SlowCoder #1 Posted August 3, 2010 I thought about using a fine sandpaper. If I did, I'm sure it would shine up nice. But what to do to keep the oxidation of the newly exposed metal down? Other options? Quote Share this post Link to post Share on other sites
fiddlepaddle #2 Posted August 3, 2010 Silicon spray, let dry, wipe. Quote Share this post Link to post Share on other sites
A.J. Franzman #3 Posted August 3, 2010 Polishing 2600 toggle switches? They're slide switches, not toggle switches (a toggle switch's lever pivots inside the switch body, while a slide... slides). Any clear durable spray product should keep corrosion at bay for a while. Krylon Triple Thick may have an edge in durability. Quote Share this post Link to post Share on other sites
tremoloman2006 #4 Posted August 4, 2010 I just use 0000 Steel Wool. Spin a piece around a switch a few times and it looks as good as new! Quote Share this post Link to post Share on other sites
tetrode kink #5 Posted August 4, 2010 Hey trem, not that I disagree with you, but why would you, when advising the use of steel wool, provide a picture of shredded wheat biscuits??? -tet Quote Share this post Link to post Share on other sites
SlowCoder #6 Posted August 4, 2010 I ended up using a green Scotch scouring pad and it worked great. Quote Share this post Link to post Share on other sites
