supercat #51 Posted April 22, 2010 I'm not sure I agree %100, if there is part of the screen that is "off" and part that color cycles, the cycling part is still "ON" more that the rest. True, but stuff that isn't very bright will 'burn in' so much more slowly than stuff which is at full brightness that it becomes essentially a non-issue. A bigger issue for 2600 games, IMHO, would be distinction between the displayable screen and border/comb areas. If the displayable screen areas are cycling through bright colors, they would be burned in significantly more than the border areas. Quote Share this post Link to post Share on other sites
Pioneer4x4 #52 Posted April 22, 2010 True, but stuff that isn't very bright will 'burn in' so much more slowly than stuff which is at full brightness that it becomes essentially a non-issue. A bigger issue for 2600 games, IMHO, would be distinction between the displayable screen and border/comb areas. If the displayable screen areas are cycling through bright colors, they would be burned in significantly more than the border areas. Both points are probably true. I think that I'll stick with Star Raiders until I try out some of the other choices mentioned recently. I need to clean up and make space before I have it where it will be running all the time. Quote Share this post Link to post Share on other sites
almightytodd #53 Posted April 23, 2010 Star Wars Empire Strikes Back - After you lose, the Snow-speeder skims the surface and zips past the Imperial Walkers... Quote Share this post Link to post Share on other sites
