Sign in to follow this
jbaudrand
joyfire with sound
I'm trying to add sound in a little game,
if joy0fire then missile0y=player0y-2:missile0x=player0x+4:AUDV0=8:AUDC0=4
 p=p+1
 if p=10 then AUDC0=0
:/ I though the counter will be in frame, but it's too long, it plays during 3-4 seconds, so I wonder what is my mistake.
any idea?
Try adding a ":P=0" to the end of your if statement.
Without it "p" will be some value from 0-255 when the fire button is pressed.
Edited by RevEng
Thanks, it's working better but I'm still trying to understand how it works: because when I set if p=2 then AUDC0=0, the sound stay as long as the missile is on screen, very strange
test sound.bas
The problem in a nutshell, is that if missile0y<=240 then you're always skipping the bit of code that increments your sound timer and turns off the sound when it reaches 2.
If you move that bit of code above your missile0y check, so it's executed each frame, then everything works out...
*** EXISTING CODE
 if missile0y>240 then goto skip
 missile0y = missile0y-2:goto drawlooping
skip
 if joy0fire then missile0y=player0y-2:missile0x=player0x+4:AUDV0=4:AUDC0=3:p=0
 p=p+1
 if p=2 then AUDC0=0
drawlooping
*** NEW CODE
 p=p+1
 if p=2 then AUDC0=0
skip
*** EXISTING CODE
skip
 p=p+1
 if p=2 then AUDC0=0
drawlooping
*** NEW CODE
 p=p+1
 if p=2 then AUDC0=0
skip
ooh thanks, the logic in programming is merciless..
