Tr3vor #1 Posted June 24, 2010 I found that my atari had cobwebs on it after 3 days of sitting in the "extra room", so I took it apart to see if any spiders made it thier home. when I was in there, i found that the top said "Property of Atari" I don't think so... and it had a paper taped to the cpu box thing saying (I think) my atari's birthday. I'm wondering if this is normal for an Atari Quote Share this post Link to post Share on other sites
BDW #2 Posted June 24, 2010 Out of the several Ataris I have opened up, all of them have the little piece of paper. I dont remember the stamp, though. Quote Share this post Link to post Share on other sites
shadowdoggie #3 Posted June 24, 2010 The paper is normal, but where exactly are you seeing that stamp? I've never seen that. What type of unit is it? Quote Share this post Link to post Share on other sites
JingleJoe #4 Posted June 24, 2010 Yup mine has the peice of papper, with ancient useless selotape too but not the stamp ... perhaps yours was something special? Quote Share this post Link to post Share on other sites
Tr3vor #5 Posted June 24, 2010 The paper is normal, but where exactly are you seeing that stamp? I've never seen that. What type of unit is it? Its a light sixer with speaker vents and a channel select switch. The stamp is on under the very top of the atari, a bit to the right from the cartrige port. Quote Share this post Link to post Share on other sites
+Random Terrain #6 Posted June 24, 2010 I didn't know that Zorro worked for Atari. 2 Quote Share this post Link to post Share on other sites
JingleJoe #7 Posted June 24, 2010 The paper is normal, but where exactly are you seeing that stamp? I've never seen that. What type of unit is it? Its a light sixer with speaker vents and a channel select switch. The stamp is on under the very top of the atari, a bit to the right from the cartrige port. I knew they were for speakers! Sorry for the tangent but does anyone have any links to Atari history information about that? Quote Share this post Link to post Share on other sites
shadowdoggie #8 Posted June 24, 2010 (edited) The paper is normal, but where exactly are you seeing that stamp? I've never seen that. What type of unit is it? Its a light sixer with speaker vents and a channel select switch. The stamp is on under the very top of the atari, a bit to the right from the cartrige port. I knew they were for speakers! Sorry for the tangent but does anyone have any links to Atari history information about that? If you search, you should be able to find a bunch of threads on the speaker vents and some of the history behind how they were to be used. And, regarding the stamp, I think this Atari may have been a little special, because I've never seen that before on any Atari I've had in my possession. Edited June 24, 2010 by shadowdoggie Quote Share this post Link to post Share on other sites
Tr3vor #9 Posted June 25, 2010 Sweet, my atari's special Quote Share this post Link to post Share on other sites
A-T-A-R-I #10 Posted June 25, 2010 (edited) Two of my 6ers have the "Property Of Atari" stamp. Could it be they stamped this in the promotional units that the stores used on display? Edited June 25, 2010 by A-T-A-R-I Quote Share this post Link to post Share on other sites
Herbarius #11 Posted June 25, 2010 (edited) After seeing several of these threads I feel pretty bad for thoughtlessly removing that piece of paper from my Atari, when I opened it up the first time, and throwing it into the trash... To my defense, I had no idea every Atari had this, for all I knew the previous owner put it in there for some reason unknown to me... It was almost an automatic "this doesn't belong here" reaction... (no, it didn't have a stamp) Edited June 25, 2010 by Herbarius Quote Share this post Link to post Share on other sites
Benzman66 #12 Posted June 25, 2010 I always throw the piece of paper out when repairing them. Quote Share this post Link to post Share on other sites
JingleJoe #13 Posted June 25, 2010 My peice of paper doesn't have a date on it, just a number and a squiggle. Additionally I googled about the atari speakers and found some good info here Quote Share this post Link to post Share on other sites
shadowdoggie #14 Posted June 26, 2010 My peice of paper doesn't have a date on it, just a number and a squiggle. Additionally I googled about the atari speakers and found some good info here More speaker info... http://www.atariage.com/forums/topic/90798-2600-heavy-sixer-with-built-in-speakers/page__p__1105699__hl__2600%20speakers__fromsearch__1?do=findComment&comment=1105699 http://www.atariage.com/forums/topic/68994-heavy-sixer-or-not/page__p__848125__fromsearch__1?do=findComment&comment=848125 Early runs of the 4 switch systems had speaker vents too Quote Share this post Link to post Share on other sites
A.J. Franzman #15 Posted June 27, 2010 After seeing several of these threads I feel pretty bad for thoughtlessly removing that piece of paper from my Atari, when I opened it up the first time, and throwing it into the trash...[...] (no, it didn't have a stamp) Do you mean it was blank? Some of the imprints on these papers do seem to be more subject to fading than others. I always throw the piece of paper out when repairing them. Please stop doing that. My peice of paper doesn't have a date on it, just a number and a squiggle. That number probably is a date code. Some of these papers even have a date and time code, down to the second. Others have resisted attempts to decode them. Quote Share this post Link to post Share on other sites
A.J. Franzman #16 Posted June 27, 2010 Early runs of the 4 switch systems had speaker vents too Yes, but only heavy sixers had speaker supports molded into the case bottom. Quote Share this post Link to post Share on other sites
Herbarius #17 Posted June 27, 2010 Do you mean it was blank? Some of the imprints on these papers do seem to be more subject to fading than others. Yes, it looked blank, unless my memory is playing a trick on me. Quote Share this post Link to post Share on other sites
Zoyx #18 Posted June 27, 2010 I had not clue that the 2600 had stereo support until I did my A/V mod. Then noticed that noises were coming from different speakers. For instance, the Flash Gordon theme in Vanguard goes through the left channel. Call me easily amused, but I thought that was kind of neat to discover after all these years. Quote Share this post Link to post Share on other sites
SekOner #19 Posted June 28, 2010 I had not clue that the 2600 had stereo support until I did my A/V mod. Then noticed that noises were coming from different speakers. For instance, the Flash Gordon theme in Vanguard goes through the left channel. Call me easily amused, but I thought that was kind of neat to discover after all these years. Yeah,i second that. who knew that Atari's had stereo support. i always second guessed myself when i would say "thats definitely for speakers,.....no no its for ventilation... nope speakers". crazy to find out all this time later that indeed they are for speakers. Quote Share this post Link to post Share on other sites
