matthew180
Assembly on the 99/4A
5 hours ago, Asmusr said:
Which ones are those?
Let's see RXB, SXB and XB 2.8 are backwards compatible, except RXB is only one that can run TI Basic programs without modifications.
Abasic, Power Basic, and Kull XB 2 can not run XB programs without major modifications to XB programs, thus NOT BACKWARDS COMPATIBLE.
Posted (edited)
Thanks. So those BASICs are based on a compiling of the XB GPL into machine code?
Edited by Asmusr
Just now, Asmusr said:
Thanks. So those BASICs are based on compiling the XB GPL into machine code?
Yep that is exactly what you find!
It is very very hard to convert GPL to Assembly and make it work without using the built in GPL.
There are things Assembly can do that are very fast but you give up many features of GPL in return.
Tursi had the best solution is to get rid of GROM delays as that would make GPL the same speed as Forth.
If abasic refers to the Geneve basic, it is very compatible with standard XB, barring programs that went outside the XB playground.  Although like RXB and other enhanced BASICs, the Geneve Basic adds features and CALLS that can render a program unusable with standard XB.  I do not know if Geneve basic can run TI Basic programs without modifications, though from what I've read it is likely since it doesn't use VDP for processing, garbage collection, or program space.
Geneve Basic is written in assembly (no GPL) and the source is available.  Since Myarc worked with TI, I wouldn't be surprised if the XB ROM assembly code portion had been consumed into the project and then updated for the new environment.  Maybe there are some hints and tricks that could be applied on the TI side as well, should such a programming effort move forward.
Incorrect. XB 2.8 G.E.M. can also run TI BASIC programs without modifications.
So I assume you don't think the assembly code was generated by compiling the XB GPL into assembly. That leaves only Power Basic and Kull XB 2 as candidates for doing what I suggested.
I did not make that clear in my post but yes, that is a correct assumption based on my knowledge of the code.
Hmmm is just loaded XB 2.7 on Classic99 and typed:
CALL CHAR(158,"FF")
ERROR BAD VALUE
But you can do this in RXB no problem, so it sounds like you have to prepare XB 2.7 to pull this off.
Or can you do this in XB 2.8 without doing anything but just type it in or run it without a CALL to make it work?
Posted (edited)
"Or can you do this in XB 2.8 without doing anything but just type it in or run it without a CALL to make it work?"
Of course it can be done. XB 2.7 is not the same as XB 2.8 G.E.M.!!!!!
Edited by senior_falcon
Any news on when XB 2.8 will be in Classic99 so I can test it?
Posted (edited)
You can download it right now and run it as a user cartridge.
(sorry about the big blue heart-dunno where that came from!)
From deep down perhaps?
  • Haha 2
Not /every/ new product lands in Classic99. ;)
We need that TI-based app store... ;)
A question that I know has been answered before but I cannot find the right search words.
I see that starting an program file with E/A 5  will look for a file if even if you type nothing at the command line and just hit ENTER.
What file is it searching for?
I seem to recall it searches for DSK1.UTIL1
If not E/A, then TI-Writer does that?
Yes, Editor/Assembler loads DSK1.UTIL1 when an empty path is entered in option 5.
Thanks guys.
I am getting tired of typing DSK1.CAMTTY67  everytime I need to restart my system.
