Sign in to follow this
Kjmann
Altirra 1.8 Color Adjust Settings
I Really Like This Emulator. it's been a great tool for testing and Doesn't do a Bad job playing games either.
I of course will always be partial to the Real Hardware. =)
After playing with the Color Adjust settings for quite a while I Think I have come up with some settings that are really close to a Real NTSC Machine (I'm not Sure about PAL because I've never owned a PAL Machine).
I'm Very Picky about my color settings so I spent the time and thought everyone else would benefit from knowing what I came up with. =)
Here are my settings for the "Adjust Colors" selection under the "System > Video" pull down menu.
Hue Start: -50
Hue Step: 27.5
Brightness: -4%
Contrast: 100%
Saturation: 30%
Artifacting Phase: 189
Artifacting Saturation: 200%
Artifacting Brightness: +10%
Hope this helps. =)
Yeah, like that..Nice one...
Thanks. I use 4 Different Games To Set the Colors By. I use these when I'm Retrofitting an XL with the S-Video Kit that I sell. Since I include new Power supplies with all the systems I always have to re-adjust Hue Step Pot in the XL. So I decided to use the same 4 games to adjust Altirra.
1 - John Harris version of Frogger (Look at the Very Top Logs. they should be Dark Brown With a Very Slight Green Tint on Them and the Time Line At the Bottom should be Red.)
2 - Pole Position (Look At the Sky It should be an almost Periwinkle Blue. a little Darker and toward the green side from sky blue.)
3 - Pac-Man (On The Menu, The "Press Select for 2 player game" and Etc should be a good solid Light Green and the word "Select" A Solid "Pac-Man" Yellow)
4 - DropZone (The Ground Should be a Good Solid Brown just before the point of Turning Red)
As said before, thanks for the sharing, its nice to see a formula to the colours as opposed to my hit and miss approach :)
I Recently Made some minor Changes to my earlier settings for a better Artifacting look
Hue Start: -50
Hue Step: 27.5
Brightness: +0%
Contrast: 100%
Saturation: 35%
Artifacting Saturation: 90%
Artifacting Brightness: +0%
Hope this helps people get a good "Real Atari" Look. =)
Seen and adjusted, only one thought, you are using an NTSC machine, I wonder if someone would do the same with a PAL machine using the same sort of test guidelines, just for the sake of choice.
Either way i still like the look of yours.
Thanks for the compliment. =)
I hadn't thought of PAL Response. I'll have to look in to that.
Here are a couple more adjustments:
Hue Start: -50
Hue Step: 27.5
Brightness: +0%
Contrast: 105%
Saturation: 40%
Cheers Sal, changes entered.
A PAL set would be nice but as and when or indeed if it can be done.
