Sign in to follow this
Sega Dude
Making my first Atari game and I got a compile error...
Im making my first atari game with Visual bB. I was coding the position of the sprits and I got a compile error. It looks fine to me I don't know why it won't compile.Heres my code: (Scroll down for error)
 rem Generated 8/21/2010 9:59:27 AM by Visual bB Version 1.0.0.548
rem **********************************
rem *<filename>                      *
rem *<description>                   *
rem *<author>                        *
rem *<contact info>                  *
rem *<license>                       *
playfield:
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
end
COLUBK= $B6
COLUPF = 212
player0x=50:player0y=50
player1x=20:player1y=20
player0:
111000
%01111100
%01111100
010000
010000
111000
%01111100
%01111100
end
player1::
%01100110
%01101100
%01111101
110010
%01011101
%01001000
001000
111100
end
draw_loop
drawscreen
goto draw_loop
This is the error:
Thanks for your help!
I don't know exactly what is going on thar but I noticed
 player1::
should probably be
 player1:
and the
playfield:
should have a space so it isn't a label
 playfield:
It should look like this, though when you copy pasted your character its messed. This code will display both your characters at different positions. Your problem was placement of code and missing code. You could instead of using dim p1x and dim p1y just use the same as player0 but then they would be right on top of each other when you start the game. You always need to put spaces before most code for it to work.
x=50
y=50
dim p1x=100
dim p1y=100
main
playfield:
end
COLUBK=$B6
COLUPF=212
player0x=50
player0y=50
player0:
%00111000
%01111100
%01111100
%00010000
%00010000
%00111000
%01111100
%01111100
end
player1x=p1x
player1y=p1y
player1:
%01100110
%01101100
%01111101
%00110010
%01011101
%01001000
%00001000
%00111100
end
drawscreen
goto main
Edited by endrien
x=50
y=50
dim p1x=100
dim p1y=100
main
playfield:
end
COLUBK=$B6
COLUPF=212
player0x=50
player0y=50
player0:
111000
%01111100
%01111100
010000
010000
111000
%01111100
%01111100
end
player1x=p1x
player1y=p1y
player1:
%01100110
%01101100
%01111101
110010
%01011101
%01001000
001000
111100
end
drawscreen
goto main
Thanks endrien! It works now!!
No problem, any other questions I'm sure we've got an answer for. All you have to do is ask :).
