JohnBuell
Disk drive conversion question
I know there have been aftermarket conversion kits for 3 1/2" drives for use with the 8-bits for quite a long time. In theory, you can replace or add an off the shelf 3.5" drive to certain units, like the XF551 and have a 3.5 or dual 3.5/5.25 drive setup. But what I'm wondering is has anyone taken drives like the old ST external drives and converted those for use with an 8bit? Is this remotely possible?
Well they are standard PC drives I think. You could use a standard Atari ST floppy drive on an Atari PC-1 anyway..
So I would think if you were willing to come up with a cable you could use an Atari ST floppy drive with an ATR-8000.
Yes they are.
I have an XF551 with a 3,5" 720KB drive, ripped from an Atari STF and another XF551 with an aftermarket 5,25" 720KB drive intended for ST usage.
In theory the drive mechanism could probably be swapped into the XF551.
The entire drive itself - no, the ST has all the drive controller stuff inside the computer, the work that the CPU and controller would normally do can't be done by the 8-bit computer.
ST drive by external interface? I don't know, don't have one.
