Mord #1 Posted May 15, 2010 I've been thinking about getting rid of my Sega Master System since I tend to just use the power base converter on my genesis these days. Before I do tho, does anyone know of any games that don't work with it? Quote Share this post Link to post Share on other sites
ApolloBoy #2 Posted May 15, 2010 The only one I know of that doesn't work is F-16 Fighting Falcon, because that uses a video mode that the Genesis doesn't support. Quote Share this post Link to post Share on other sites
Mord #3 Posted May 15, 2010 The only one I know of that doesn't work is F-16 Fighting Falcon, because that uses a video mode that the Genesis doesn't support. I have that game, but can't say I'm a fan of it. So I guess if I get rid of the SMS, that game will go with it. Quote Share this post Link to post Share on other sites
wavelflack #4 Posted May 16, 2010 What are the details of the video mode? Quote Share this post Link to post Share on other sites
gdement #5 Posted May 16, 2010 What are the details of the video mode? It's an old mode from the SG-1000. Wikipedia says the SG-1000 uses 256x192 16 colors, 32 sprites (per screen I assume, size not given). Apparently F-16 is the only SMS game that used this mode. I wonder if there was any advantage that could explain it, or maybe it was just a quick port from the older system. Quote Share this post Link to post Share on other sites
gdement #6 Posted May 16, 2010 I think I've heard of some games not working with the Genesis controllers, so you might need to keep your SMS pads. Somebody else can probably give a list, or say if I'm wrong. Quote Share this post Link to post Share on other sites
goldenegg #7 Posted May 16, 2010 I think I've heard of some games not working with the Genesis controllers, so you might need to keep your SMS pads. Somebody else can probably give a list, or say if I'm wrong. You're correct. I don't have a full list, but can tell you Montezuma's Revenge is one of those games. Quote Share this post Link to post Share on other sites
Mord #8 Posted May 16, 2010 I think I've heard of some games not working with the Genesis controllers, so you might need to keep your SMS pads. Somebody else can probably give a list, or say if I'm wrong. You're correct. I don't have a full list, but can tell you Montezuma's Revenge is one of those games. Wonder boy in Monsterland is another. That's fine tho. I have 4 controllers so if I get rid of the SMS I'll only be getting rid of two of the controllers. Quote Share this post Link to post Share on other sites
goldenegg #9 Posted May 16, 2010 I think I've heard of some games not working with the Genesis controllers, so you might need to keep your SMS pads. Somebody else can probably give a list, or say if I'm wrong. You're correct. I don't have a full list, but can tell you Montezuma's Revenge is one of those games. Wonder boy in Monsterland is another. That's fine tho. I have 4 controllers so if I get rid of the SMS I'll only be getting rid of two of the controllers. It's possible to mod a Genesis controller to work with those games. You need to cut the wire coming from pin 7. An easy way to do this without damaging a controller, simply buy a 9-pin M/F adapter and pull out pin 7. Connect the adapter between the Genesis and the controller. This is the method I use, as I really dislike the SMS controllers. Quote Share this post Link to post Share on other sites
davepesc #10 Posted May 16, 2010 Add Bomber Raid and Alien Syndrome to the list that need an SMS pad. Quote Share this post Link to post Share on other sites
doubleminor #11 Posted May 16, 2010 Monopoly starts up, but doesn't give you the setup menu. Quote Share this post Link to post Share on other sites
