Tanman Posted May 18, 2010 Share Posted May 18, 2010 Alcohol the best thing to use on the pins? Just got a bunch of carts in that look like they were buried for 10 years. Quote Link to comment Share on other sites More sharing options...
+Mitch Posted May 18, 2010 Share Posted May 18, 2010 Isopropyl alcohol and q-tips are what I use to clean them. Mitch Quote Link to comment Share on other sites More sharing options...
Rybags Posted May 18, 2010 Share Posted May 18, 2010 AKA VCR Head Cleaner fluid. Aerosol electrical contact cleaner also does the job, but it's a bit pricey. I find that it is also good for doing the hard to reach contacts on motherboard connectors. And apparently some have had success using a simple pencil eraser. Quote Link to comment Share on other sites More sharing options...
labrat Posted May 18, 2010 Share Posted May 18, 2010 And apparently some have had success using a simple pencil eraser. Yes, use a pencil eraser for the really stubborn ones that you think are dead! Quote Link to comment Share on other sites More sharing options...
Sleepy Posted May 18, 2010 Share Posted May 18, 2010 (edited) I also use a rubber to clean the contacts. Aerosol electrical contact cleaner also does the job, but it's a bit pricey. I find that it is also good for doing the hard to reach contacts on motherboard connectors. When you use something like "Kontakt 60" don´t forget to remove the cleaning fluid with "WL-Spray" because "Kontakt 60" is good in cleaning, but when it remains on the pcb or contacts in a switch it can damage it. After cleaning with 61 & WL protect the contacts with "Kontakt 61". Sleepy Edited May 18, 2010 by Sleepy Quote Link to comment Share on other sites More sharing options...
ApolloBoy Posted May 18, 2010 Share Posted May 18, 2010 This stuff works wonders: Out of all the methods I tried, this works the best. Quote Link to comment Share on other sites More sharing options...
Tanman Posted May 18, 2010 Author Share Posted May 18, 2010 Windex? Good bad? Quote Link to comment Share on other sites More sharing options...
scanline Posted May 22, 2010 Share Posted May 22, 2010 Windex? Good bad? windex would probly be a very bad idea way to much water and if you use rubbing alcohol use the 91% Isopropyl Alcohol instead of the only 50% rubbing alcohol Quote Link to comment Share on other sites More sharing options...
