Dropcheck #1726 Posted September 14, 2019 On 9/13/2019 at 4:10 PM, Tillek said: SFHQ is back up. If you wanted to test with telnet, the port is 5983 like it is on the list. I also have a raw port set at 5431 (same url). Lots of protocols to choose from. Tried this afternoon. Not able to logon. Got request to enter ESC key to energize, but neither the return key or ESC key seemed to be recognized. Got this cryptic message three times and was booted. **EMSI_REQA77E Quote Share this post Link to post Share on other sites
Dropcheck #1727 Posted September 14, 2019 16 hours ago, JohnPolka said: The Basement and Part-Time BBSs have files for download too (see my signature for telnet addresses). Incidentally, some of the BBSs use telnet protocol (I believe SFHQ and Boot Factory use telnet mode) and others (such as the Basement, Part-Time, and the Resistance) use raw mode. So, it probably would be good to try file transfers on a variety of BBSs. You probably should also test uploading too. -JP Logged on to both and apparently don't have a high enough security level to browse files. Was going to test uploading and downloading, but if I'm reading the menu screen right I have to be in the Browse section to do so. 😟 Would you be willing to increase my security level? Username is Dropcheck Quote Share this post Link to post Share on other sites
+Tillek #1728 Posted September 14, 2019 1 hour ago, Dropcheck said: Tried this afternoon. Not able to logon. Got request to enter ESC key to energize, but neither the return key or ESC key seemed to be recognized. Got this cryptic message three times and was booted. **EMSI_REQA77E That's the fidonet mailer. If you hit ESC it should go to the BBS... if you hit return, it tries to connect as a mailer. Wonder if you were the one that I saw that tried to connect, and then when the mailer timed out, I saw someone try to connect again by seeing RING for the username at the login a few times. If it doesn't like the ESC for some reason, you could also just wait a few seconds for the timeout. But out of curiosity, what software were you trying to connect with? Also, were you using telnet? (5983) or raw (5431)? Quote Share this post Link to post Share on other sites
Dropcheck #1729 Posted September 14, 2019 7 minutes ago, Tillek said: That's the fidonet mailer. If you hit ESC it should go to the BBS... if you hit return, it tries to connect as a mailer. Wonder if you were the one that I saw that tried to connect, and then when the mailer timed out, I saw someone try to connect again by seeing RING for the username at the login a few times. If it doesn't like the ESC for some reason, you could also just wait a few seconds for the timeout. But out of curiosity, what software were you trying to connect with? Also, were you using telnet? (5983) or raw (5431)? Probably was me. 🙂 I'm using BobTerm1.21 with the Rverter handler loaded. I was trying to connect using the IP address/5983 Quote Share this post Link to post Share on other sites
JohnPolka #1730 Posted September 15, 2019 2 hours ago, Dropcheck said: Logged on to both and apparently don't have a high enough security level to browse files. Was going to test uploading and downloading, but if I'm reading the menu screen right I have to be in the Browse section to do so. 😟 Would you be willing to increase my security level? Username is Dropcheck I sent you an email earlier...you now have access to both BBSs. -JP Quote Share this post Link to post Share on other sites
Dropcheck #1731 Posted September 15, 2019 (edited) 19 hours ago, JohnPolka said: I sent you an email earlier...you now have access to both BBSs. -JP Thank you. 🙂 I connected to the parttime bbs. I was able to initiate a Y-Modem-batch session and the first file did make it. However I ran out of disk space for the second and aborted. I was not however able to upload a text file. Not sure if it was at my end or not. Are you seeing any error indications at your end? Edited September 15, 2019 by Dropcheck Quote Share this post Link to post Share on other sites
JohnPolka #1732 Posted September 17, 2019 On 9/15/2019 at 1:26 PM, Dropcheck said: Thank you. 🙂 I connected to the parttime bbs. I was able to initiate a Y-Modem-batch session and the first file did make it. However I ran out of disk space for the second and aborted. I was not however able to upload a text file. Not sure if it was at my end or not. Are you seeing any error indications at your end? Part-Time uses raw mode instead of telnet mode for Internet connections. I suspect you might be using telnet mode. That may explain why you can't upload to Part-Time. -JP Quote Share this post Link to post Share on other sites
x=usr(1536) #1733 Posted September 17, 2019 (edited) On 8/19/2019 at 12:26 PM, _The Doctor__ said: https://www.ebay.com/itm/USR-GPRS232-730-Serial-RS232-RS485-to-GPRS-DTU-Support-GSM-GPRS/232133198296?_trkparms=aid%3D1110001%26algo%3DSPLICE.SIM%26ao%3D1%26asc%3D59401%26meid%3Db5a33927fe0945cab15e85b0c8d66712%26pid%3D100010%26rk%3D2%26rkt%3D12%26sd%3D282211959352%26itm%3D232133198296%26pg%3D2047675&_trksid=p2047675.c100010.m2109 what do you think about these? The idea's good, but it appears as though they may only support 2G GSM: https://www.usriot.com/products/rs232-gsm-modem.html Unless proof to the contrary can be found, I'd suggest giving these a miss. 2G and 3G GSM is in various phases of being shut down worldwide, so this is a device with a limited lifespan dependent on the plans of the cellular carriers in the territory it would be used in. Edited September 17, 2019 by x=usr(1536) Quote Share this post Link to post Share on other sites
777ismyname #1734 Posted September 23, 2019 There are LTE models. https://www.ebay.com/itm/USR-G781-industrial-celluar-serial-modem-lte-4g-data-converter-to-ethernet/263316950797?hash=item3d4ee9cf0d:m:m2nUftNswDyTqOZJBXpiUIQ 1 Quote Share this post Link to post Share on other sites
+Bikerbob #1735 Posted September 28, 2019 does anyone log into Hawaii BBS??? I have tried.. I get in.. I create an account.. log off.. try and log in again.. no go. Anyone?? James Quote Share this post Link to post Share on other sites
+Bikerbob #1736 Posted September 28, 2019 So Hawaii, is an Oasis 4.7 BBS - some super cool features and functions. I figured out why I kept loosing my info. I have my account now.. I have asked the SYSop if he would be willing to share the bbs software with others.. as far as I am aware there is no copy of Oasis 4.... anything in any archive. His seems to be running very well.. smooth and attractive in Atasci. So its important to have it saved. Anyway.. hope some more people call.. love to discuss on the board or here.. what you think about it. James Quote Share this post Link to post Share on other sites
+Bikerbob #1737 Posted September 28, 2019 So today doing my rounds Basement - down Part-time - down Vet Guild - down Tried several times, hope all is well, I remember Tillek saying he lost a drive on Veg Guild, not sure why the other two are down.. had tried friday as well.- John? James Quote Share this post Link to post Share on other sites
+Tillek #1738 Posted September 30, 2019 On 9/28/2019 at 4:13 PM, Bikerbob said: So today doing my rounds Basement - down Part-time - down Vet Guild - down Tried several times, hope all is well, I remember Tillek saying he lost a drive on Veg Guild, not sure why the other two are down.. had tried friday as well.- John? James Just FYI... Did get the new drive, just trying to toss some improvements in before restoring the image (and maybe one more last ditch attempt at a "right before crashing" backup. Quote Share this post Link to post Share on other sites
+Bikerbob #1739 Posted September 30, 2019 Veg Guild - LMAO I kill myself. Sorry Tillek.. Thats what happens when the Veterns get too old. James Quote Share this post Link to post Share on other sites
JohnPolka #1740 Posted September 30, 2019 (edited) On 9/28/2019 at 1:13 PM, Bikerbob said: So today doing my rounds Basement - down Part-time - down Vet Guild - down Tried several times, hope all is well, I remember Tillek saying he lost a drive on Veg Guild, not sure why the other two are down.. had tried friday as well.- John? James I noticed the problem this morning. Basement and Part-time are back up. I reset my router the other day but forgot to reset the port forwarding. I've been fighting a bad cold the last few days which is why this went unnoticed for a few days. -JP Edited September 30, 2019 by JohnPolka 1 Quote Share this post Link to post Share on other sites
+Tillek #1741 Posted October 1, 2019 22 hours ago, Bikerbob said: Veg Guild - LMAO I kill myself. Sorry Tillek.. Thats what happens when the Veterns get too old. James Eh? Wha was that sonny? I can't hear so well at my old age.... Damn dragons roar way too loud in those caves. Quote Share this post Link to post Share on other sites
+Tillek #1742 Posted October 1, 2019 20 hours ago, JohnPolka said: I noticed the problem this morning. Basement and Part-time are back up. I reset my router the other day but forgot to reset the port forwarding. I've been fighting a bad cold the last few days which is why this went unnoticed for a few days. -JP Hope you're feeling better...... 1 Quote Share this post Link to post Share on other sites
+Tillek #1743 Posted October 10, 2019 I just posted on the Atari BBS club in the SysOp section about some improvements/features for the BBS list. Hope you find them useful. Quote Share this post Link to post Share on other sites
+Bikerbob #1744 Posted October 18, 2019 (edited) On 9/28/2019 at 4:05 PM, Bikerbob said: So Hawaii, is an Oasis 4.7 BBS - some super cool features and functions. I figured out why I kept loosing my info. I have my account now.. I have asked the SYSop if he would be willing to share the bbs software with others.. as far as I am aware there is no copy of Oasis 4.... anything in any archive. His seems to be running very well.. smooth and attractive in Atasci. So its important to have it saved. Anyway.. hope some more people call.. love to discuss on the board or here.. what you think about it. James posted it up on mousenet!! James Edited October 18, 2019 by Bikerbob 1 Quote Share this post Link to post Share on other sites
+Tillek #1745 Posted October 22, 2019 Just a note.... took SFHQ down today since it seemed I was getting spammed... I'll get it back up tonight but I had to go to work and didn't have time to dig into it and didn't want to leave it running like that. Not that anyone would be likely to get on with it constantly getting hang up calls. Quote Share this post Link to post Share on other sites
+Bikerbob #1746 Posted October 22, 2019 seems a few boards are down at the moment. James Quote Share this post Link to post Share on other sites
+Tillek #1747 Posted October 23, 2019 14 hours ago, Bikerbob said: seems a few boards are down at the moment. James Well, the attack continues from a new IP so.... we'll see. Anyone else getting a ton of activity on their BBS ports in their firewall logs? 1 Quote Share this post Link to post Share on other sites
+Bikerbob #1748 Posted October 24, 2019 that sucks.. wish people have something better to do. James lol.. I keep wanting to finish with /s 1 Quote Share this post Link to post Share on other sites
+Tillek #1749 Posted October 24, 2019 4 hours ago, Bikerbob said: that sucks.. wish people have something better to do. James lol.. I keep wanting to finish with /s I do that too. In fact, I think I'm just going to start doing it.... confuse the FaceBook crowd. /s Quote Share this post Link to post Share on other sites
+DarkLord #1750 Posted October 24, 2019 Yeah, I love that idea! I might even make a shirt with some old style BBS stuff on it. Go /s !!! Quote Share this post Link to post Share on other sites
