Scootiecat
How to reattach labels
The end label came off my Berzerk cart. What should I use to reattach it?
If you search around, there are many threads on this topic. Most usually suggest using a glue stick, but I've found that sometimes this isn't quite enough and the label starts to peel off again over time (especially near the edges). I've considered using a spray adhesive like this, but I haven't tried it so far myself.
Slap paste on the back, Jack
Make a new seal, Neil
You don't have to use gloss, Hoss
Just label your game.
Brush glue on the cart, Bart
It don't need to be fine art
Drip sap on the frame, James
And label your game.
Ahh yes!"50 ways to leave your" lover.That is one of my all time favorite songs.Paul Simon is absolutely the best of the song writers
Edited by Rik
UHU glue stick i think is the brand also scotch makes a CRAFT stick too or you can goto target
and get
YELLOW package
3m double stick see
threw scotch tape carefull not to rip label before using double sitck tape sticks to paper lables real good.
the tape looks like gift wrap tape but has a yellow cardboard insert on the 3m holder to let you know its double stick
I always pull more than i need then stick one end to desk then using sicsor cut thinner than normal and use small strips smaller not as WIDE AS LABEL im repairing to the label and then align then affix to cart the double stick tape works best but make shure its evenly applied to back side of label or it will look bumpy!..
here is my own label CROCKROCKS and end lable says ADAMw a paste from screen cap off stellax of my modded Asteroid©® Atari©Atari®( tm) type game..crockrocks I used HACKOMATIC II to remake graphics.
i used glue stick 1st but it came off so i changed to double stick double sided scotch type tape.
Disclaimer crockrocks is not for sale and
Asteroids® is a © and of Atari Corp and Atari® is a TM of Atari CORP.
all other ®'s are rocks in crockrocks..!!
Edited by awace
I'll third, fourth and fifth the glue stick. Before you try to adhese using the glue stick, though, I try to clean off the plastic and underside of the sticker with a slightly damp (water) q-tip to get any dust/hair/whatever that might keep the glue from sticking properly.
I'm with the majority here. I've used Elmer's glue sticks with a lot of success. I do recommend getting the old glue off the cartridge first so the new glue will stick nice. Goo Gone works really well, then I usually follow up with some glass cleaner and a paper towel.
