Tursi
Classic99 Updates
Nothing to do with Classic99.... are you sure that there's actually anything being stored there? Try CALL LOAD to put a value there and then see if it comes back when you peek?
Classic99 doesn't even know when BASIC is running, and it can definitely read and write to all of scratchpad...?
Well, I ran the program, but >83A0 is never written to that I can see... the CALL PEEK is working (you can set a breakpoint of "<83A0" (break on read from 83A0) and it breakpoints as expected, but the value in memory remains 0,0.
Why do we expect that 83A0 is written to?
(I likewise put 01,02 in those bytes and they were never changed....)
Edited by Tursi
OK here is what I did, I loaded Assembly support program called STAR in DSK1 and loaded MULTI with OLD DSK1.MULTI
Wow, the memories! STAR - the first program I ever sold!
Source code of GPL and CALL INIT use this address >83A0 is the Default Data Stack, CALL LINK variables are pushed onto the stack.
What I am doing it trying to find out what is at this address to see what is pushed onto the stack and see why my RXB routine CALL LINK(address,variable) is crashing only if a variables exists?
CALL LINK(address) works exactly as it is supposed to work, but why it crashed with a single or more variables is the issue.
(You see the variables are handled in ASSEMBLY not GPL so I need to find out how....)
If I can not see what is going on there then it is virtually impossible to figure out why it fails.
Edited by RXB
hmm.. I don't know. I don't see any emulation issues. Maybe your documentation is wrong, or the conditions in which it's true aren't what we expect?
For Editor/Assembler, the manual says that >8312 is the argument count and the argument information is in low memory at >200A, with the data in a value stack in VDP memory. The "differences with the Extended BASIC loader" section notes that XB uses >8300 through >8315 for argument passing.
A quick look in TI Intern (BASIC only, I know) shows that >8372 contains the data stack pointer, and at startup, it's >9E. But in XB it's >AF, and when running I'm seeing >BA. Even running a deep BASIC program, I never see >83A0 change.
Can anyone confirm they get any value other than zero on a real TI running XB from "CALL PEEK(-31888,A)::PRINT A" ?
55
Hmm.. did I calculate the address right? (That hex->decimal->negative number always throws me.)
What was your XB doing at the time of the CALL PEEK?
CALL PEEK(-31840,A) gives 0 on a real console - also in a loop with some other CALLs.
As @Tursi indicated, CALL LINK() uses the VDP Value Stack in VRAM for parameter passing. The Value Stack Pointer is at >836E, which contains >0958 at XB startup (>06F8 for TIB). The Value Stack is 8 bytes wide.
The TI Extended Basic Assembly Language Code Programmer’s Guide says this (among other things) about CALL LINK():
The arguments are passed to the ALC subprogram through the stack in VDP RAM and the identifier list in CPU RAM. The identifier list consists of the following:
  1. >8300 – >830F Argument identifiers (one byte each; maximum of 16).
  2. >8310 Old value stack pointer.
  3. >8312 Number of arguments.
  4. >8314 Temporary storage space for subroutine name.
...lee
...lee
First off ATARIAGE sucks! I spent 25 minutes on a post and ATARIAGE just deep sixed it on some kind of site reboot?
This happens way to often and I have a very reasonable complaint on this happening on ATARIAGE site!
OK I am running STAR Assembly Support routine and looking at debugger running and nothing you posted is changing except for 2 bytes at >8300
No name change even when there are 5 CALL LINK names, no values shown even thought there are 2 and no VDP stack changes?
Additionally looking at >0958 Stack NOTHING IS HAPPENING, no changes???
AGAIN WILL TRY TO UPLOAD WHAT I AM DOING:
(Try running it and explain to me where CALL LINK is getting the names and where they are stored?)
It is not using stack as far as I can see?
DSK1.zip
Just for REFERENCE here is CALL INIT XB SOURCE CODE:
       IDT  'SUPPORTS'
*      VERSION FOR GROM
*      THIS IS THE SUPPORT FOR 9900 ASSEMBLY LANGUAGE WITH
*           EXTENDED BASIC ON THE TI 99/4.  THE CALL INIT
*           SUBPROGRAM WILL LOAD THIS ROUTINE INTO THE
*           EXPANSION RAM FROM GROM.  TO LOAD THE OBJECT
*           INTO GROM THE OBJECT MUST BE TEXT EDITED.
*           IN THE FIRST RECORD CHANGE THE DATA AFTER THE
*           "9" TAG FROM "E000" OR "2000" TO THE ADDRESS
*           DESIRED AND CHANGE THE "7" TAG TO A "8" TAG.
*      NOTE:   BSS INSTRUCTIONS CANNOT BE USED IN THIS
*              PROGRAM IN ORDER TO LOAD PROPERLY INTO GROM.
ON     EQU  1
OFF    EQU  0
DEBUG  EQU  OFF               FOR DEBUGGER ADDRESSING
*        ASMIF DEBUG=ON
* ILFA   EQU  >FFF8
* SET    EQU  >00EC
*        ASMELS
ILFA   EQU  >4000
SET    EQU  >00CE
*        ASMEND
*      SYSTEM EQUATES
SCNKEY EQU >000E
EXBASX EQU >6010              EXTENDED BASIC XML TABLES (BASE)
BYTE   EQU >830C
OLDS   EQU >8310              OLD VALUE PTR BEFORE EVALUATE SUB
*                             ARGUMENT
COUNT  EQU >8312              NUMBER OF ARGUMENT
SREF   EQU >831C
ERRCOD EQU >8322              PLACE TO RETURN ERROR CODE
BASE   EQU >8343
FAC    EQU >834A
SCTEMP EQU >8354
SCLEN  EQU >8355
SCNAME EQU >8356
FAC6   EQU FAC+6
VSPTR  EQU >836E              VALUE STACK PTR
MAXVDP EQU >8370
SNDADD EQU >83CC
STFLGS EQU >83CE
CRULST EQU >83D0
GPLWS  EQU >83E0              GPL/EXTENDED BASIC WORKSPACE
WRVDP  EQU >4000              Write enable for VDP
VDPRD  EQU >8800              VDP read data address
VDPWD  EQU >8C00              VDP write data address
VDPWA  EQU >8C02              VDP write address address
*      ERROR EQUATES
ERRNO  EQU >0200              2 Numeric Overflow
ERRSYN EQU >0300              3 Syntax Error
ERRIBS EQU >0400              4 Illegal after subprogram
ERRNGS EQU >0500              5 Unmatched quotes
ERRNTL EQU >0600              6 Name too long
ERRSNM EQU >0700              7 String-number mismatch
ERROBE EQU >0800              8 Option base error
ERRMUV EQU >0900              9 Improperly used name
ERRIM  EQU >0A00             10 Image error
ERRMEM EQU >0B00             11 Memory full
ERRSO  EQU >0C00             12 Stack overflow
ERRNWF EQU >0D00             13 NEXT without FOR
ERRFNN EQU >0E00             14 FOR NEXT nesting
ERRSNS EQU >0F00             15 Must be in subprogram
ERRRSC EQU >1000             16 Recursive subprogram call
ERRMS  EQU >1100             17 Missing subend
ERRRWG EQU >1200             18 RETURN without GOSUB
ERRST  EQU >1300             19 String truncated
ERRBS  EQU >1400             20 Bad subscript
ERRSSL EQU >1500             21 Speech string too long
ERRLNF EQU >1600             22 Line not found
ERRBLN EQU >1700             23 Bad line number
ERRLTL EQU >1800             24 Line too long
ERRCC  EQU >1900             25 Can't continue
ERRCIP EQU >1A00             26 Command illegal in program
ERROLP EQU >1B00             27 Only leagal in a program
ERRBA  EQU >1C00             28 Bad argument
ERRNPP EQU >1D00             29 No program present
ERRBV  EQU >1E00             30 Bad value
ERRIAL EQU >1F00             31 Incorrect argument list
ERRINP EQU >2000             32 Input error
ERRDAT EQU >2100             33 Data error
ERRFE  EQU >2200             34 File error
ERRIO  EQU >2400             36 I/O error
ERRSNF EQU >2500             37 Subprogram not found
ERRPV  EQU >2700             39 Protection violation
ERRIVN EQU >2800             40 Unrecongnized character
WRNNO  EQU >2900             41 Numeric overflow
WRNST  EQU >2A00             42 String truncated
WRNNPP EQU >2B00             43 No program present
WRNINP EQU >2C00             44 Input error
WRNIO  EQU >2D00             45 I/O error
WRNLNF EQU >2E00             46 Line not found
*        ASMIF DEBUG=ON
*        AORG  >E000
*        ASMELS
       AORG >2000
*        ASMEND
       DATA NAMLNK            XML LINK TO NAME LINK ROUTINE
FFA    DATA IFFA              FIRST FREE ADDRESS (FFA) POINTER
LFA    DATA ILFA              LAST  FREE ADDRESS (LFA) POINTER
HAA    DATA >AA55             CONSTANT TO SIGNAL INITIALIZED MEM.
*      UTILITY BLWP VECTORS
       DATA   UTILWS,NUMASG   NUMERIC ASSIGNMENT
       DATA   UTILWS,NUMREF   NUMERIC REFERENCE
       DATA   UTILWS,STRASG   STRING ASSIGNMENT
       DATA   UTILWS,STRREF   STRING REFERENCE
       DATA   UTILWS,XMLLNK   LINK TO SYSTEM UTILITIES
       DATA   UTILWS,KSCAN    KEYBOARD SCAN
       DATA   UTILWS,VSBW     VDP single byte write
       DATA   UTILWS,VMBW     VDP multiple byte write
       DATA   UTILWS,VSBR     VDP single byte read
       DATA   UTILWS,VMBR     VDP multiple byte read
       DATA   UTILWS,VWTR     VDP write to register
       DATA   UTILWS,ERR      Return error code to EXENDED BASIC
*      UTILITY WORKSPACE
UTILWS DATA 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
R2LB   EQU  UTILWS+5
R4LB   EQU  UTILWS+9
*      D A T A    C O N S T A N T S
CBH65  BYTE >65
EQBIT  BYTE >20
*      NAME LINK ROUTINE
*                             ALC ROUTINE NAME IN FAC
NAMLNK MOV  @LFA,R1           ADDRESS POINTER
NAML10 CI   R1,ILFA
       JEQ  NAMERR            NAME NOT FOUND
*                             TEST NEXT NAME
       MOV  R1,R0                  R0=SOURCE
       LI   R2,FAC                 R2=DESTINATION
       C    *R0+,*R2+         TEST 2 BYTES
       JNE  NAML20
       JNE  NAML20
       C    *R0+,*R2+         TEST LAST 2 BYTES
       JNE  NAML20
       MOV  *R0+,R0           NAME MATCHES GET CODE ADDRESS
       B    *R0               AND BRANCH TO IT
NAML20 AI   R1,8              NAME DOESN'T MATCH, GO TO NEXT ONE
       JMP  NAML10
NAMERR LI   R0,ERRSNF         "NOT FOUND" ERROR
*           GENERAL ERROR RETURN
ERROR  MOV  R0,@ERRCOD
ERR2   LWPI GPLWS
       B    @SET
ERR    MOV  *R13,@ERRCOD
       JMP  ERR2
*      NUMERIC ASSIGNMENT UTILITY
*        UTILITY ROUTINE NUMASG
*         A utility to allow a numeric value to be assigned
*         to a numeric variable or a numeric array passed
*         as an argument to sub.
*         The floating point variable to be assigned is in
*         FAC.
*         The stack has information for each argument.
*         For a simple numeric variable, the stack entry looks
*         like this :
*           :Pointer to    : >00 :     :Pointer to    :     :
*           :S. T. entry   :     :     :Value space   :     :
*         For a array argument, the stack entry looks
*         like this:
*           :Pointer to    :     :     :Pointer to    :     :
*           :S. T. entry   :     :     :Dim. info.    :     :
*         REGISTER USAGE
*          R0 : Array element number or zero
*          R1 : Argument number
*          R0,R1,R2,R3,R4,R5,R6,R7,R8 are used in this
*          routine
*          5 types of arguments :
*                           Identifier 0 : Numeric Expression
*                           Identifier 1 : String Expression
*                           Identifier 2 : Numeric Expression
*                           Identifier 3 : String Variable
*                           Identifier 4 : Numeric Array
*                           Identifier 5 : String Array
NUMASG MOV  *R13,R0           For the change of the work space
       MOV  @2(R13),R1        For the change of the work space
       BL   @CKARG            Check valid argument number and
********************   set up stack entry pointer in R5  *********
**** CHECK THE ARGUMENT IDENTIFIER IN CPU RAM ********************
**** A SIMPLE NUMERIC VAIABLE OR AN ARRAY REFERENCE **************
       MOV  R1,R3             Get the argument number
       DEC  R3                Offset 1
       AI   R3,>8300          For CPU address
       MOVB *R3,R3            Get the one byte identifier in
*                             CPU
       JEQ  NUERR2            Can't do the assignment to a
*                             numeric expression argument
       SRL  R3,8              Make it double
       DECT R3                Flag 2 is for NUMERIC VARIABLE
       JNE  NUM04
********* FOR ASSIGMENT TO A SIMPLE NUMERIC VARIABLE *************
       MOV  R0,R0             In this case, R0 must contain 0
       JNE  NUERR2            ERROR : BAD ARGUMENT
       MOV  R5,R3             Get the pointer to the stack entry
       INCT R3                Point to the ID byte of the
*                             stack entry
       BL   @GETV1            Get 1 byte (ID) from VDP
       JNE  NUERR1            ERROR : STRUNG NUMBER MISMATCH
       INCT R3                Point to the value space pointer
       BL   @GET1             Get the value space pointer in R1
NUM00  LI   R4,FAC            Source is in FAC
NUM01  LI   R2,8              8 bytes to copy
NUM02  MOVB *R4+,*R1+         Move ONE byte
       DEC  R2                Decrement the counter - done?
       JGT  NUM02             No - loop for more
       RTWP                   Yes - return to the caller
******** FOR ASSIGNMENT TO ONE ELEMENT OF AN ARRAY ***************
**** R0 : ARRAY ELEMENT NUMBER R5 : POINTER TO STACK ENTRY *******
NUM04  BL   @ARYBND           Check array element within boundries
*                          and fine the pointer to element in ERAM
       JMP  NUM00             Go to the general code to move
*                             from FAC to ERAM
**** CHECK VALID ARGUMENT NUMBER AND SET UP STACK ENTRY **********
****** POINTER IN R5                                   ***********
CKARG  MOV  R1,R1             Argument number can't be 0
       JEQ  NUERR2            ERROR : BAD ARGUMENT
       SLA  R1,8              Make one byte
       CB   @COUNT,R1         Valid argument?
       JLT  NUERR2            ERROR : BAD ARGUMENT
       SRL  R1,8              Make it two byte again
       MOV  R1,R5             Get the argument number
       SLA  R5,3              8 bytes per stack entry
       AI   R5,8              Skip the 8 bytes file name
*                             on top of stack
       A    @OLDS,R5          Add to the old stack pointer
*                             R5 : Pointer to the stack entry
       RT
***** CHECK THE ARRAY ELEMENT NUMBER IS WITHIN BOUNDRIES   *******
ARYBND MOV  R11,R9            Save return address
       DECT R3                Flag 4 is for ARRAY
       JNE  NUERR1            NO - Assume string argument
*                             ERROR : STRING-NUMBER MISMATCH
       MOV  R5,R3             Get the stack entry pointer
       BL   @GET1             Get the S. T. entry pointer
       MOV  R1,R3             R1 : Data register for GET1
*                             R3 : Address register for GET1
       BL   @GETV1            Get the 1st byte of S. T. entry
       JLT  NUERR1            String bit is set - ERROR
*                             STRING-NUMBER MISMATCH
       BL   @ARY1             Go through this general routine
       BL   @GET1             Get the pointer to ERAM in R1
       S    R4,R0             Check the BASE : 0 : O.K.
*                                       BASE : 1 : offset 1
       SLA  R0,3              8 bytes per element
       A    R0,R1             Add to the pointer in ERAM
       B    *R9
ARY1   MOV  R11,R10           Save RTN address
       SLA  R1,5              R1 still contains 1st buyte from
*                             func bits
       SRL  R1,13             Shift back to use as a double
******* R1 : NUMBER OF DIMENSION, R5 : STACK ENTRY POINTER *******
       MOV  R1,R8             Save number of dimension for later
       MOVB @BASE,R4          Check the BASE
       SRL  R4,8              Make it double
       JEQ  NUM08             If BASE=0, INDEX=0 -- it's o.k.
       DEC  R0                Decrement the INDEX
       JLT  NUERR3            BASE=1, INDEX=0 --- ERROR
*                             BAD SUBSCRIPT
       INC  R0                Restore INDEX
NUM08  LI   R6,1              Initial value for accumulator
       MOV  R5,R3             Put the stack entry pointer in R3
       AI   R3,4              Try to get the dim. info. pointer
       BL   @GET1             Go to get the dim. info. pointer
       MOV  R1,R3             Put it in R3
       DECT R3                For the following INCT insturction:
NUM10  INCT R3                Point to dimension information entry
*                             2-byte maximum per dimension
       BL   @GET1             Get the dimension maximum in R1
       INC  R1                BASE=0, add 1 offset
       S    R4,R1             BASE=1, O.K.
       MPY  R1,R6             Get the maximum array index
*                             R6 : accumulator
       MOV  R6,R6             First 2 bytes must be 0 here
       JNE  NUERR3            else BAD SUBSCRIPT
       MOV  R7,R6             Get last two bytes result
       DEC  R8                Decrement the counter
*                             R8 : number of dimension
       JGT  NUM10             Loop for more
       DEC  R6                BASE=0 :element number must range
*                             from 0 to (R6-1)
       A    R4,R6             BASE=0 :element number range 1 -- R6
       C    R0,R6             User's INDEX must <= maximum INDEX
       JGT  NUERR3            NO - ERROR : BAD SUBSCRIPT
       INCT R3                Points to value space which
*                             contains pointer to the beginning
*                             of array element value in ERAM
       B    *R10              RTN
NUERR1 LI   R0,ERRSNM         STRING-NUMBER MISMATCH
       B    @ERROR            Error out
NUERR2 LI   R0,ERRBA          BAD ARGUMENT
       B    @ERROR            Error out
NUERR3 LI   R0,ERRBS          BAD SUBSCRIPT
       B    @ERROR            Error out
*      NUMERIC REFERENCE UTILITY
*        UTILITY ROUTINE NUMREF
*         A utility to allow reference to a numeric expression,
*         numeric variable or a numeric array passed
*         The floating point variable assigned will be
*         in FAC after calling NUMREF.
*         like this :
*         For a array reference, the stack entry looks
*         like this:
*         For a numeric expression, the stack entry has the
*         8 bytes floating points value come back from
*         a parse.
*         REGISTER USAGE
*          routine
NUMREF MOV  *R13,R0           For the change of the work space
*                             and set up stack pointer
******  R5 : Pointer to the stack entry, R1 : Argument number. ***
******** CHECK THE ARGUMENT IDENTIFIER IN CPU RAM ****************
**** A NUMERIC EXPRESSION, SIMPLE NUMERIC VARIABLE OR AN ARRAY ***
       DEC  R3                Offset 1
*                             CPU
       JNE  REF00             Not a numeric expression
**** A NUMERIC EXPRESSION, MOVE THE 8 BYTES STACK ENTRY **********
**** FROM VDP TO FAC.                                   **********
       MOV  R0,R0             R0 in this case must contain 0
       JNE  RFERR2            ERROR : BAD ARGUMENT
       LI   R2,8              8 bytes to move
       LI   R4,FAC            Destination address
       MOV  R5,R3             Source address : stack entry pointer
REF03  BL   @GET1             Get 2 bytes from VDP
       MOV  R1,*R4+           Put 2 bytes in FAC
       INCT R3                Update source address
       DECT R2                Update the counter
       JGT  REF03             More to move
       RTWP                   Return to caller
********** SIMPLE NUMERIC VARIABLE OR AN ARRAY *******************
REF00  DECT R3                Flag 2 is for NUMERIC VARIABLE
       JNE  REF04             NO - go to the code for array
****** FOR REFERENCE TO A SIMPLE NUMERIC VARIABLE ****************
*                             stack entry
*                             Numeric ID byte must be 0
       JNE  RFERR1            ERROR : STRING-NUMBER MISMATCH
REF01  MOV  R1,R4             Put the source address in R4
*                             for the "general move" code
       LI   R1,FAC            Desination address is in FAC
       B    @NUM01            Goto the "general move" code and
*                             return to caller
****** FOR ASSIGNMENT TO ONE ELEMENT OF AN ARRAY *****************
****** R0 : ARRAY ELEMENT NUMBER, R5 : POINTER TO STACK ENTRY ****
REF04  BL   @ARYBND           Check array element is within bounds
*                and find the pointer to the array element in ERAM
       JMP  REF01             Go to the general code to move
*                             from ERAM to FAC
RFERR1 B    @NUERR1           STRING-NUMBER MISMATCH
RFERR2 B    @NUERR2           BAD ARGUMENT
*      STRING ASSIGNMENT UTILITY
*        UTILITY ROUTINE STRASG
*         A utility to allow a string to be assigned to a
*         sting variable or one element of an string variable
*         array passed as an argument to subpro.
*         For a string variable, the stack entry looks
*         like this :
*           :Pointer to    : >65 :     :Pointer       :string:
*           :Value space   :     :     :to sting      :length:
*         For a string array, the stack entry looks like this:
*         USER'S REGISTER USAGE
*          R2 : String address in ERAM, (the first byte
*          of the string is the length of the string.)
*          THIS ROUTINE REGISTER USAGE
*          R0 : Always is the string address in ERAM
*               except when routine ARY1 is called,
*               then has the array element number.
*          R0, R1, R2, R3, R4, R5, R6, R7, R8, R9, R10 are used in
*          this routine
*         UTILWS workd space usage
*          UTILWS     : Array element provided by user
*          UTILWS+2   : RTN address for VGASSN
*          UTILWS+4   : Temporary place for R5 when VPUSH,
*                       GETSTR, ASSGNV are called.
*          UTILWS+6   : Temporary place for @BYTE when
*                       GETSTR is called.
*          UTILWS+8   : RTN address for GPL
*          UTILWS+12  : String address in ERAM provided by user
STRASG MOV  *R13,@UTILWS      Array element from user
       MOV  @2(R13),@GPLWS+2  For change of work space
*                             Argument number provided by user
       MOV  @4(R13),@UTILWS+12 String address probided by user
       LWPI GPLWS             Load GPL work space registers
*                             which has string information
*                             address in VDP
       MOV  R11,@UTILWS+8     RTN address for back to GPL
       MOV  @UTILWS+12,R0     ERAM string address is in R0 now
       BL   @CKARG            Check valid argument number and set
*                             up pointer to stack entry in R5
       MOV  R1,R3             Get argument number
       DEC  R3                Offset 1
*                             CPU
       SRL  R3,8              make it double
       DEC  R3                Check if string expression
       JEQ  STERR2            Can't do the assignment to a
*                             string expression argument
       DECT R3                Flag 3 is for string variable
       JNE  STARY             NO : Is STRING ARRAY ?
******* ASSIGMENT TO STRING VARIABLE *****************************
       MOV  @UTILWS,R10       In this case : array element
*                             has to be 0
       JNE  STERR2            ERROR : BAD ARGUMENT
       MOV  R5,R3             Address register for GETV1
*                             stack entry
       CB   R1,@CBH65         Is this a string variable ?
       JNE  STERR1            No - STRING-NUMBER MISMATCH ERROR
**** PUSH THIS STACK ENTRY ON TOP OF THE STACK FOR ***************
**** ROUTINE "ASSGNV" TO USE                       ***************
**** MOVE THIS STRING VARIABLE ENTRY TO CPU FAC AREA *************
**** IN ORDER TO DO A VPUSH                          *************
       LI   R6,8              Number of bytes to move
       LI   R4,FAC            Destination address in CPU
       MOV  R5,R3             Restore stack entry pointer
*                             R3 : address register for GET1
STR02  BL   @GET1             Get 2 bytes from VDP
       MOV  R1,*R4+           Put to FAC area
       DECT R6                Update the counter
       JGT  STR02             More to move
***** DO THE VPUSH, GETSTR, COPY STRING TO STRING SPACE **********
***** AND ASSIGNMENT                                    **********
       BL   @VGASSN
********* NOW UPDATES THE STACK ENTRY OF THIS ********************
********* STRING VARIABLE                     ********************
********* R5 STILL POINTS TO THE OLD STACK ENTRY *****************
********* FOR THIS STRING VARIABLE               *****************
       AI   R5,4              "POINTER TO STRING" entry
       MOV  R5,R4             Address register for PUT1
       MOV  R6,R1             Put the pointer to string
*              (come back from ASSGNV) into data register for PUT1
       BL   @PUT1             Put 2 bytes of data to VDP
       INCT R4                "LENGTH OF STRING" entry
       MOVB *R0,R1            Put the length into data register
       SRL  R1,8              Make it two bytes
STRTN  MOV  @UTILWS+8,R11     Restore RTN address
       MOV  @UTILWS+6,@BYTE   Restore @BYTE
       LWPI UTILWS            Go back to old workspace
       RTWP                   Return
STERR1 LI   R0,ERRSNM         STRING-NUMBER MISMATCH
ERRTN  MOV  @UTILWS+8,R11     Restore RTN address
       B    @ERROR
STERR2 LI   R0,ERRBA          BAD ARGUMENT
       B    @ERROR            Error return
************* Common routine for STRASG & STRREF to check
************* valid array element
STARYC MOV  R11,R2            Save RTN address
       DECT R3                Flag 5 is for string array
       JNE  STERR1            ERROR : STRING-NUMBER MISMATCH
       BL   @GET1             Get the S.T. entry pointer
       BL   @GETV1            Get the 1st byte of S.T. entry
       JLT  STARY1            O.K.
       B    @STERR1           ERROR : STRING-NUMBER MISMATCH
STARY1 MOV  @UTILWS,R0        Put array element in R0 now
*                             for the general routine ARY1
       BL   @ARY1             Go through general routine to
*                             check array element is out of bound
* R4 : BASE, R0 : ARRAY ELEMENT, R3 : POINTER TO BEGINNING OF
*                                     VALUE SPACE
*                                       BASE : 1 : Offset 1
       SLA  R0,1              2 bytes per element
       A    R0,R3             Pointer to the exact element we want
       BL   @GET1             Get the string pointer
       B    *R2               RTN
STARY  BL   @STARYC           Go through general routine
*                             shared by STRREF
*   NOW R1 : POINTER TO THE OLD STING
*       R3 : POINTER TO THE VALUE SPACE
*** SET UP FAC ENTRY AND PUSH IT ON STACK FOR ASSIGN ROUTINE *****
       LI   R6,FAC            Desination address
       MOV  R3,*R6+           Put pointer to value space in
       MOVB @CBH65,*R6+       Put >65 ID in
       MOVB R4,*R6+           Clear the unuse byte
       MOV  R1,*R6+           Put the pointer to string in
       MOV  R1,R3             Set up address register for GETV1
       JNE  STARY4            Not null pointer : o.k.
       CLR  *R6               Clear the length bytes
       JMP  STARY6            Go on
STARY4 DEC  R3                Point to string length
       BL   @GETV1            Get the length from VDP
       MOV  R1,*R6            Put the length in FAC area
***** FAC ENTRY HAS BEEN SET UP NOW ******************************
STARY6 MOV  @UTILWS+12,R0     Restore the ERAM string address
*                             to R0
       BL   @VGASSN           Do the VPUSH, GETSTR and ASSIGN
***** ASSIGNMENT WILL POP THE STACK, OLD STACK ENTRY *************
***** DOES NOT NEED TO BE UPDATED IN THIS CASE       *************
       B    @STRTN            RTN
VGASSN MOV  R11,@UTILWS+2     Save return address
***** VPUSH changed R0, R5    ************************************
       MOV  R5,@UTILWS+4
       MOV  @>601E,R11        XML table address for VPUSH
       BL   *R11              Do the VPUSH
********* RESTORE R0, R5 *****************************************
       MOV  @UTILWS+12,R0
       MOV  @UTILWS+4,R5
**** GETS THE STRING SPACE, COPIES THE STRING FROM ERAM **********
**** INTO VDP STRING SPACE, AND SETS UP THE FAC WITH A  **********
**** STRING ENTRY OF THE FOLLOWING FORM:                **********
**** : >001C : >65 : XX : POINTER   : LENGTH    :       **********
**** :       :     :    : TO STRING : OF STRING :       **********
**** FAC    +2    +3   +4          +6                   **********
       MOVB *R0,R6            R0 : Address of string (length by
*                             & string) supplies by ALC
       SRL  R6,8              Set up the length byte
       MOV  @BYTE,@UTILWS+6   Save @BYTE
       MOV  R6,@BYTE          For GETSTR routine
       MOV  R6,@FAC6          Set up length byte entry in FAC
*********** GETSTR changes R0, R5 value *************************
       MOV  @>6012,R11        XML table address for GETSTR
       BL   *R11              Call GETSTR routine
       MOV  @UTILWS+12,R0     Restore R0
*********** SET UP FAC ENTRY ************************************
       LI   R6,FAC            Optimize to save bytes
       LI   R4,>001C          Get address of SREF
       MOV  R4,*R6+           Indicate a temporary string
       MOVB @CBH65,*R6+       Indicate a string
       MOVB R4,*R6+           Byte is not used
       MOV  @SREF,*R6         Save pointer to the string
*********** COPY THE STRING TO STRING SPACE *********************
       MOV  @BYTE,R2          Get number of bytes to copy
       JEQ  STR04             If none to copy
       MOV  *R6,R4            Get pointer to destination
*                         R4 : address register for PUTV1 below
       MOV  R0,R3         RO : pointer to string (length byte)
       INC  R3            Skip the length byte pointer to string
STR06  MOVB *R3+,R1           Get one byte from ERAM
       BL   @PUTV1            Put 1 byte in VDP
       INC  R4                Update the destination address
       DEC  R2                1 less to move
       JGT  STR06             If not done-loop for more
*                             ASSGNV destroys all the registers
STR04  MOV  @>6028,R11        XML table address for ASSGNV
       BL   *R11              Call ASSGNV
******** RESTORE R0, R5 ******************************************
       MOV  @UTILWS+12,R0
       MOV  @UTILWS+4,R5
       MOV  @UTILWS+2,R11     Restore RTN address
       RT
*      STRING REFERENCE UTILITY
*        UTILITY ROUTINE STRREF
*         A utility to allow a reference to a string expression,
*         sting variable or a string array passed as an
*         argument to a subprogam.
*         For a string expression, the stack entry looks
*         like this :
*           :  >001C       : >65 :     :              :      :
*           :or Pointer to :     :     :Pointer       :String:
*           :Value space   :     :     :to sting      :Length:
*           >001C : For a temporary string
*           pointer to value space : for a perment string
*         For a string variable, the stack entry looks like this:
*           :Pointer to    : >65 :     :Pointer to    :String:
*           :S. T. entry   :     :     :String        :Length:
*           :Value space   :     :     :Dimension info:      :
*          Before calling STRREF : The string length has
*          the maximum length which indicates how many
*          spaces followed the length byte has been
*          allocated for the string.
*          After calling STRREF : The length byte has
*          the actual length of the string which
*          locates right after the length byte.
STRREF MOV  *R13,R0           For the change of the work space
*                             Array element now is in R0
*                             Argument number is in R1
*                             set up pointer to stack entry in R5
       DEC  R3                Offset 1
       MOVB *R3,R3            Get one byte identifier in CPU
       DEC  R3                Flag 1 is for string expression
       JEQ  SRF01             String expression is o.k.
       JNE  STARYF            Not string expression or variable,
*                             must be string array in this case.
********** REFERENCE TO STRING EXPRESSION OR STRING VARIABLE *****
SRF01  MOV  R0,R0             R0 must be 0 in this case
       JNE  SRFER2            ERROR : BAD ARGUMENT
       MOV  @4(R13),R0        Now move string pointer in ERAM
*                             into R)
*                             stack entry
       CB   R1,@CBH65         Is this a string varialbe ?
       JNE  SRFER1            No - STRING-NUMBER MISMATCH ERROR
       INCT R3                Points to "pointer to string"
       BL   @GET1             Get the "pointer to string" from
*                             stack entry in VDP
SRF03  MOV  R1,R1             Is it null pointer ?
       JEQ  SRF05             Yes - put 0 in length byte
       MOV  R1,R6             R6 now contains "pointer to string"
       DEC  R1                Points to the length byte of
*                             this string in string space
       BL   @GETV1            Get the 1 byte actual length
*                             of this string in R1
       CB   *R0,R1            Compare the maximem length user
*                             provided with the actual length
       JL   SRFER3            Not enough space - ERROR
*                             STRING-TRUNCATED ERROR
SRF05  MOVB R1,*R0+           Enough space - o.k.
*                             Put the actual length into the
*                             length byte
       JEQ  SRF08             0 byte length - don't move
******** R0 : Points to the allocated string space in ERAM *******
*                             Destination address register for the
*                             following move
       MOV  R6,R3             Set up address register for GETV1
*                             R3 now cantains "pointer to string"
*                             Source address for following move
       SRL  R1,8              Make actual length byte a double
       MOV  R1,R5             R5 : number of bytes to move
SRF07  BL   @GETV1            Get 1 byte into VDP
       MOVB R1,*R0+           Put 1 byte into ERAM
       INC  R3                Update the source address
       DEC  R5                Update the counter
       JGT  SRF07             More to move - loop back
SRF08  RTWP                   Return to caller
************ REFERENCE TO STRING ARRAY ***************************
STARYF BL   @STARYC           Check array element is within bound
*               and find the string element pointer in value space
       MOV  @4(R13),R0        Put string address in ERAM provided
*          by the user into R0 now. (for the change of work space)
       JMP  SRF03             Go to the general code to move
*                             the string from VDP to ERAM
SRFER1 B    @NUERR1           STRING-NUMBER MISMATCH
SRFER2 B    @NUERR2           BAD ARGUMENT
SRFER3 LI   R0,ERRST          STRING TRUNCATED
       B    @ERROR            Error out
***    UTILITY ROUTINES TO ACCESS VDP                         ****
***** GET1 : Get two bytes of data from VDP
*****        R3 : Address in VDP
*****        R1 : Where the two bytes data stored
GET1   SWPB R3
       MOVB R3,@VDPWA
       SWPB R3
       MOVB R3,@VDPWA
       NOP
       MOVB @VDPRD,R1
       SWPB R1
       MOVB @VDPRD,R1
       SWPB R1
       RT
***** PUT1 : Put tow bytes of data into VDP
*****        R4 : Address on VDP
*****        R1 : Data
PUT1   SWPB R4
       MOVB R4,@VDPWA
       SWPB R4
       ORI  R4,WRVDP
       MOVB R4,@VDPWA
       NOP
       MOVB R1,@VDPWD
       SWPB R1
       MOVB R1,@VDPWD
       SWPB R1
       RT
***** GETV1 : Get 1 byte of data from VDP
*****         R1 : Where the 1 byte data stored
GETV1  SWPB R3
       MOVB R3,@VDPWA
       SWPB R3
       MOVB R3,@VDPWA
       NOP
       MOVB @VDPRD,R1
       RT
***** PUTV1 : Put 1 byte of data into VDP
*****         R4 : Address in VDP
*****         R1 : Data
PUTV1  SWPB R4
       MOVB R4,@VDPWA
       SWPB R4
       ORI  R4,WRVDP
       MOVB R4,@VDPWA
       NOP
       MOVB R1,@VDPWD
       RT
*      LINK TO SYSTEM XML UTILITIES
XMLLNK MOV  *R14+,@GPLWS+2    GET ARGUMENT
       LWPI GPLWS
       MOV  R11,@UTILWS+22    Save GPL return address
       MOV  R1,R2
       CI   R1,R2
       JH   XMLL30            IF SYSTEM XML WE HAVE ADDRESS
       MOV  @EXBASX(R1),R2    Get address from XML table
       CI   R1,4              Is it MEMCHK?
       JNE  XMLL30            No
       MOV  @2(R2),R2
       BL   *R2               Special case for MEMCHK
       DATA MEMERR            Error return from MEMCHK
       JMP  XMLL40
XMLL30 BL   *R2               GO TO ROUTINE
XMLL40 LWPI UTILWS            GET BACK TO RIGHT WORKSPACE
       MOV  R11,@GPLWS+22     Restore GPL return address
       RTWP
MEMERR LI   R0,ERRMEM
       B    @ERROR
*      KEYBOARD SCAN
KSCAN  LWPI GPLWS
       BL   @SCNKEY
       LWPI UTILWS
       RTWP
**     VDP single byte write
VSBW   BL   @WVDPWA           Write out address
       MOVB @2(R13),@VDPWD    Write data
       RTWP                   Return to calling program
**     VDP multiple byte write
VMBW   BL   @WVDPWA           Write out address
VWTMOR MOVB *R1+,@VDPWD       Write byte
       DEC  R2                Decrement byte count
       JNE  VWTMOR            More to write?
**     VDP single byte read
VSBR   BL   @WVDPRA           Write out address
       MOVB @VDPRD,@2(R13)    Read data
**     VDP multiple byte read
VMBR   BL   @WVDPRA           Write out address
VRDMOR MOVB @VDPRD,*R1+       Read byte
       JNE  VRDMOR            More to read?
**     VDP write to register
VWTR   MOV  *R13,R1           Get register number and value
       MOVB @1(R13),@VDPWA    Write out value
       ORI  R1,>8000          Set for register write
       MOVB R1,@VDPWA         Write out register number
**     Set up to write to VDP
WVDPWA LI   R1,>4000
       JMP  WVDPAD
**     Set up to read VDP
WVDPRA CLR  R1
**     Write VDP address
WVDPAD MOV  *R13,R2           Get VDP address
       MOVB @R2LB,@VDPWA      Write low byte of address
       SOC  R1,R2             Properly adjust VDP write bit
       MOVB R2,@VDPWA         Write high byte of address
       MOV  @2(R13),R1        Get CPU RAM address
       MOV  @4(R13),R2        Get byte count
       RT                     Return to calling routine
*      >24EA to >24F3 are not used (10 bytes unused)       *
IFFA   EQU  >24F4          INITIAL VALUE FOR FFA FOR INIT
       END
Sold? I've spent over 30 years on RXB (Rich GK XB originally) and I think I made in total $98.00 in total.
Multiple versions of carts made and sold not to mention GK or GRAMLUATOR versions and that is my total net.
Edited by RXB
When I run this:
10 CALL INIT
20 CALL LINK("RASMUS")
the value "RASMUS" can be found at >082A in VDP RAM. You also get a SUBPROGRAM NOT FOUND error, of course.
Quick question: is there a way to disable ALT-F4 when using classic 99 in a windows environment? I find myself accidentally using that combination which closes Classic99 immediately, without warning. I am probably mixing my muscle memories - on the Geneve I use the a AT keyboard F4 key while on the real TI I use FCTN-4 - and have not been able to untrain myself. In the meantime, i have re-written some XB code now at least three times, with the silver lining being it is much more efficient now ;)
We must be looking at the wrong thing, cause 83A0 is not listed in there...
I did that yesterday for the first time! I am quite proud of the creative string of profanity that followed. :)
But at the moment... no. Alt-F4 sends a window close command, it's the same as clicking the 'X' on the window. I could probably add a keyboard check, or just a simple "exit?" prompt, but right now my Classic99 build is a little broken so I can't make quick changes. :/
  • Like 5
I've done it too!
I did it yesterday
I did it today! Luckily, I was using Win994a. :)...
My favorite is when the palm of my hand grazes
the mouse pad on my laptop hitting the upper right hand corner x :waving: PROGRAM...
Edited by HOME AUTOMATION
I just turned to my real TI and let the speech synthesizer spit out some garbled profanity-sounding noises ;)
I searched for programs that could disable ALT-F4 and came up with one called AutoHotKey that supposedly can be set up to intercept keypresses and re-assign them to another function. I will play around with it when I get back home tonight. Best of luck fixing the build!
AutoHotKey is a great program. I use it all the time on my work PC for quick shortcuts for keypresses.
