jbs30000
Quick yes or no question on variable arrays
I don't know for sure, but I thought arrays were read-only with bB:
http://www.randomterrain.com/atari-2600-memories-batari-basic-commands.html#dataarrays
[quote name='jbs30000' date='Sat Oct 16, 2010 2:48 AM' timestamp='1287211696' post='2116064']
It's been a while since I've done this so I figured I'd better double check because my memory is crap.
If I go
dim MyArray=a
Then MyArray[0] is a and MyArray[1] is b, correct?
[/quote]
Yes, that's right. The number in square brackets is the offset to the starting address, so an offset of 0 gives you the starting address (a). The assembly equivalent is
[code]
; MyArray[0]
LDX 0
LDA MyArray,X
; MyArray[1]
LDX 1
LDA MyArray,X
[/code]
Michael
[quote name='Random Terrain' date='Sat Oct 16, 2010 7:31 AM' timestamp='1287228675' post='2116115']
[/quote]
If you dim an array to ROM, it will be a read-only array. But if you dim an array to RAM, it will be a read/write (variable) array.
Note that if you dim an array to expansion RAM that requires separate read and write addresses, you'll need to either dim the array twice-- once for writing, and once for reading-- or you'll need to modify the index as needed if the expansion RAM is small enough.
For example:
[code]
rem dim a Superchip array for writing and reading
dim w_MyArray=$F000
dim r_MyArray=$F080
w_MyArray[12]=rand
w_MyArray[12]=r_MyArray[12]+1
[/code]
[code]
rem modify the index instead of dimming twice
dim MyArray=$F000
rem use index 0 to 127 for writing
rem use index 128 to 255 for reading
MyArray[12]=rand
MyArray[12]=MyArray[140]+1
[/code]
In the second example, note that 140=12+128, so it does the same thing as the first example (add 1 to the element with index 12). However, the second example/method is harder for the reader to understand, and it will work only for Superchip expansion RAM (since the Superchip has 128 bytes of RAM, so there are a total of 256 write and read addresses).
Michael
