w1k #1 Posted August 12, 2010 (edited) fuuuuh.. my sio2sd is dead.. yesterday i flash firm to 2.5 - everythinhgs ok. today i turn it, and only red lcd, and red diode.. what can be broken? edit: today i try SYSINFO and disk drive info/testing.. hmm.. that was last when i load, then i turn off atari edit2: yellow diode very low flash (1x/sec) Edited August 12, 2010 by w1k Quote Share this post Link to post Share on other sites
HiassofT #2 Posted August 12, 2010 fuuuuh.. my sio2sd is dead.. Could be the quite common brownout-detector/fuse-bits problem. Try re-programming the ATMEL with an ISP cable and be sure to set the low fuse byte to 0x3f instead of 0xff. Read more about it here. so long, Hias Quote Share this post Link to post Share on other sites
w1k #3 Posted August 12, 2010 i have not a programmer, that the problem Quote Share this post Link to post Share on other sites
lbaeza #4 Posted August 13, 2010 Look here: http://www.atariage.com/forums/topic/65784-sio2sd/page__st__225__p__1654599#entry1654599 Regards Quote Share this post Link to post Share on other sites
w1k #5 Posted August 14, 2010 that connector/flasher.. can i burn any content do eprom? maybe new q-meg, etc for atari? Quote Share this post Link to post Share on other sites
