Pyromaniac605 #1 Posted March 12, 2010 I just recently hacked together a new power box for my A2600 and for a while it worked fine but just now about 10 mins ago i plugged in Threshold switched it on and... nothing i flicked the switches around a bit fiddled with all the plugs... nothing i desperatley tried all my games and nothing there does not appear to be anything wrong with the wiring of my hack-job power box. Please help. -Darren- Quote Share this post Link to post Share on other sites
A.J. Franzman #2 Posted March 13, 2010 I just recently hacked together a new power box for my A2600 and for a while it worked fine but just now about 10 mins ago i plugged in Threshold switched it on and... nothing i flicked the switches around a bit fiddled with all the plugs... nothing i desperatley tried all my games and nothing there does not appear to be anything wrong with the wiring of my hack-job power box. Please help. Check voltages at the regulator. Should be left pin = same as your power supply, center pin = ground, right pin = 4.8 to 5.2 volts. All DC of course. If you have good input but no output, replace the regulator. If you have no input, check the solder on the power switch and the power jack. Quote Share this post Link to post Share on other sites
