abaudrand
little problems with if-then and maths
Hi, I'm trying to do a checktest to determine the movement of the missile of one player depending the position of the other player.
I wrote that:
if player1y-player0y<30 then var6{1}=0 else var6{1}=1
but it will not compile. I guess I got a kind of 'syntax error'.
Do I need to broke the operation like:
temp2=player1y-player0y
if temp2<30 then var6{1}=0 else var6{1}=1
What do you think?
okay, I'll try tommorow. I hoped it could save a line of code... Thanks RT.
I don't try to do math in an if-then. I use a temporary variable like in your second example.
I'm able to compile that line of code without an error, so I think there must be something else wrong with your program. What makes you think it's in that line? What does the error message say?
Michael
When I try to do the maths inside the if-then statement, the compilation stops at this line:
.L0784 ; if player1y - player0y < 30 then var6{1} = 0 else var6{1} = 1
LDA player1y
CMP player0y
.skipL0784
.condpart344
But when I broke into two part the code, it works fine:
.L0784 ; temp2 = player1y - player0y
LDA player1y
SEC
SBC player0y
STA temp2
.L0785 ; if temp2 < 30 then var6{1} = 0 else var6{1} = 1
LDA temp2
CMP #30
BCS .skipL0785
.condpart344
LDA var6
AND #253
STA var6
jmp .skipelse10
.skipL0785
LDA var6
ORA #2
STA var6
.skipelse10
For the moment, I will keep it broken in two parts even I don't understand why it doesn't work :)
Regards.
Michael
I think compiling it requires this build of bB.
:/ I don't know if I should use this build of bB as long as it's not an official upgrade... Since I've switched to SC, I got more free variables available and I could burn one or two for storing figures for mathematical operations. I must agree this new build could spare them and I also guess it could spare cycles... icon_question.gif(mumbling)
