+Gemintronic #1 Posted August 28, 2010 (edited) For some reason the first row get the last rows colors. set smartbranching on set romsize 4k set kernel_options pfheights pfcolors COLUBK = $00 scorecolor = $0E pfheights: 4 26 16 26 4 2 2 2 2 2 2 end pfcolors: $33 $33 $33 $33 $33 $33 $8E $8E $8E $8E $8E end playfield: XXXXXXXXXXXXX....XXXXXXXXXXXXXXX X..............................X ................................ X..............................X XXXXXXXXXXXXX....XXXXXXXXXXXXXXX ................................ XX..XXX.XXX..XX.XXX.XXX.XX..XXX. X.X.X.X..X..X....X..X.X.X.X.X... XXX.X.X..X...X...X..X.X.X.X.XX.. X...X.X..X....X..X..X.X.X.X.X... X...XXX.XXX.XX..XXX.XXX.X.X.XXX. end main drawscreen goto main Edited August 28, 2010 by theloon Quote Share this post Link to post Share on other sites
Cliff Friedel #2 Posted August 28, 2010 If you throw in a 12th line on the pfcolors definition, it should change that first row to that color. It has to do with the fact that there are 96 rows for the playfield, even though bB only uses 88. At least I think that is how it goes. Try using no_blank_lines and see if that changes it as well. If you look at the bug thread, you can see us talking about it. It may apply to that as well. Hope this helps. Cliff Quote Share this post Link to post Share on other sites
PAC-MAN-RED #3 Posted August 28, 2010 Another fix for this was mentioned here Quote Share this post Link to post Share on other sites
Cliff Friedel #4 Posted August 28, 2010 Another fix for this was mentioned here That won't work as that wasn't for the playfield, it was for the background using the background kernel option. If you do that for a normal playfield, it won't change the playfield color, it will make the entire background the color of COLUBK. The first line will still be wrong. Cliff Quote Share this post Link to post Share on other sites
+Gemintronic #5 Posted August 28, 2010 (edited) If you throw in a 12th line on the pfcolors definition, it should change that first row to that color. It has to do with the fact that there are 96 rows for the playfield, even though bB only uses 88. At least I think that is how it goes. Try using no_blank_lines and see if that changes it as well. If you look at the bug thread, you can see us talking about it. It may apply to that as well. Hope this helps. Cliff Hey! Thanks for the help! PAC-MAN-RED too as that topic was educational as well. The workaround seems to be adding an extra line to the top of the playfield data and adding a corresponding pfheights. Adding a pfcolors line doesn't seem to efffect it. I still consider this color wrap-around issue a bug (albeit with workarounds). Just have to watch out for it in the future Edited August 28, 2010 by theloon Quote Share this post Link to post Share on other sites
Cliff Friedel #6 Posted August 28, 2010 (edited) Hey! Thanks for the help! PAC-MAN-RED too as that topic was educational as well. The workaround seems to be adding an extra line to the top of the playfield data and adding a corresponding pfheights. Adding a pfcolors line doesn't seem to efffect it. I still consider this color wrap-around issue a bug (albeit with workarounds). Just have to watch out for it in the future You are right. I remembered having to add a line to one of them, I just couldn't remember which one =) Should have wrote something up. Glad you got it fixed though. Cliff Edited August 28, 2010 by Cliff Friedel Quote Share this post Link to post Share on other sites
+Random Terrain #7 Posted August 28, 2010 (edited) Another fix for this was mentioned here That's the simplest fix when used in the foreground. Put COLUPF in your main loop and have it be the color of your top row. Problem solved. Edited August 28, 2010 by Random Terrain Quote Share this post Link to post Share on other sites
+Random Terrain #8 Posted August 28, 2010 I just updated the pfcolors section: http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#kernop_pfcolors You may need to refresh the page or clear your cache to see the changes. Quote Share this post Link to post Share on other sites
PAC-MAN-RED #9 Posted August 28, 2010 Another fix for this was mentioned here That won't work as that wasn't for the playfield, it was for the background using the background kernel option. If you do that for a normal playfield, it won't change the playfield color, it will make the entire background the color of COLUBK. The first line will still be wrong. Cliff It was a caffeine deficient morning stupor. New rule: Coffee first, than answer questions. Quote Share this post Link to post Share on other sites
+Random Terrain #10 Posted August 28, 2010 I just updated the pfcolors section: http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#kernop_pfcolors You may need to refresh the page or clear your cache to see the changes. Updated that section one more time: http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#kernop_pfcolors Does that handle everything or did I forget something? Quote Share this post Link to post Share on other sites
PAC-MAN-RED #11 Posted August 29, 2010 (edited) Looks good to me... although picture examples along with the code would be awesome, but a lot more work too. It would be just like the forums, and to save some work, users could contribute their code snippets and pictures. Just thinking... Edited August 29, 2010 by PAC-MAN-RED Quote Share this post Link to post Share on other sites
+batari #12 Posted August 29, 2010 I think that all you need to do is put your pfcolors definition in the game loop. If it's outside of the game loop, the top line will not be updated every frame. If you want it outside the game loop, setting COLUPF manually works as mentioned above. Quote Share this post Link to post Share on other sites
+Random Terrain #13 Posted August 29, 2010 I think that all you need to do is put your pfcolors definition in the game loop. If it's outside of the game loop, the top line will not be updated every frame. If you want it outside the game loop, setting COLUPF manually works as mentioned above. Thanks. I'll update the page again. Quote Share this post Link to post Share on other sites
+Random Terrain #14 Posted August 29, 2010 (edited) I think that all you need to do is put your pfcolors definition in the game loop. If it's outside of the game loop, the top line will not be updated every frame. If you want it outside the game loop, setting COLUPF manually works as mentioned above. I was playing with test code and that works for the playfield, but putting it in the main loop doesn't seem to work when you use background. It does work if you use no_blank_lines with background, though. Edited August 29, 2010 by Random Terrain Quote Share this post Link to post Share on other sites
+Random Terrain #15 Posted August 29, 2010 (edited) Updated it again: http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#kernop_pfcolors As usual, you may need to refresh the page or clear your cache. Edited August 29, 2010 by Random Terrain Quote Share this post Link to post Share on other sites
