+Stephen Posted April 21, 2014 Share Posted April 21, 2014 Thanks for the update. Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted April 21, 2014 Share Posted April 21, 2014 The new Thunderdome connection appears to be MUCH faster than the old one. Quote Link to comment Share on other sites More sharing options...
+xucaen Posted April 26, 2014 Share Posted April 26, 2014 I got into BBSes back in the early 90's on my 386 DOS PC. I even ran a BBS for a short time on a 486, was on Fidonet too. This all sounds like fun, what would you all recommend for hardware if I wanted to get back into this? Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted April 29, 2014 Share Posted April 29, 2014 You're asking this in the Atari 8-Bit forum so the only logical answer is: an Atari XL or XE. Quote Link to comment Share on other sites More sharing options...
Theoryman Posted April 29, 2014 Share Posted April 29, 2014 Years ago, I ran a BBS Express! Pro system. Brings back memories. Started getting all my atari stuff out the last week or two. Have to see what can be found... -- Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 15, 2014 Share Posted May 15, 2014 It is a logical answer, and in the right place but the ST can run a pretty good BBS setup as well... Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted May 15, 2014 Share Posted May 15, 2014 Maybe. Is it possible to run a BBS with ST-Xformer? :-) Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 16, 2014 Share Posted May 16, 2014 Maybe. Is it possible to run a BBS with ST-Xformer? :-) Well, there's no maybe about the ST being able to run a BBS well. Got that living proof thing going on here. As for ST-Xformer running an 8bit BBS via emulation, I'm not sure. Cool concept though. Did the ST version support the serial ports and all that? Might actually be something fun to play with, but I'd still endorse running an 8bit BBS on real 8bit hardware. That's just me. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 16, 2014 Share Posted May 16, 2014 BTW, anyone logged on to the El Cafe lately? I've not been able to the last couple of attempts I've made. Thanks! Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted May 16, 2014 Share Posted May 16, 2014 No E Cafe in about 2 weeks I guess. You can run an Atari 8-bit BBS on a800win... been doing here it since 1999. Quote Link to comment Share on other sites More sharing options...
DocRotCod Posted May 17, 2014 Share Posted May 17, 2014 It's up. I've been having issues with it freezing up. My guess is because of the extra power draw with the PBI device and the PR: Connection. Need to make a higher amp power supply - hopefully that will take care of it. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 17, 2014 Share Posted May 17, 2014 Don't you be starvin' that puppy - feed it what it needs! Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted May 18, 2014 Share Posted May 18, 2014 As for ST-Xformer running an 8bit BBS via emulation, I'm not sure. Cool concept though. Did the ST version support the serial ports and all that? Was just kidding. I only know the initial release of ST-Xformer and it even can't keep up with BASIC games with some ML-routines. On stock 520ST that is. It does support an 8-bit disk drive when connected to the ST parallel port but I don't think the serial port can be used. I don't believe in software emulators anyways. They may be useful for some things but why use them if you have the real thing? Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 18, 2014 Share Posted May 18, 2014 Was just kidding. I only know the initial release of ST-Xformer and it even can't keep up with BASIC games with some ML-routines. On stock 520ST that is. It does support an 8-bit disk drive when connected to the ST parallel port but I don't think the serial port can be used. I don't believe in software emulators anyways. They may be useful for some things but why use them if you have the real thing? I kinda suspected that. I don't remember it running all that good on an original ST either. More of a curiosity than anything else. About the software emulation - I'm right there with ya brother. Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted May 31, 2014 Share Posted May 31, 2014 Was running through the BBS's today and was unable to connect with: Inside the 8bit El Cafe YYZ BBS I know their SysOps lurk around here - get'em back online guys, I miss calling in. Quote Link to comment Share on other sites More sharing options...
Atari-Collector Posted June 2, 2014 Share Posted June 2, 2014 Just to stick my nose in quick.. I just brought my BBS live after a 20 year break While running on a PC, the files areas are going to me mainly for Atari stuff (and Trekkie things) telnet://holodeckbbs.noip.me It's still a work in progress, so be kind Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted June 2, 2014 Share Posted June 2, 2014 Just to stick my nose in quick.. I just brought my BBS live after a 20 year break While running on a PC, the files areas are going to me mainly for Atari stuff (and Trekkie things) telnet://holodeckbbs.noip.me It's still a work in progress, so be kind I tried to login but it said 'port scanner' detected and kicked me off... ??? Quote Link to comment Share on other sites More sharing options...
Atari-Collector Posted June 2, 2014 Share Posted June 2, 2014 I tried to login but it said 'port scanner' detected and kicked me off... ??? Thanks for the info.. the new fossil driver seem a bit trigger happy on blocking. I can log in with in my own network fine. mite end up going back to the previous version since I know it worked on a live test a couple days ago sorry for the mix up.. Quote Link to comment Share on other sites More sharing options...
Atari-Collector Posted June 3, 2014 Share Posted June 3, 2014 Thanks for the info.. the new fossil driver seem a bit trigger happy on blocking. I can log in with in my own network fine. mite end up going back to the previous version since I know it worked on a live test a couple days ago sorry for the mix up.. The problem has been fixed. Mite be a couple bugs left, but that'll come in time. Quote Link to comment Share on other sites More sharing options...
+bf2k+ Posted June 3, 2014 Share Posted June 3, 2014 FOSSIL driver for tcp/ip? Sounds cool. Haven't used a FOSSIL since me old Fidonet days... 1 Quote Link to comment Share on other sites More sharing options...
Stephen J. Carden Posted June 9, 2014 Share Posted June 9, 2014 Was running through the BBS's today and was unable to connect with: Inside the 8bit El Cafe YYZ BBS I know their SysOps lurk around here - get'em back online guys, I miss calling in. I am up and running. I have both slaves up at the moment and as soon as my KRH (keyboard Replacement Hardware) get here I will be putting up more slaves. If you think the bbs has crashed just send an e-mail to realdos AT bellsouth.net Steve http://www.realdos.net Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted June 13, 2014 Share Posted June 13, 2014 (edited) Thunderdome seems to have some connection problems. The DNS service is acting up so thunderdome.anydns.com isn't actually pointing to the BBS most of the time. The problem is not at my end and the only thing I can so is complain to the service provider. I modified my online IP checker http://thunderdome.fox-1.nl to make it anydns-independent and I hope this temporary solution will do for now. Edited June 13, 2014 by Fox-1 / mnx Quote Link to comment Share on other sites More sharing options...
+DarkLord Posted June 14, 2014 Share Posted June 14, 2014 Hope you get it sorted out soon. Quote Link to comment Share on other sites More sharing options...
Lord Cygnus Posted June 24, 2014 Share Posted June 24, 2014 Thunderdome seems to have some connection problems. The DNS service is acting up so thunderdome.anydns.com isn't actually pointing to the BBS most of the time. The problem is not at my end and the only thing I can so is complain to the service provider. I modified my online IP checker http://thunderdome.fox-1.nl to make it anydns-independent and I hope this temporary solution will do for now. How are you doing Fox1? I tried connecting to your board using my 130XE to no avail. Were you able to resolve the IP/DNS issue? -=[Lord Cygnus]=- Quote Link to comment Share on other sites More sharing options...
Fox-1 / mnx Posted June 24, 2014 Share Posted June 24, 2014 (edited) It looks like the dynamic DNS issue can't be solved. I mailed the provider and after a long while I got a reply that they can't solve it because it's a 3rd party issue. Tried to contact them too but never got a single reply. As for now the only way to connect to the BBS is by using the IP address, which can be found at http://thunderdome.fox-1.nl Edited June 24, 2014 by Fox-1 / mnx Quote Link to comment Share on other sites More sharing options...
