Heaven/TQA #1 Posted April 13, 2010 (edited) Well... is there any bug in G2F esp. under Windows 7? When pressing the DISC icon there is no ASM file and no fade tab created? Even when I am doing SAVE ASM in the save dialog there is no asm file on the disc? Thanks for letting me know... Edited April 13, 2010 by Heaven/TQA Quote Share this post Link to post Share on other sites
Tezz #2 Posted April 13, 2010 (edited) It's an issue caused by Win7's default settings with it's permissions which is affecting saving to the folder on the desktop, you can simply save directly to your C drive to avoid it or you can alter the permissions: 1. Right click on Desktop folder and click Properties. 2. Switch to Security tab and click Edit. 3. Click Add, type your account name, click Check Names and click OK. 4. Highlight your account name and allow full control. 5. Click OK. Edited April 13, 2010 by Tezz Quote Share this post Link to post Share on other sites
Heaven/TQA #3 Posted April 13, 2010 what a nice W7 feature... I am using a software and it prevents to save me... thanks Tezz... Quote Share this post Link to post Share on other sites
Heaven/TQA #4 Posted April 14, 2010 Tezz, it seems not working under Parallels and OS X... I can not do what you mentioned and saving on c: plus pressing the "save" button does not generate any files... to make a long story short... can you simply post your fixed title screen with all data files and fade enabled? thanks! I have not relocated any data in memory so you can simply press export... Thanks! Quote Share this post Link to post Share on other sites
Tezz #5 Posted April 14, 2010 ok sure, no problem. PM with files sent Quote Share this post Link to post Share on other sites
