matthew180
Assembly on the 99/4A
Hmm SAMS has 4K pages at EVERY ADDRESS IN 32K and that means a single 4K page can reside at multiple locations at same time too!
        PAGE S3
                              SAMS MAPPER
     The SAMS card has tons of documents as to its function and use.
     So to re-explain these docs would be pointless. Read the docs or
     find some, sorry but the RXB package is already huge.
     In PASS mode the mapper register setup is equivalent to:
     mapper address  mapper  page num            address range
      HEX     Dec            HEX  Dec            memory area
     >4004 = 16388 is MR02 = >02 = 02 points to >2000 - >2FFF range
     >4006 = 16390 is MR03 = >03 = 03 points to >3000 - >3FFF range
     >4014 = 16404 is MR10 = >0A = 10 points to >A000 - >AFFF range
     >4016 = 16406 is MR11 = >0B = 11 points to >B000 - >BFFF range
     >4018 = 16408 is MR12 = >0C = 12 points to >C000 - >CFFF range
     >401A = 16410 is MR13 = >0D = 13 points to >D000 - >DFFF range
     >401C = 16412 is MR14 = >0E = 14 points to >E000 - >EFFF range
     >401E = 16414 is MR15 = >0F = 15 points to >F000 - >FFFF range
     (MR=Mapper Register)
     In MAP mode the mapper register setup is equivalent to: EXAMPLE1
     >4004 = 16388 is MR02 = >10 = 16 points to >2000 - >2FFF range
     >4006 = 16390 is MR03 = >11 = 17 points to >3000 - >3FFF range
     >4014 = 16404 is MR10 = >12 = 18 points to >A000 - >AFFF range
     >4016 = 16406 is MR11 = >13 = 19 points to >B000 - >BFFF range
     >4018 = 16408 is MR12 = >14 = 20 points to >C000 - >CFFF range
     >401A = 16410 is MR13 = >15 = 21 points to >D000 - >DFFF range
     >401C = 16412 is MR14 = >16 = 22 points to >E000 - >EFFF range
     >401E = 16414 is MR15 = >17 = 23 points to >F000 - >FFFF range
                                                            PAGE    S4
                              SAMS MAPPER
     In map mode the mapper register setup is equivalent to: EXAMPLE2
     >4004 = 16388 is MR02 = >62 =  98 points to >2000 - >2FFF range
     >4006 = 16390 is MR03 = >63 =  99 points to >3000 - >3FFF range
     >4014 = 16404 is MR10 = >64 = 100 points to >A000 - >AFFF range
     >4016 = 16406 is MR11 = >65 = 101 points to >B000 - >BFFF range
     >4018 = 16408 is MR12 = >66 = 102 points to >C000 - >CFFF range
     >401A = 16410 is MR13 = >67 = 103 points to >D000 - >DFFF range
     >401C = 16412 is MR14 = >68 = 104 points to >E000 - >EFFF range
     >401E = 16414 is MR15 = >69 = 105 points to >F000 - >FFFF range
     In MAP mode the mapper register setup is equivalent to: EXAMPLE3
     >4004=16388 is MR02 =>1FF9 = 8185 points to >2000 - >2FFF range
     >4006=16390 is MR03 =>1FFA = 8186 points to >3000 - >3FFF range
     >4014=16404 is MR10 =>1FFB = 8187 points to >A000 - >AFFF range
     >4016=16406 is MR11 =>1FFC = 8188 points to >B000 - >BFFF range
     >4018=16408 is MR12 =>1FFD = 8189 points to >C000 - >CFFF range
     >401A=16410 is MR13 =>1FFE = 8190 points to >D000 - >DFFF range
     >401C=16412 is MR14 =>1FFF = 8191 points to >E000 - >EFFF range
     >401E=16414 is MR15 =>2000 = 8192 points to >F000 - >FFFF range
This from RXB 2020 documents.
So the SAMS blows away any other Memory type of device as you can have copies of same memory location in SAMS at same time.
One page could have self modified code and another copy could be a back up to restore everything back to original and a third another version and a forth so on.........
        PAGE S3
                              SAMS MAPPER
                                                            PAGE    S4
                              SAMS MAPPER
Can you map memory into >6000 to >6FFF and >7000 to >7FFF?  Or are those pages blocked as I noticed the mapper registers from >4008 to >4012 are not listed?  And yes, I understand one can map in/out memory from the 32K range, just trying to understand if I can expand to 40K by opening up the >6000 to >7FFF range from within SAMS.
You can only map >2000, >3000, >A000, >B000, >C000, >D000, >E000, >F000
The E/A cart doesn't provide RAM at >6000->7FFF unless it's also a Super Cart.
Edited by Asmusr
1 hour ago, Asmusr said:
The E/A cart doesn't provide RAM at >6000-7FFFF unless it's also a Super Cart.
It's one of my favourite enhancements. :)
It is for my requirements, thus I have 40K of useable ram.  I needed the extra ram for that program with the new features that were added and the extra code for the TIPI interface.
I have built, hmm.. sitting here 4ea 32k supercarts. As a normal routine for each I copy >2000 through all the ea utils that are tabled, like lee explained, and I copy that to one of my 4 banks of supercart space, then I can always push that table back to >2000 again to make my utils always available to my ea programs.
Again 1 Meg, how much can you map into >6000 to >7FFF and the answer is half as much which is 512K at most.
Also the SAMS has the special issue of being able to have same thing being changed at same time in another address let me explain:
I put a Assembly program that modifies itself at >A000 and that same routine is at >B000 as both of those 4K pages are the same page say page 76 in SAMS.
So SAMS page 76 resides at both >A000 and >B000 so any change to >A000 will be exactly duplicated in >B000 so do you see the implications for SELF MODIFIED CODE?
That means if you modifiy code at >B000 it will be exactly duplicated at >A000 thus you can make a copy of page 76 into another page say 86 now you have a restore.
I used this feature to do a RXB SECTOR COPY of a disk that removed the copy protections and copied the results from DISK 1 to DISKS 2, 3 and 4.
I can see the fixation on Cartridge RAM but it is ONLY 8K not 32K!!!!
On 8/30/2021 at 5:25 PM, 9640News said:
Got a question.  Is there a way with the Editor/Assembler module present, to use GPL code to load an EA #5 file (4 parts), into memory?
What I would like to do would be to have a keypress detected in a running assembly program, that would load a revised version of the program replacing itself.  It would load the program from >A000 to >FFFC and from >6000 to ~>7A00.
Beery
Maybe I am having a “senior” moment, but if you press 1 from the EA menu, does it not load an EA5 program EDIT1 etc, and if you press 2 does it not load EA5 program ASSM1 etc?
Pressing 1 loads the editor but note, there are other menus depending on the first menu selections.
Edited by GDMike
Well REA still has those keys you can use 1, 2, 3, and 5 for same menu items but the screen shows something diffrent:
1126657260_REAScreen.thumb.png.359197e82c0df6fb4d2608e600060e4b.png Also S path sets your Editor or Assembler so you never have to type it in twice.
Edited by RXB
missing text
