+mizapf Posted November 13, 2016 Share Posted November 13, 2016 May I add one thing that I found surprisingly GOOD with Windows 10? It is the Win-X menu. It may have been there for some longer time, but I never heard about it until now, and when I tried it, it was as if someone said, sure we did not forget you, but we couldn't say it too loud that there is a pro menu, or the people would start to do silly things with it. An honest thumbs up from a Linux advocate. 2 Quote Link to comment Share on other sites More sharing options...
RXB Posted November 15, 2016 Share Posted November 15, 2016 (edited) OMG in an attempt to get Classic99 to work I just created a NEW LOGIN just for Classic99 on my Windows 10 and guess what happens: Downloaded a brand new copy of Classic99 and put it in Documents folder did nothing else but started Classic99 and wrote a single line in RXB 1 REM typed: SAVE "DSK3.TEST" typed CALL CAT(3) and it showed the XB program there. typed DELETE "DSK3.TEST" I/0 ERROR 73 RXB can not DELETE A XB PROGRAM? All the DSK# are all READ ONLY and I can not do anything ???? What is going on with Windows 10 and Classic99? P.S. TI99DIR will delete those files???? Edited November 15, 2016 by RXB Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted November 15, 2016 Share Posted November 15, 2016 ... at this point I'm seriously considering whether even I need to roll over to Linux on my desktop. The enlightened path is beckoning.... 2 Quote Link to comment Share on other sites More sharing options...
Sinphaltimus Posted November 15, 2016 Share Posted November 15, 2016 (edited) OMG in an attempt to get Classic99 to work I just created a NEW LOGIN just for Classic99 on my Windows 10 and guess what happens: Downloaded a brand new copy of Classic99 and put it in Documents folder did nothing else but started Classic99 and wrote a single line in RXB 1 REM typed: SAVE "DSK3.TEST" typed CALL CAT(3) and it showed the XB program there. typed DELETE "DSK3.TEST" I/0 ERROR 73 RXB can not DELETE A XB PROGRAM? All the DSK# are all READ ONLY and I can not do anything ???? What is going on with Windows 10 and Classic99? P.S. TI99DIR will delete those files???? Using that same profile, disable indexing. See if that fixes your issue. Also, disable the Windows preview pane. Edited November 15, 2016 by Sinphaltimus Quote Link to comment Share on other sites More sharing options...
+Schmitzi Posted November 15, 2016 Share Posted November 15, 2016 Wasn´t there something with "Type=3" for the wanted DSK#, to have write access ? In the classic.ini Quote Link to comment Share on other sites More sharing options...
Tursi Posted November 15, 2016 Author Share Posted November 15, 2016 The enlightened path is beckoning.... I thought we ended the computer/OS/console wars when we grew up? I've been using Linux professionally for 21 years now, so if I may snark back (in all love, cause you're awesome), "enlighten this!" I just don't like it as a development platform.. I much prefer the tools available for in Windows. I'll do it at work where I have to, but for fun I like lighter systems. Or old school, where the tools suck AND the system is small enough to work it out anyway. Quote Link to comment Share on other sites More sharing options...
Tursi Posted November 15, 2016 Author Share Posted November 15, 2016 (edited) OMG in an attempt to get Classic99 to work I just created a NEW LOGIN just for Classic99 on my Windows 10 and guess what happens: Downloaded a brand new copy of Classic99 and put it in Documents folder did nothing else but started Classic99 and wrote a single line in RXB 1 REM typed: SAVE "DSK3.TEST" typed CALL CAT(3) and it showed the XB program there. typed DELETE "DSK3.TEST" I/0 ERROR 73 RXB can not DELETE A XB PROGRAM? All the DSK# are all READ ONLY and I can not do anything ???? What is going on with Windows 10 and Classic99? P.S. TI99DIR will delete those files???? If you are using FIAD, Classic99 does not support the DELETE opcode. My stance is that file management is the host system's job, not the emulator's. If you are using a disk image, Classic99's default support still doesn't support disk writes. (I guess I should just do that.) Wasn´t there something with "Type=3" for the wanted DSK#, to have write access ?In the classic.ini Please do not select "type 3" without knowing what you are doing and why, you can seriously corrupt your disk images. It only works for DSK1-3 and 180k max (the TI disk controller limitations.) It's a hack that patches in the TI disk controller ROM for testing against hardware layout. Edited November 15, 2016 by Tursi Quote Link to comment Share on other sites More sharing options...
senior_falcon Posted November 16, 2016 Share Posted November 16, 2016 I thought we ended the computer/OS/console wars when we grew up? I've been using Linux professionally for 21 years now, so if I may snark back (in all love, cause you're awesome), "enlighten this!" I just don't like it as a development platform.. I much prefer the tools available for in Windows. I'll do it at work where I have to, but for fun I like lighter systems. Or old school, where the tools suck AND the system is small enough to work it out anyway. Good heavens, no snark intended. 'Twas an effort to be humorous - if I failed...Well, there's a reason I'm not a stand up comedian! I will say that I've been spared the frustration you and Rich have experienced due to the change to Windows 8 and 10. (If I was on the Ubuntu bandwagon 5 or 6 years ago, then I'd have been gnashing my teeth over the change to the Unity desktop.) Quote Link to comment Share on other sites More sharing options...
Tursi Posted November 16, 2016 Author Share Posted November 16, 2016 Good heavens, no snark intended. 'Twas an effort to be humorous - if I failed...Well, there's a reason I'm not a stand up comedian! I will say that I've been spared the frustration you and Rich have experienced due to the change to Windows 8 and 10. (If I was on the Ubuntu bandwagon 5 or 6 years ago, then I'd have been gnashing my teeth over the change to the Unity desktop.) Bah, snark is humor too!! (And yeah... I tried Unity for a short bit on one of the images I was deploying ). 8 and 10 were unpleasant upgrades, but they are the first ones for me, and 8 was only deployed on a test machine anyway. 10 actually suits my needs fine on my tablet, I just didn't like it on my development station. Since Windows 3.1 became 95 I've managed to dodge the less useful upgrades and been pretty happy. Linux as a development platform annoys me mostly because it's a moving target, especially in the kernel. I lost weekends to work because some guy decided to change a kernel interface from open license to GPL, and I couldn't open source the driver because it included code from one of our vendors. Nothing I could do about that, except work the weekends to change the code. I don't like things that cost me time for dumb reasons. But I'm allowed to like the OS I like... it's kind of annoying to always see the "use the better one instead" type comments. I don't take it personally, but there's an embedded assumption that I don't know better, and trust me, I do. But if you really want to hear me rant, get a beer into me and ask me about OSX. 1 Quote Link to comment Share on other sites More sharing options...
+OLD CS1 Posted November 16, 2016 Share Posted November 16, 2016 Amiga or Death! Quote Link to comment Share on other sites More sharing options...
RXB Posted November 16, 2016 Share Posted November 16, 2016 (edited) If you are using FIAD, Classic99 does not support the DELETE opcode. My stance is that file management is the host system's job, not the emulator's. If you are using a disk image, Classic99's default support still doesn't support disk writes. (I guess I should just do that.) Please do not select "type 3" without knowing what you are doing and why, you can seriously corrupt your disk images. It only works for DSK1-3 and 180k max (the TI disk controller limitations.) It's a hack that patches in the TI disk controller ROM for testing against hardware layout. I never use DISK IMAGE in Classic99, if you have ever watched any of my Youtube video's you know I use TI File created by TI99Dir from Disk Image files from PC99. Edited November 16, 2016 by RXB Quote Link to comment Share on other sites More sharing options...
Tursi Posted November 16, 2016 Author Share Posted November 16, 2016 Now Workbench I liked! 2 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted November 16, 2016 Share Posted November 16, 2016 Okay. So at some point Classic99 changed the color values. That threw me for a second. While testing, I get an all white TI screen. - Well, it struck me that it compared a bit odd to the Debugger (and other desktop applications running). Debugger do say VDP7: >0F. Color inspection says white in Debugger is >FFFFFF, and gray in Debugger is >F0F0F0. And white in TI is >F0F0F0. Oh my. All TI colors have second nibble at >0. Guess that's for a bit of convenience related to the newer F18A. Now I wonder if F18A actually outputs "dark white" for white, or if there's an exception there (like turning >FFF into >FFFFFF). Not terribly important, just that white used to be white ... Quote Link to comment Share on other sites More sharing options...
RXB Posted November 16, 2016 Share Posted November 16, 2016 Ok this is just so odd: I put a brand new fresh install of Classic99 on a new Windows 10 login and then just go to my screen in RXB 2015 Editor Assembler: Incluced are the ZIP pics and try this in RXB 2015 to see if i works properly TURSI! Pic of RXB Error.zip Quote Link to comment Share on other sites More sharing options...
Tursi Posted November 16, 2016 Author Share Posted November 16, 2016 What does the debugger say, Rich? Any time you have disk issues, please copy and paste the debug log - it usually states exactly what was tried, instead of the translated TI error. Sometimes99er - I did change the palette on October 1st. The F18A uses 4 bits per gun, and I just shifted it up.... so, it's true, it would be slightly darker. That's probably incorrect, I should probably stick a >0F in those unused bits. 1 Quote Link to comment Share on other sites More sharing options...
Tursi Posted November 16, 2016 Author Share Posted November 16, 2016 When I try to change that option 6, Rich, I don't see any disk activity at all -- is there a key I need to press to make it save the changes? Quote Link to comment Share on other sites More sharing options...
RXB Posted November 17, 2016 Share Posted November 17, 2016 (edited) When I try to change that option 6, Rich, I don't see any disk activity at all -- is there a key I need to press to make it save the changes? It saves the values into VDP RAM and does not work? I put the values in VDP RAM at >0F00 >0F00 DSK#.EDIT1 (Editor path) >OF28 DSK#.ASSM! (Assembler path) >0F50 DSK#.SOURCE (Source path) >0F78 DSK#.OBJECT (Object path) >0FA0 DSK#.LIST (List path) >0FC8 L (Assembler Options) When you put a key like 6 and type LCSFPF or LCS and hit enter it should put the value at >0FC8 in VDP RAM. Really strange some keys work like 3 works but 4, 5 and 6 do not work? Here is the entire SET PATH CONFIGURE ROUTINE: Setup values: ********************************************************* * Set up configure paths SETUP CEQ >99,V@>0EFF PREVIOUS RUN FLAG SET? BS SOLDEA Yes ST >99,V@>0EFF No, SET PREVIOUS RUN FLAG CLR V@>0F00 MOVE >FF,V@>0F00,V@>0F01 MOVE 11,G@C1,V@>0F00 DSK1.EDIT1 MOVE 11,G@C2,V@>0F28 DSK1.ASSM1 MOVE 12,G@C3,V@>0F50 DSK1.SOURCE MOVE 12,G@C4,V@>0F78 DSK1.OBJECT MOVE 10,G@C5,V@>0FA0 DSK1.LIST MOVE 2,G@C6,V@>0FC8 L * NORMAL RXB START OF EA MODULE Here is main routine: ****************************************************** * CONFIGURE PATHS * CONFIG CALL EASCRN CLR @XTOKEN CALL CLRREA ALL SPACE HOME FMT COL 6 HTEX '* CONFIGURE PATHS *' FEND ST 49,V@65 1 MOVE 40,V@>0F00,V@67 DSK1.EDIT1 ST 50,V@161 2 MOVE 40,V@>0F28,V@163 DSK1.ASSM1 ST 51,V@257 3 MOVE 40,V@>0F50,V@259 DSK1.SOURCE ST 52,V@353 MOVE 40,V@>0F78,V@355 DSK1.OBJECT ST 53,V@449 5 MOVE 40,V@>0FA0,V@451 DSK1.LIST FMT ROW 17 COL 1 HTEX '6 OPTIONS:' ROW 21 COL 4 HTEX 'CTRL 1 - 5 DRIVE SELECTION' ROW 23 COL 4 HTEX 'ANY OTHER KEY TO MAIN MENU' FEND MOVE 40,V@>0FC8,V@556 OPTIONS: L CONFIH SCAN BR CONFIH CHE '7',@KEY <7? BS CONFIL Exit out CHE '1',@KEY 1 to 6 only valid BR CLREA Exit out DST 65,@CURADD Cursor Location CHE >30,@KEY KEY>48? BR CONFIH SUB >30,@KEY KEY-48 ST @KEY,@TMP Save key 0-5 ST @KEY,@TMP8 Save key 1-6 DEC @TMP -1 MUL 96,@TMP Add 64 Cursor Address DADD @TMP,@CURADD Cursor address ST 130,V*CURADD Left Arrow DADD 35,@CURADD Cursor DST @CURADD,@TMP4 Save address CONFIJ CALL GETINP Get input DCZ @FAC6 Length 0? BS CONFIG CHE 39,@FAC <39? BS CONFIG DCLR @TMP6 Index CONFIK DADD 40,@TMP6 Index+40 DEC @TMP8 Copy of KEY BR CONFIK ST @FAC7,V@>0ED8(@TMP6) Length MOVE 39,V*TMP4,V@>0ED9(@TMP6) String BR CONFIG MMMENU ST >EA,@XTOKEN Set flag BR MMENU Exit * CTRL keys *************************************** CONFIL CHE 182,@KEY CTRL 5? BS CONFIG CHE 177,@KEY BR CONFIG CALL ACCTON ACCEPT TONE ST @KEY,@TMP4 SAVE KEY SUB 176,@TMP4 CTRL=1 to 5 DCLR @ARG DST -25,@TMP SCREEN ADDRESS DST >0EDC,@ARG MEMORY ADDRESS CONFLP DADD 40,@ARG 40*VALUE DADD 96,@TMP 96*VALUE DEC @TMP4 BR CONFLP ST 30,@TMP6 CONDEU DST >0160,@TMP2 COUNTER CONDEV SCAN BS CONDST DDEC @TMP2 COUNTER-1 BR CONDEV EX V*TMP,@TMP6 SWAP B CONDEU CONDST CALL ACCTON ST @KEY,V*TMP SCREEN ADDRESS # ST @KEY,V*ARG MEMORY ADDRESS # BR CONFIG ************************************************** Edited November 17, 2016 by RXB Quote Link to comment Share on other sites More sharing options...
Tursi Posted November 17, 2016 Author Share Posted November 17, 2016 I dunno.. it works for me. Not that I actually know what 'works' means? Are you using the built-in RXB2015 or your own? Can you just show me a short video of what is not working? I suspect I don't actually know what I'm testing. 1 Quote Link to comment Share on other sites More sharing options...
sometimes99er Posted November 17, 2016 Share Posted November 17, 2016 (edited) Sometimes99er - I did change the palette on October 1st. The F18A uses 4 bits per gun, and I just shifted it up.... so, it's true, it would be slightly darker. That's probably incorrect, I should probably stick a >0F in those unused bits. To preserve black as >000000 and get white as >FFFFFF, you could simply duplicate the first nibble for each color element (RGB). That "trick" would distribute the intensity of "guns" somewhat evenly. For example, cyan, >40E0F0, would become >44EEFF. Edited November 17, 2016 by sometimes99er Quote Link to comment Share on other sites More sharing options...
RXB Posted November 17, 2016 Share Posted November 17, 2016 I dunno.. it works for me. Not that I actually know what 'works' means? Are you using the built-in RXB2015 or your own? Can you just show me a short video of what is not working? I suspect I don't actually know what I'm testing. Yea using RXB 2015 E you have in Classic99. So why when I load this into XP on my 300 Mhz IBM PC behind me does the same thing happen????? Do you have something loaded that i do not? Silver light? Some library I do not have? Yea I will post a video and get back to you on this..... Quote Link to comment Share on other sites More sharing options...
Tursi Posted November 17, 2016 Author Share Posted November 17, 2016 To preserve black as >000000 and get white as >FFFFFF, you could simply duplicate the first nibble for each color element (RGB). That "trick" would distribute the intensity of "guns" somewhat evenly. For example, cyan, >40E0F0, would become >44EEFF. I like that idea, thanks! 1 Quote Link to comment Share on other sites More sharing options...
RXB Posted November 20, 2016 Share Posted November 20, 2016 Hi! Well I have no clue why I only have 1 working copy of Classic99 but every so often it will not allow me to write to VDP >0F00 as it should as I showed previously. I have learned to fix this is shut down Classic99 and start it up and it works fine after that???? Whenever I use Classic99 I have to got to Set up and try to change Option 6 and if it does not work I have to restart Classic99 and it works after that. Quote Link to comment Share on other sites More sharing options...
Tursi Posted November 20, 2016 Author Share Posted November 20, 2016 Rich, that is a weird thing. There's no difference in the code between a write to VDP >0F00 and a write to any other VDP address, except the GPU addresses >4000->41FF (and only the GPU can do those). I'm still not clear what happens when you say it doesn't work... I would appreciate a video of that case. I can change option 6 but I'm just guessing, I've no idea what I should be seeing so I don't know if it's right or wrong. Also try it under MESS or JS99er (MESS is a better test since it uses a different CPU core).. let's try to narrow down if it's an emulation issue. Quote Link to comment Share on other sites More sharing options...
RXB Posted November 21, 2016 Share Posted November 21, 2016 (edited) Rich, that is a weird thing. There's no difference in the code between a write to VDP >0F00 and a write to any other VDP address, except the GPU addresses >4000->41FF (and only the GPU can do those). I'm still not clear what happens when you say it doesn't work... I would appreciate a video of that case. I can change option 6 but I'm just guessing, I've no idea what I should be seeing so I don't know if it's right or wrong. Also try it under MESS or JS99er (MESS is a better test since it uses a different CPU core).. let's try to narrow down if it's an emulation issue. I select 4 for REA, go to set up with S, and push 6 for Options, and type in values, nothing happens and nothing changes. I have the debugger shows I pushed the keys LCSFPF but nothing is written to VDP and it does the same thing for 4, 5 and 6 but 1 to 3 do work fine? So I shut down Classic99 and restart it then it works fine? Something is stopping it from writing to VDP in these areas and I have no idea what? Shutting down and restarting fixes it? P.S. It also crashes GPL Assembler too. Is Edit Assembler preloaded before I load the GPL Assembler? It occurred to me that maybe there is a conflict there in VDP? Edited November 21, 2016 by RXB Quote Link to comment Share on other sites More sharing options...
Tursi Posted November 21, 2016 Author Share Posted November 21, 2016 The issues you are asking about there sound more like software issues than emulation issues. Classic99 doesn't know what software you are running, it just loads to VDP what the CPU code tells it to. If there's a VDP conflict, it's not related to the emulation. Again, a video, please. I can press those keys but I don't know what it is SUPPOSED to do, so I can't tell if it's working for me. Show me both working and broken so I have somewhere to start. 1 Quote Link to comment Share on other sites More sharing options...
