thegamezmaster
Atari Lynx AC Adapter Question
Newbie Atari Lynx owner here. Just got a Lynx II with no power supply. System works on batteries and was wondering is there any other power supply from a different handheld work with it? Got a whole box of different ones but not sure where to go from there. Anyone help as to what else will work. Searched the web but couldn't find a definative answer. Thanks.
Was going to post a nmew topic on here, but this post works...
I was wondering along these same lines.
I know the voltage: 9vdc, 1a.
I know the center pin is positive.
I was wondering if someone could give me the plug diamater.
I've seen some out there for 2.1mm and 2.5mm , wondering if they would work.
Thanks in advance for any help.
I was looking on the Lynx II and on the case it says 9 volts DC 3.0 W. Was looking at ac adapters on ebay and the atari one's say output is 9 volts dc 1.0 amp. Why the difference?
I tried two standard universal power supplies today. One was a Jensen set at 9V center positive (600mA) and it works fine. Tried another generic at 9V center positive (500mA) and that works fine too!
I am pretty certain most universals with a 500mA and above rating (not to exceed 1A) set at 9V with center (tip) positive (VERY IMPORTANT) will work just fine. The Jensen is available at any Best Buy location.
You can go above 1A, it's 9V that mustn't be exceeded.
I use a 7.5V transformer, but it's plugged to the batteries contacts, not the normal psu socket.
