LYNXGUY
Legacy Engineering USB joystick & Xformer 2000
I ordered and received the Legacy Engineering USB joystick and I have 2 questions. . . . . . .
Does anyone know why it doesn't work with Xformer 200 for Windows v.8 ???
But if it does am I missing a setting somewhere ???
thanks
LYNXGUY
thanks
LYNXGUY
I can't get any joystick to work in xformer, nor do I get sound. even when selecting those options.
I got sound and on my old computer I was able to use a non USB joystick that worked great.
I do get sound on my new computer and I can use the keyboard to play but thats no fun.
Maybe Xformer 2000 isn't programmed for USB joysticks ???
Edited by LYNXGUY
below is a image capture and the joystick works as I can move the "x" all over and the #1 red fire button lights up but no games work with either the Xformer or any PC game that requires a joystick.
Any ideas ???
Edited by LYNXGUY
Id dump Xformer - any good reason why you'd torture yourself getting it to work?
thanks
LYNXGUY
What is Windows v.8 ???
Maybe you don't have a DirectX installed.
Check out the xformers web site..
http://www.emulators.com/xformer.htm
Edited by rdea6
Actually it is called Xformer 2000 For Windows v.8
v.8 is version 8
I've tried the sticks with a bunch of PC games as well as other atari emulators....
Xformer is the only one that wont work.
Is there any particular reason you want to use XFormer 2000 instead of another emulator? XFormer is pretty old, and it just might not be programmed to read joysticks via DirectInput.
I checked out the site and which DirectX do I download ??
I got a DELL with Windows XP
Click on the Start button, click "Run," and type "dxdiag" and click "OK". This will tell you which version of DirectX you have; for Windows XP, you should have DirectX 9. If the program doesn't run, or if you have an older version, download DirectX 9 here.
Here is a pic of the USB DirectX info
It is super easy to use and it uses .atr files which are awesome, any other 8bit Emulators that use .atr files ??
Edited by LYNXGUY
That looks like DirectX 9. Unless the "dxdiag" program shows that you have an older version (see the "System" tab), then I'm not sure what else you can do. If XFormer 2000 isn't programmed to read joysticks via DirectInput, then it just can't do it, and you probably won't be able to get it to work with any USB joystick; it isn't an issue specific to the Legacy joysticks. As I said, XFormer is a pretty old emulator, and you should probably look into a newer one (like Atari800Win or Altirra) instead.
My DELL doesn't have a joystick input so I have no choice but to use a USB joystick :x
It's a crap emulator anyway, NFI why anyone would still bother to use it.
I've found that sometimes it can help with apps that have trouble with joysticks to ensure that the one you want to use is listed first in the control panel - you can change the order of controllers installed via it.
In my experience, the one thing that XFormer has going for it is its ability to mount a file in the PC filesystem directly as a "virtual" disk image. That makes it easy to read an XEX or a data file without having to move it into an ATR first. But then again, there aren't many situations when you'd actually need to do that.
I downloaded Altirra 0.9.0.0
It looks great but. . . . . . .
How do I load .ATR files and what are the keyboard commands ??
Not all games start with pushing the fire button :cool:
Loading ATR files: "File" Menu -> "Boot image..."
Keyboard commands: README.TXT (under "Keyboard Mappings")
Where did you get version 0.9.0.0? The most current version is 1.6, at the site I linked to earlier.
Direct from emulator.com:
[/Quote]
"Using the optional Xformer Cable with Xformer Classic (on MS-DOS only) you can directly connect Atari 810, Atari 1050, XF551, Indus GT, and Rana disk drives to your PC to transfer Atari 8-bit files and disks to your PC. Xformer Classic and Xformer Cable are no longer supported. The DOS software and instructions for building the cable are provided as-is."
This is the only reason that I ever used this emulator in the past.. I had my rana drive and printer connected to my PC, and was able to read disks and print listings.
Later I found out about APE, SIO2PC, and never looked back.
Edited by rdea6
Thanks for the info
I cannot for the life of me remember where I got that version but I will download version 1.6.
again thanks.
Xformer is a horrendous piece of crap. Do yourself a favor and grab one of the other emulators mentioned. ;)
Altirra is an awesome choice in particular. :cool:
Guess what guys,
I downloaded the latest version of Altirra and OMFG it is AWESOME :o :o
And with the latest version the Legacy joystick works.
I am going to put Altirra on my laptop too, thanks guys you rock :thumbsup: :thumbsup:
It sure is! :cool: :thumbsup:
And it's written by a friendly and extremely talented guy rather than a giant asshole like Xformer. :D
What's the story with Xformer, and the guy who wrote it? Looks like he did/said something bad? What happened? Is he still in business?
When I "dropped off the scene" it was ST Xformer, trying to emulate the A8 on the ST and it just didn't work. I know there's been "Gemulator" and "Xformer 98" and stuff like that and I don't know one from the other - which systems, etc. The only one I've ever put any time in with is A800win. I do think I downloaded one of those Xformer packages a long time ago, just to get the OS and BASIC ROMS, which I used in A800win; I don't recall that I even tried the one with it. Sounds like I didn't miss out on anything, eh?
