Geoff Oltmans Posted October 15, 2020 Author Share Posted October 15, 2020 Just a clarification... I've had issues getting things building and working the same on both platforms at the exact same time sometimes. I *think* I'm close to having something a little more modern and maintainable at this point though. Quote Link to comment Share on other sites More sharing options...
joltguy Posted October 16, 2020 Share Posted October 16, 2020 11 hours ago, Geoff Oltmans said: I can send you a dev build to tinker with and maybe you can help me flesh out any bugs if you're interested (or anyone else for that matter). I'd love to try it out! 1 Quote Link to comment Share on other sites More sharing options...
Geoff Oltmans Posted October 16, 2020 Author Share Posted October 16, 2020 In this archive is the application itself, and the SDL2 framework. The .framework needs to be copied over to the /Library/Frameworks folder before launching. Let me know how it works! AdamemSDL_macos_2_1d.zip 1 1 Quote Link to comment Share on other sites More sharing options...
joltguy Posted October 16, 2020 Share Posted October 16, 2020 1 hour ago, Geoff Oltmans said: In this archive is the application itself, and the SDL2 framework. The .framework needs to be copied over to the /Library/Frameworks folder before launching. Let me know how it works! Seems to be working! It wouldn't launch when I copied the SDL2 framework to /Library/Frameworks (security issue) but I was able to get it to work by installing the framework in my user ~/Library/Frameworks folder instead. I can't test thoroughly test right now but I was able to get it to boot a few different .dsk images without issue. Full screen worked too! A couple of issues I did notice so far: The names of the mounted disk images don't show up in the menu Mounting to anything other than disk 1 or tape 1 doesn't seem to work Thanks for developing this! ? 1 Quote Link to comment Share on other sites More sharing options...
Geoff Oltmans Posted October 16, 2020 Author Share Posted October 16, 2020 2 hours ago, joltguy said: Seems to be working! It wouldn't launch when I copied the SDL2 framework to /Library/Frameworks (security issue) but I was able to get it to work by installing the framework in my user ~/Library/Frameworks folder instead. I can't test thoroughly test right now but I was able to get it to boot a few different .dsk images without issue. Full screen worked too! A couple of issues I did notice so far: The names of the mounted disk images don't show up in the menu Mounting to anything other than disk 1 or tape 1 doesn't seem to work Thanks for developing this! ? Good to hear! Yeah, there's bound to be some issues in there. Most of the preferences menu requires you to save the changes and then relaunch the application to take effect, so bear that in mind. Quote Link to comment Share on other sites More sharing options...
mr_gw454 Posted March 4, 2023 Share Posted March 4, 2023 Hi @Geoff Oltmans, I was able to download a current version of your emulator from James's adamarchive.org site and this one works perfectly on my Linux Mint 20.1 system:ADAMem SDL v2.1g Linux (2023) (Geoff Oltmans).zip I'd like to know if the source is available for this more recent version as I'd like to try to compile it for use on my Raspberry Pi 4 (ARM). Thank you! Quote Link to comment Share on other sites More sharing options...
Geoff Oltmans Posted March 10, 2023 Author Share Posted March 10, 2023 On 3/3/2023 at 6:57 PM, mr_gw454 said: Hi @Geoff Oltmans, I was able to download a current version of your emulator from James's adamarchive.org site and this one works perfectly on my Linux Mint 20.1 system:ADAMem SDL v2.1g Linux (2023) (Geoff Oltmans).zip I'd like to know if the source is available for this more recent version as I'd like to try to compile it for use on my Raspberry Pi 4 (ARM). Thank you! Not yet. I want to clean up a few things before I let loose the floodgates. 1 Quote Link to comment Share on other sites More sharing options...
mr_gw454 Posted September 27, 2023 Share Posted September 27, 2023 On 3/9/2023 at 10:04 PM, Geoff Oltmans said: Not yet. I want to clean up a few things before I let loose the floodgates. Hi Geoff -- any update on this? Thanks! Quote Link to comment Share on other sites More sharing options...
Geoff Oltmans Posted September 27, 2023 Author Share Posted September 27, 2023 5 hours ago, mr_gw454 said: Hi Geoff -- any update on this? Thanks! I'm closer than I was. Prolly in another week or so. sorry for the delays. Quote Link to comment Share on other sites More sharing options...
mr_gw454 Posted September 27, 2023 Share Posted September 27, 2023 31 minutes ago, Geoff Oltmans said: I'm closer than I was. Prolly in another week or so. sorry for the delays. Not a problem at all -- just hobby stuff! I'm interested in the source to see if I can get it to compile on a Raspberry Pi. Thanks again! Quote Link to comment Share on other sites More sharing options...
Geoff Oltmans Posted October 2, 2023 Author Share Posted October 2, 2023 On 9/27/2023 at 3:09 PM, mr_gw454 said: Not a problem at all -- just hobby stuff! I'm interested in the source to see if I can get it to compile on a Raspberry Pi. Thanks again! It'll definitely do that. Quote Link to comment Share on other sites More sharing options...
