Hitachi Posted October 29, 2010 Share Posted October 29, 2010 Hello. I have a question. Will the breakaway cable from a wired 360 controller work with a regular xbox controller? I've seen pictures of the cable and it looks like you could take the original xbox controller and plug it into the thing. I'm hoping that it might for PC applications. Can someone test this, or has someone already? Thanks Quote Link to comment Share on other sites More sharing options...
jamesk Posted October 29, 2010 Share Posted October 29, 2010 Hello. I have a question. Will the breakaway cable from a wired 360 controller work with a regular xbox controller? I've seen pictures of the cable and it looks like you could take the original xbox controller and plug it into the thing. I'm hoping that it might for PC applications. Can someone test this, or has someone already? Thanks Well I have two original Xbox controllers. They are USB even though they have the odd original xbox plug on the end of the breakaway cable. I cut two extra USB cables and soldered them to the xbox cables and they work fine on my PC. I don't see any reason why the 360 breakaway would not work with the original controller. It looks like it fits and it would be diabolical for MS to change the pinouts. If you really want to be sure and you have a multimeter, a continuity test would verify the cable is compatible. Quote Link to comment Share on other sites More sharing options...
tetrode kink Posted October 29, 2010 Share Posted October 29, 2010 Well I have two original Xbox controllers. They are USB even though they have the odd original xbox plug on the end of the breakaway cable. I cut two extra USB cables and soldered them to the xbox cables and they work fine on my PC. I don't see any reason why the 360 breakaway would not work with the original controller. It looks like it fits and it would be diabolical for MS to change the pinouts. If you really want to be sure and you have a multimeter, a continuity test would verify the cable is compatible. Diabolical? Yes. Out-of-character? No. Quote Link to comment Share on other sites More sharing options...
Video Posted October 29, 2010 Share Posted October 29, 2010 The cables aren't compatible. They look similar, but they won't fit together. To bad, I would love to use my old duke on the 360, it's so much more comfortable than anything I've come across on the 360. You can hack the end off the original cable and wire it to work as a USB, and a computer will have no problem reading it, however, I imagine the 360 will not accept it. Quote Link to comment Share on other sites More sharing options...
eeun Posted November 14, 2010 Share Posted November 14, 2010 Another vote here for just adding a usb connector to your original xbox controller. You can even splice into the cable rather than cutting it if you want to also retain the original connector. I cut my cable, since my xbox is only used for XBMC, not gaming, and I only needed a 3-foot cable, not the 8-feet or however long the stock cable is. You'll need drivers on the PC, available Here. It's problematic installing in Vista/7, but a workaround is Here. Quote Link to comment Share on other sites More sharing options...
flyboyovyick Posted December 6, 2010 Share Posted December 6, 2010 You should see my Xbox!! Xbox 1.3 stock ram (for now) 40gb HDD with xbmc 3 controller ports 5 usbs Custom paint job Output Full HD 1080P Upscales DVD's Quote Link to comment Share on other sites More sharing options...
gtmtnbiker Posted December 17, 2010 Share Posted December 17, 2010 You should see my Xbox!! Xbox 1.3 stock ram (for now) 40gb HDD with xbmc 3 controller ports 5 usbs Custom paint job Output Full HD 1080P Upscales DVD's Are you able to use a regular USB gamepad with the xbox such as the 360 version? Which guide did you follow for adding USB ports to your xbox? Quote Link to comment Share on other sites More sharing options...
