danwinslow #1 Posted May 16, 2010 I recently acquired a falcon. It had the standard Connor 85MB drive in it. It booted up and worked fine. Then, because I am an idiot, I thought it would be good to get HDDriver loaded. So I dug out my HDDriver disk, and copied the disk overtop of the root of the C: drive. The next boot, I could see the original Atari HD driver come up and announce the HD, and then the hddriver loads. When the desktop comes up, it says "Data on drive C: may be damaged" and I'm stuck. Booting with the HDDriver disk only seems to work, until I launch the configuration utility. Any command I use from the utility freezes up the computer. I figure I need to remove the HDDriver driver out of teh auto program, but I cant get to teh C: drive to do it. Any suggestions? Quote Share this post Link to post Share on other sites
danwinslow #2 Posted May 16, 2010 Nm, found my way around it. Quote Share this post Link to post Share on other sites
