vic). It'd be a much harder game if you couldn't.
Looking at the code you've got there - it doesn't support diagonals anyway. You branch past everything once one directional hit is made.
Maybe just scrap it and use a translation table instead. Or, just EOR #$F and won't you have the value that Vic code expects?
ah, sorry... you might be right... ;) I need to pass all checks and then enter the valid codes for VIC into $02... thanks for pointing out...
here you go... it was my fault. thx Rybags
check_joystick:
		lda #0
		sta $02
		lda 632
		tay
		and #1 ;up
		bne not_up
		lda $02
		ora #1
		sta $02
		bne not_down
		;ldx #1
		;bne get_stick_end
not_up		tya
		and #2 ;down
		bne not_down
		lda $02
		ora #2
		sta $02
		;ldx #2
		;bne get_stick_end
not_down 	tya
		and #4 ;left
		bne not_left
		lda $02
		ora #4
		sta $02
		bne get_stick_end
		;ldx #4
		;bne get_stick_end
not_left 	tya
		and #8 ;right
		bne not_right
		lda $02
		ora #8
		sta $02
		;ldx #8
		;bne get_stick_end
not_right 	;ldx #0
		;lda #0
		;sta $02
get_stick_end ;stx $02
		beq fire_pressed
		lda 2
		and #$7f
		sta 2
		rts
		ora #$80
		sta $02
		rts
gridrunner.zip
check_joystick:
		lda #0
		sta $02
		lda 632
		tay
		and #1 ;up
		bne not_up
		lda $02
		ora #1
		sta $02
		bne not_down
		;ldx #1
		;bne get_stick_end
not_up		tya
		and #2 ;down
		bne not_down
		lda $02
		ora #2
		sta $02
		;ldx #2
		;bne get_stick_end
not_down 	tya
		and #4 ;left
		bne not_left
		lda $02
		ora #4
		sta $02
		bne get_stick_end
		;ldx #4
		;bne get_stick_end
not_left 	tya
		and #8 ;right
		bne not_right
		lda $02
		ora #8
		sta $02
		;ldx #8
		;bne get_stick_end
not_right 	;ldx #0
		;lda #0
		;sta $02
		beq fire_pressed
		lda 2
		and #$7f
		sta 2
		rts
		ora #$80
		sta $02
		rts
You can optimize your above joystick/trigger code to:
LDA 632
ASL
LSR 53264
Ror
EOR #$8F
STA $02
;) Great stuff Karolj, good to see it nearing completion.
"only" linking and some sound fx tweaking...
maybe I am moving the title msx into the "main" game... as Miker's music plus your G2F title screen is flickering on NTSC...
check_joystick:
		lda #0
		sta $02
		lda 632
		tay
		and #1 ;up
		bne not_up
		lda $02
		ora #1
		sta $02
		bne not_down
		;ldx #1
		;bne get_stick_end
not_up		tya
		and #2 ;down
		bne not_down
		lda $02
		ora #2
		sta $02
		;ldx #2
		;bne get_stick_end
not_down 	tya
		and #4 ;left
		bne not_left
		lda $02
		ora #4
		sta $02
		bne get_stick_end
		;ldx #4
		;bne get_stick_end
not_left 	tya
		and #8 ;right
		bne not_right
		lda $02
		ora #8
		sta $02
		;ldx #8
		;bne get_stick_end
not_right 	;ldx #0
		;lda #0
		;sta $02
		beq fire_pressed
		lda 2
		and #$7f
		sta 2
		rts
		ora #$80
		sta $02
		rts
LDA 632
ASL
LSR 53264
Ror
EOR #$8F
STA $02
aehm... if this works... it is far simpler than my one... ;)
Jesus... Atariski... your code works perfect... :D just compiled the new build... now this comes into my code snippets archive... ;)
Edited by Heaven/TQA
