Heaven/TQA #1 Posted April 4, 2010 I am just in Gridrunner coding mood and wanted to get everything together. But I was under the impression that RMT replay routine was NTSC/PAL fixed and when I am not including the latest replay-routine in Eclipse I realise that the version of the ASM replay routine is the same? 1.20090108? I thought Raster fixed that issue already or do I miss something? Quote Share this post Link to post Share on other sites
matosimi #2 Posted April 5, 2010 I am just in Gridrunner coding mood and wanted to get everything together. But I was under the impression that RMT replay routine was NTSC/PAL fixed and when I am not including the latest replay-routine in Eclipse I realise that the version of the ASM replay routine is the same? 1.20090108? I thought Raster fixed that issue already or do I miss something? Just check if system is NTSC, then count player routine executions and skip every 6th frame Quote Share this post Link to post Share on other sites
